2821 Router is getting high CPU Utilization
Muthukumar P
Hi team,
                We are getting high cpu utilization on cisco 2821 Router. Could you suggest on this.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.07.05 00:17:13 =~=~=~=~=~=~=~=~=~=~=~=
ter len 0
MH-NMVIKROLI-NMDC-RT-C2861-1.146#sh inv
MH-NMVIKROLI-NMDC-RT-C2861-1.146#sh inventory
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821         , VID: V04 , SN: FHK1129F29Y
NAME: "WAN Interface Card - Serial (1T)", DESCR: "WAN Interface Card - Serial (1T)"
PID: WIC-1T=           , VID: 1.0, SN: 35857142
MH-NMVIKROLI-NMDC-RT-C2861-1.146#show tech
------------------ show version ------------------
Cisco IOS Software, 2800 Software (C2800NM-IPBASEK9-M), Version 12.4(10b), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 19-Jan-07 16:23 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
MH-NMVIKROLI-NMDC-RT-C2861-1.146 uptime is 1 year, 16 weeks, 6 days, 17 hours, 42 minutes
System restarted at 06:00:08 IST Sat Mar 9 2019
System image file is "flash:c2800nm-ipbasek9-mz.124-10b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.50) with 251904K/10240K bytes of memory.
Processor board ID FHK1129F29Y
2 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
------------------ show running-config ------------------
Building configuration...
Current configuration : 13851 bytes
! Last configuration change at 11:05:26 IST Sat Mar 14 2020 by L2admin
! NVRAM config last updated at 10:58:34 IST Sat Mar 14 2020 by rsadmiN
version 12.4
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname MH-NMVIKROLI-NMDC-RT-C2861-1.146
boot-start-marker
boot-end-marker
logging buffered 4096 informational
logging console critical
no logging monitor
enable password 7 <removed>
no aaa new-model
clock timezone IST 5 30
ip cef
ip flow-cache timeout active 1
ip domain name Indiainfoline.com
ip multicast-routing
ip ssh version 2
username nmadmin privilege 15 secret 5 <removed>
username rsadmin privilege 15 secret 5 <removed>
username L3admin privilege 15 secret 5 <removed>
username L1admin privilege 5 secret 5 <removed>
username L2admin privilege 15 secret 5 <removed>
archive
 log config
  logging enable
  notify syslog
  hidekeys
interface Loopback0
 no ip address
interface Loopback1
 ip address 202.87.34.68 255.255.255.255
interface Loopback2
 ip address 202.87.34.70 255.255.255.255
interface Loopback3
 ip address 202.87.34.71 255.255.255.255
interface Loopback4
 ip address 202.87.34.72 255.255.255.255
interface Loopback5
 ip address 202.87.34.73 255.255.255.255
interface Loopback6
 ip address 202.87.34.74 255.255.255.255
interface Tunnel0
 description ***GRE Tunnel to WebWorks DC***
 ip address 10.10.101.17 255.255.255.252
 ip flow ingress
 ip pim sparse-mode
 ip igmp static-group 224.5.6.9
 ip igmp static-group 224.5.6.8
 ip igmp static-group 239.255.255.255
 ip igmp static-group 224.5.6.7
 ip igmp static-group 224.7.8.9
 ip igmp static-group 233.1.2.5
 ip igmp static-group 233.1.2.7
 ip igmp static-group 224.5.6.10
 tunnel source 202.87.34.71
