07-06-2021 05:36 AM - edited 07-06-2021 08:29 AM
Hello cisco community members.
I have a TP- link TD-W9970 modem that is in bridge mode, one 2821 router, Modem lan port & 2821 roter 0/0 port are connected.
modem gateway IP= 192.168.1.1
IP static= 185.120.250.247
router 0.0 IP= 192.168.152.74
router 0.1 IP= 192.168.2.1
pc IP (connected to 0/1 in rouer)= 192.168.2.2
we have one ipsec tunnel that is ok. Router have internet but the pc can`t get acces to the internet.
I`m able to ping router 0/1 port (192.168.2.1) & router 0/0 port (192.168.152.74) & 10.1.1.150 (ipsec tunnel). But I can`t ping the modem gateway (192.168.1.1)
Please help to get access to the internet in pc or switch connected to 0/1 port. I think that I need to a root. thanks for every one that help.
Fariborzi#show conf
Using 2275 out of 245752 bytes
version 12.4
hostname Fariborzi
boot-start-marker
boot-end-marker
enable secret 5 $1$/.O0$5YpYvp3LWrTrhTcOZYsG//
no aaa new-model
ip cef
ip domain name FariborziShop.co.ir
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
no dspfarm
username admin secret 5 $1$hQx2$s5HAC4W1uP2cUm9AObDQp/
crypto isakmp policy 370
encr 3des
authentication pre-share
group 2
crypto isakmp key #F@r!b0rz!$h0p# address 91.207.139.1
crypto ipsec transform-set Fariborzi-Shop-TS esp-aes 256 esp-sha-hmac
mode transport
crypto ipsec profile Fariborzi-Shop-PF
set transform-set Fariborzi-Shop-TS
interface Tunnel4410
description connect to post
ip address 192.168.152.74 255.255.255.252
ip mtu 1400
ip nat outside
ip virtual-reassembly
ip tcp adjust-mss 1360
tunnel source 185.120.250.247
tunnel destination 91.207.139.1
tunnel protection ipsec profile Fariborzi-Shop-PF
interface GigabitEthernet0/0
description connect-Modem
ip address 185.120.250.247 255.255.255.254
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
description connect-LAN
ip address 192.168.2.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp pap sent-username 4144227319 password 0 44010493
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1 permanent
ip route 10.1.1.150 255.255.255.255 192.168.152.73 name POST
no ip http server
no ip http secure-server
ip nat inside source list POST-NAT interface Tunnel4410 overload
ip nat inside source list dsl-access interface Dialer1 overload
ip access-list extended POST-NAT
permit ip any host 10.1.1.150
ip access-list extended dsl-access
permit ip 10.0.0.0 0.0.0.255 any
control-plane
line con 0
login local
line aux 0
line vty 0 4
login
transport input ssh
line vty 5 15
login
transport input ssh
scheduler allocate 20000 1000
end
07-06-2021 03:10 PM
Hello @Feredi ,
in a scenario like yours it is better to use route-maps so that it makes more clear what NAT should do.
route-map INTERNET permit 10
match address dsl-access
match interface Dialer 1
route-map TUNNEL permit 10
match address POST-NAT
match interface tunnel 4410
no ip nat inside source list POST-NAT interface Tunnel4410 overload
no ip nat inside source list dsl-access interface Dialer1 overload
ip nat inside source route-map INTERNET interface Dialer 1 overload
ip nat inside source route-map TUNNEL interface Tunnel4410 overload
then also rewrie ACL dsl-access in the following way:
deny ip 10.0.0.0 0.0.0.255 host 10.1.1.150
Note: the match interface refers to the exit interface in the route-maps.
Hope to help
Giuseppe
07-07-2021 02:27 AM
hii Guiseppe larosa
Please tell me exactly which lines I must delete and replace your commands.
I`m a beginner
Thanks so much
