07-06-2021 03:47 PM
I want to connect router A and router B with a cable and link them up,
"Fast Ethernet 0/1 is up, line protocol is down".
I can't connect normally.
I put the following command in Fa0 / 1 of Router A and Router B.
-Router A-
conf t
interface FastEthernet0 / 1
ip address 192.168.3.1 255.255.255.0
duplex full
speed 100
no shut
exit
-Router B-
conf t
ip address 192.168.3.2 255.255.255.0
duplex full
speed 100
no shut
exit
The result of the "sh int" command is:
-Router A / Router B-
FastEthernet0 / 1 is up, line protocol is down
Hardware is Gt96k FE, address is ****. ****. **** (bia ****. ****. ****)
Internet address is 192.168.3.1/24 ← Router B is "192.168.3.2/24"
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Auto-duplex, Auto Speed, 100BaseTX / FX
(Omitted)
I am simply aiming for a connection within the same segment,
Does this series require a serial cable?
I have no idea what caused the connection.
Please kindly advise.
Thanking you in advance.
07-06-2021 03:58 PM
they should work (you do not serial connection to work p2p link)
this shows - major as below :
1. cable is not good, so check ethernet cable
2. or one of the side interfaces may have an issue.
if you have a laptop or device, connect to this device the interface should come up as a test
07-06-2021 09:07 PM
Thank you for your reply.
I am using a "cat5e" crossover cable.
I exchanged it, but the result was the same.
I replaced it with another 1841 router and the results were the same.
> if you have a laptop or device, connect to this device the interface> should come up as a test
The PC is currently connected to Fa0 / 0.
After changing Fa0 / 1 to the same segment as the PC, connect the PC to Fa0 / 1
Let's test whether to link up.
07-07-2021 05:22 AM
> if you have a laptop or device, connect to this device the interface> should come up as a test The PC is currently connected to Fa0 / 0. After changing Fa0 / 1 to the same segment as the PC, connect the PC to Fa0 / 1 Let's test whether to link up.
You mean when you connect the PC, the Port come up ? on both Router side (when you do reach one ?)
can you post below inforation form each Router :
show run
show version
show interface fas 0/1 (complete output)
07-06-2021 04:26 PM
Are you using a cross-over cable?
Have you tried with both side's ports configured for auto speed and duplex?
07-06-2021 09:12 PM
> Have you tried with both side's ports configured for auto speed and> duplex?
I made it automatic on both sides, but the result was the same.
This is recognized as an "Auto MDI / MDI-X" compatible device.