 tunnel destination 180.149.240.17
interface Tunnel1
 description ***NMG BLORE GRE***
 ip address 10.10.100.1 255.255.255.252
 ip pim sparse-mode
 tunnel source 202.87.34.68
 tunnel destination 180.179.234.74
interface Tunnel2
 description ***NMG_Banglore_GRE***
 ip address 10.10.101.29 255.255.255.252
 ip pim sparse-mode
 ip igmp static-group 224.5.6.21
 shutdown
 tunnel source 202.87.34.74
interface Tunnel4
 description ***Tunnel for UAT***
 ip address 10.10.101.21 255.255.255.252
 ip pim sparse-mode
 shutdown
 tunnel source 202.87.34.72
 tunnel destination 180.179.100.178
interface Tunnel5
 description ***NMG Chennai GRE***
 ip address 10.10.101.25 255.255.255.252
 ip pim sparse-mode
 shutdown
 tunnel source 202.87.34.73
 tunnel destination 180.179.33.250
interface GigabitEthernet0/0
 ip address 202.87.34.66 255.255.255.252
 ip route-cache flow
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 172.16.1.146 255.255.0.0
 no ip proxy-arp
 ip pim sparse-mode
 duplex auto
 speed auto
interface Serial0/1/0
 no ip address
 shutdown
 clock rate 2000000
ip route 0.0.0.0 0.0.0.0 202.87.34.65
ip route 10.20.2.0 255.255.255.224 Tunnel5
ip route 172.17.10.0 255.255.255.0 172.16.1.1
ip route 172.17.11.0 255.255.255.0 172.16.1.1
ip route 172.17.12.64 255.255.255.255 172.16.1.1
ip route 172.17.13.0 255.255.255.0 172.16.1.1
ip route 172.24.41.0 255.255.255.0 172.16.1.1
ip route 172.24.41.39 255.255.255.255 172.16.1.1
ip route 172.24.41.40 255.255.255.255 172.16.1.1
ip route 172.24.41.44 255.255.255.255 172.16.1.1
ip route 172.24.41.61 255.255.255.255 172.16.1.1
ip route 172.24.41.68 255.255.255.255 172.16.1.1
ip route 172.24.41.210 255.255.255.255 172.16.1.1
ip route 172.26.0.0 255.255.0.0 172.16.1.1
ip route 192.168.0.0 255.255.255.0 172.16.1.1
ip route 192.168.14.0 255.255.255.0 172.16.1.1
ip route 192.168.24.177 255.255.255.255 172.16.1.1
ip route 192.168.27.0 255.255.255.0 Tunnel0
ip route 192.168.28.0 255.255.255.0 Tunnel4
ip route 192.168.72.0 255.255.255.0 Tunnel1
ip route 192.168.74.0 255.255.255.0 172.16.1.1
ip route 192.168.76.0 255.255.255.0 Tunnel1
ip route 192.168.120.0 255.255.255.0 172.16.1.1
ip route 192.168.121.0 255.255.255.0 172.16.1.1
ip route 192.168.130.0 255.255.255.0 172.16.1.1
ip route 192.168.140.0 255.255.255.0 172.16.1.1
ip route 192.168.142.115 255.255.255.255 172.16.1.1
ip route 192.168.142.160 255.255.255.248 172.16.1.1
ip route 192.168.142.201 255.255.255.255 172.16.1.1
ip route 192.168.142.202 255.255.255.255 172.16.1.1
ip route 192.168.142.203 255.255.255.255 172.16.1.1
ip route 192.168.142.204 255.255.255.255 172.16.1.1
ip route 192.168.149.251 255.255.255.255 172.16.1.1
ip route 192.168.160.0 255.255.255.0 172.16.1.1
ip route 192.168.175.202 255.255.255.255 172.16.1.1
ip route 192.168.180.0 255.255.255.0 172.16.1.1
ip route 192.168.189.25 255.255.255.255 172.16.1.1
ip route 192.168.189.26 255.255.255.255 172.16.1.1
ip route 192.168.189.27 255.255.255.255 172.16.1.1
ip route 192.168.191.213 255.255.255.255 172.16.1.1 name ##CH003251-SEBI-ROUTE##
ip flow-export version 5
ip flow-export destination 172.16.3.32 2055
