QoS Shaping Issue
Joe Lee
I am working on creat the QoS Policy with the shaping. Please the policy below.
class-map match-any mail
match protocol exchange
match protocol smtp
class-map match-any system
match protocol ftp
match protocol telnet
class-map match-any high
match access-group 2222
class-map match-any low
match protocol http url "xxx.com*"
match class-map mail
match class-map system
policy-map low_family
class mail
bandwidth percent 80
class system
bandwidth percent 20
policy-map ABC
class high
shape average percent 60
class low
shape average percent 40
service-policy low_family
In the red hightlight,
Can I do like this without matching two class-map since they will fall into the low class policy?
Please advise. Thanks.
5 Replies 5
stevjarbeck
Yes.
Steve
Hi Steve,
Can you please provide me little details? or link will be helpful.
Thanks.
Sorry for giving you the wrong answer.  I've had the flu for the past week and obviously my brain isn't functioning yet.
OK.
You want to take this:
and break it down to this:
Here is the issue:
class mail
class system
policy-map ABC
class high
class low
In your policy map, as it classifies traffic it will reach "low".  The classification for low contains mail, system and the URL.  If you remove mail and system from the classification when it reaches your policy classifcation of low it will only classify the URL and apply the policy of low_family. Even though low_family matches mail and system, the policy-map itself that you attach to the interface won't match mail and system.
Let me try to break it down a bit easier.
Traffic goes out and the router classifies the traffic.  It sees high which is ACL based and gives this priority.  It won't see mail and system if you remove that from class-map match-any low even though you have it in the policy-map.  It will only know when to apply the policy-map when the classification critera has been met.  Without this, it won't know what to do with mail and system.   You can provide more control over the remaining 40% by applying another policy-map to it, as you did.
I would re-work it this way:
class-map match-any LowURL
match protocol http   url "*youtube*"
class mail
bandwidth percent 70
class system
class LowURL
bandwidth percent 10
OR
class class-default
  fair-queue
Does that help?
Again, sorry for confusing you earlier.
References:
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/fqos_c.html
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfcbshp.html#wp1002748  <--I recommend looking at this.
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t5/feature/guide/cbwfq.html (Class-Based Weighted Fair Queueing)
Hi Steve,
Thank you so much for your help. I have two more questions...
1. Based on the policy below,
match protocol http url "youtub.com*"
class mail
class system
policy-map ABC
class high
class low
If the url"youtube.com*" is place in a low (parent) policy, but not within the low family policy, how is that traffic handled in relation to CBWFQ defined in the low family policy?
2. What takes precedence for classification of traffic, NBAR or access-list?
Joe
"If a default class is configured with the bandwidth policy-map class configuration command, all unclassified traffic is put into a single queue and given treatment according to the configured bandwidth. If a default class is configured with the fair-queue command, all unclassified traffic is flow classified and given best-effort treatment. If no default class is configured, then by default the traffic that does not match any of the configured classes is flow classified and given best-effort treatment. Once a packet is classified, all of the standard mechanisms that can be used to differentiate service among the classes apply. " (Cisco)
Inbound
Outbound
  1. QoS Policy Propagation through Border Gateway Protocol (BGP)                       (QPPB)
  2. Input common classification
  3. Input ACLs
  4. Input marking (class-based marking or Committed Access Rate                       (CAR))
  5. Input policing (through a class-based policer or                       CAR)
  6. IP Security (IPSec)
  7. Cisco Express Forwarding (CEF) or Fast                       Switching
  1. CEF or Fast Switching
  2. Output common classification
  3. Output ACLs
  4. Output marking
  5. Output policing (through a class-based policer or                       CAR)
  6. Queueing (Class-Based Weighted Fair Queueing (CBWFQ) and Low                       Latency Queueing (LLQ)), and Weighted Random Early Detection                       (WRED)
References:
Quality of Service Order of Operation
You are welcome, I'm happy that I was able to help.  Let me know if you have any more questions.
Steve