ip flow-export destination 172.24.41.68 2055
no ip http server
no ip http secure-server
ip access-list standard SNMP_Server
 permit 172.26.20.38
 permit 172.24.41.68
ip access-list standard remote_access
 permit 172.16.1.152
 permit 172.17.10.139
 permit 172.24.41.211
 permit 172.24.41.210
 permit 172.26.20.38
 permit 172.26.20.46
 permit 172.24.41.40
 permit 172.26.3.13
 permit 172.24.41.39
 permit 172.24.41.95
 permit 172.24.41.68
 permit 192.168.180.0 0.0.0.255
 permit 192.168.130.0 0.0.0.255
 permit 10.10.56.0 0.0.0.255
 permit 192.168.29.0 0.0.0.127
 deny   any
logging history debugging
logging source-interface GigabitEthernet0/1
logging 172.16.3.172
logging 172.16.3.33
logging 172.16.3.206
access-list 10 permit 220.226.207.138
access-list 67 permit 172.24.41.232
access-list 67 permit 172.26.20.53
access-list 67 permit 172.26.3.84
access-list 67 permit 172.24.41.116
access-list 67 deny   any
access-list 99 permit 172.16.1.177
access-list 99 permit 172.16.1.152
access-list 99 permit 172.16.3.153
access-list 99 permit 172.17.13.137
access-list 99 permit 172.16.3.242
access-list 99 permit 172.24.41.211
access-list 99 permit 172.24.41.210
access-list 99 permit 172.16.3.200
access-list 99 permit 172.26.20.38
access-list 99 permit 172.16.3.32
access-list 99 permit 172.24.41.44
access-list 99 permit 172.24.41.40
access-list 99 permit 172.26.3.13
access-list 99 permit 172.24.41.39
access-list 99 permit 172.16.3.119
access-list 99 permit 172.24.41.68
access-list 99 permit 172.16.1.96
access-list 99 permit 172.17.12.64
access-list 99 permit 172.16.3.73
access-list 99 permit 192.168.180.0 0.0.0.255
access-list 99 deny   any
snmp-server community <removed> RO
snmp-server community <removed> RO 67
snmp-server ifindex persist
snmp-server host 172.24.41.116 <removed>
snmp-server host 172.24.41.232 <removed>
snmp-server host 172.26.20.53 <removed>
snmp-server host 172.26.3.84 <removed>
snmp-server host 172.16.1.219 <removed>
snmp-server host 172.16.3.32 <removed>
snmp-server host 172.16.3.73 <removed>
snmp-server host 172.24.41.68 <removed>
snmp-server host 172.26.20.38 <removed>
tacacs-server host 172.24.41.44
tacacs-server host 172.24.41.39
tacacs-server directed-request
tacacs-server key 7 <removed>
control-plane
banner login ^CC
                        -----"Warning"-----
This system is for use by authorized users only.
Any individual using this system, with, without, excess authorization acknowledges and consents
to the right of the company to monitor, access,use, and disclose any information generated,
received, or stored on the systems,and waives any right of privacy or expectation of privacy
on the part of the individual in connection with his or her use of this system.
If monitoring / investigation reveals possible conduct of criminal activity, system personnel
may provide the evidence of such activity to law enforcement officers.
Unauthorized and / or improper use of this system, as delineated by corporate policies,
is not tolerated and the company may take formal action against such individuals.
^C
banner motd ^CCCC^C
privilege ipenacl level 1 deny ip
privilege ipenacl level 1 permit ip
privilege ipsnacl level 1 deny
privilege ipsnacl level 1 permit
privilege router level 2 neighbor
privilege interface level 1 cdp enable
privilege interface level 1 speed
privilege interface level 1 duplex
privilege interface level 1 shutdown
privilege interface level 1 delay
privilege interface level 1 load-interval
privilege interface level 2 ip igmp static-group
privilege interface level 2 ip policy
privilege interface level 2 ip multicast boundary
privilege interface level 1 ip pim sparse-dense-mode
privilege interface level 1 ip pim sparse-mode
privilege interface level 1 ip pim dense-mode
privilege interface level 1 ip pim dr-priority
privilege interface level 1 ip flow egress
privilege interface level 1 ip flow ingress
privilege interface level 2 ip access-group
privilege interface level 1 ip address
privilege interface level 1 bandwidth
privilege interface level 1 description
privilege interface level 1 no cdp enable
privilege interface level 1 no speed
privilege interface level 1 no duplex
privilege interface level 1 no shutdown
privilege interface level 1 no delay
privilege interface level 1 no load-interval
privilege interface level 2 no ip igmp static-group
privilege interface level 2 no ip policy
privilege interface level 2 no ip multicast boundary
privilege interface level 1 no ip pim sparse-dense-mode
privilege interface level 1 no ip pim sparse-mode
privilege interface level 1 no ip pim dense-mode
privilege interface level 1 no ip pim dr-priority
privilege interface level 1 no ip flow egress
privilege interface level 1 no ip flow ingress
privilege interface level 2 no ip access-group
privilege interface level 1 no ip address
privilege interface level 1 no bandwidth
privilege interface level 1 no description
privilege configure level 2 route-map
privilege configure level 1 cdp run
privilege configure level 1 ip access-list extended
privilege configure level 1 ip access-list standard
privilege configure level 2 router
privilege configure level 1 interface
privilege configure level 2 no route-map
privilege configure level 1 no cdp run
privilege configure level 1 no ip access-list extended
privilege configure level 1 no ip access-list standard
privilege configure level 2 no router
privilege configure level 1 no interface
privilege exec level 2 write memory
privilege exec level 1 traceroute
privilege exec level 1 ping ip
privilege exec level 3 enable
privilege exec level 1 configure terminal
privilege exec level 1 show tech-support
privilege exec level 1 show standby brief
privilege exec level 1 show ip route
privilege exec level 1 show ip interface brief
privilege exec level 1 show cdp neighbors
privilege exec level 1 show mac-address-table
privilege exec level 1 show clock
privilege exec level 1 show processes
privilege exec level 1 show version
privilege exec level 1 show interfaces
privilege exec level 1 show startup-config
privilege exec level 1 show running-config view full
privilege exec level 1 show configuration
privilege exec level 1 no
privilege exec level 1 clear ip route
privilege exec level 1 clear ip arp
privilege exec level 1 clear counters
line con 0
line aux 0
 no exec
line vty 0 4
 access-class remote_access in
 exec-timeout 3 0
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
scheduler allocate 20000 1000
ntp clock-period 17180727
ntp server 192.168.149.251
ntp server 172.26.20.251
end
5 Replies 5
Muthukumar P
------------------ show stacks ------------------
Minimum process stacks:
 Free/Size   Name
 4820/6000   USB Startup
 5332/6000   SPAN Subsystem
 5144/6000   DIB error message
 4544/12000  Init
 5256/6000   RADIUS INITCONFIG
 2144/3000   Rom Random Update Process
 9084/12000  SSH Process
Interrupt level stacks:
Level    Called Unused/Size  Name
  1  1918817880   6272/9000  Network interfaces
  2  2692363872   8592/9000  DMA/Timer Interrupt
  3           1   8288/9000  PA Management Int Handler
  4           4   8640/9000  Console Uart
  5           0   9000/9000  External Interrupt
  7  1858815139   8560/9000  NMI Interrupt Handler
Spurious interrupts: 34622
------------------ show interfaces ------------------
GigabitEthernet0/0 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0007.0e1f.5550 (bia 0007.0e1f.5550)
  Internet address is 202.87.34.66/30
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is T
  output flow-control is XON, input flow-control is XON
  Last input 00:00:14, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     153001758 packets input, 245900667 bytes, 0 no buffer
     Received 12745 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast, 12 pause input
     299347638 packets output, 2931976558 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0007.0e1f.5551 (bia 0007.0e1f.5551)
  Internet address is 172.16.1.146/16
     reliability 254/255, txload 1/255, rxload 96/255
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/1505661/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 379336000 bits/sec, 166978 packets/sec
     4107045197 packets input, 505476588 bytes, 548 no buffer
     Received 2945851126 broadcasts, 0 runts, 0 giants, 1302284 throttles
     17315273 input errors, 0 CRC, 0 frame, 4 overrun, 17315318 ignored
     0 watchdog, 0 multicast, 0 pause input
     166207581 packets output, 3186496579 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 17320724 pause output
Serial0/1/0 is administratively down, line protocol is down
  Hardware is GT96K Serial
  MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Last input never, output never, output hang never
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 carrier transitions
     DCD=down  DSR=down  DTR=down  RTS=down  CTS=down
Loopback0 is up, line protocol is up
  Hardware is Loopback
  MTU 1514 bytes, BW 8000000 Kbit, DLY 5000 usec,
  Encapsulation LOOPBACK, loopback not set
  Output queue: 0/0 (size/max)
Loopback1 is up, line protocol is up
  Internet address is 202.87.34.68/32
Loopback2 is up, line protocol is up
  Internet address is 202.87.34.70/32
Loopback3 is up, line protocol is up
  Internet address is 202.87.34.71/32
Loopback4 is up, line protocol is up
  Internet address is 202.87.34.72/32
Loopback5 is up, line protocol is up
  Internet address is 202.87.34.73/32
Loopback6 is up, line protocol is up
  Internet address is 202.87.34.74/32
Tunnel0 is up, line protocol is up
  Hardware is Tunnel
  Description: ***GRE Tunnel to WebWorks DC***
  Internet address is 10.10.101.17/30
  MTU 1514 bytes, BW 9 Kbit, DLY 500000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 202.87.34.71, destination 180.149.240.17
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255
  Fast tunneling enabled
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input never, output 00:00:03, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 93
     56224797 packets output, 270919466 bytes, 0 underruns
Tunnel1 is up, line protocol is up
  Hardware is Tunnel
  Description: ***NMG BLORE GRE***
  Internet address is 10.10.100.1/30
  Keepalive not set
  Tunnel source 202.87.34.68, destination 180.179.234.74
  Tunnel TTL 255
  Last input 00:00:29, output 00:00:16, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 87
     145911062 packets input, 1927223343 bytes, 0 no buffer
     141413807 packets output, 4184759001 bytes, 0 underruns
Tunnel2 is administratively down, line protocol is down
  Hardware is Tunnel
  Description: ***NMG_Banglore_GRE***
  Internet address is 10.10.101.29/30
  Keepalive not set
  Tunnel source 202.87.34.74, destination 180.179.234.74
  Tunnel TTL 255
  Last input never, output 1y3w, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 33
     90973031 packets output, 1692808797 bytes, 0 underruns
Tunnel4 is administratively down, line protocol is down
  Hardware is Tunnel
  Description: ***Tunnel for UAT***
  Internet address is 10.10.101.21/30
  Keepalive not set
  Tunnel source 202.87.34.72, destination 180.179.100.178
  Tunnel TTL 255
  Last input 1y3w, output 1y2w, output hang never
     442272 packets output, 30702706 bytes, 0 underruns
Tunnel5 is administratively down, line protocol is down
  Hardware is Tunnel
  Description: ***NMG Chennai GRE***
  Internet address is 10.10.101.25/30
  Keepalive not set
  Tunnel source 202.87.34.73, destination 180.179.33.250
  Tunnel TTL 255
  Last input 1y0w, output 1y0w, output hang never
     924990 packets input, 67713388 bytes, 0 no buffer
     2378304 packets output, 441529376 bytes, 0 underruns
------------------ show controllers ------------------
Interface GigabitEthernet0/0
Hardware is MV96340
HWIDB: 42B631A0, INSTANCE: 42B64268, FASTSEND: 41553670, MCI_INDEX: 0
Aggregate MIB Counters
  Rx Good Bytes: 51991438011686        Rx Good Frames: 153012298
  Rx Bad Bytes: 0                      Rx Bad Frames: 0
  Rx Broadcast Frames: 12719           Rx Multicast Frames: 1843
  Tx Good Bytes: 17033674709710        Tx Good Frames: 299347638
  Tx Broadcast Frames: 172             Tx Multicast Frames: 766127
  Rx+Tx Min-64B Frames: 6591232        Rx+Tx 65-127B Frames: 135971929
  Rx+Tx 128-255B Frames: 108873983     Rx+Tx 256-511B Frames: 63855865
  Rx+Tx 512-1023B Frames: 118668223    Rx+Tx 1024-MaxB Frames: 18398704
  Rx Unrecog MAC Ctrl Frames: 0
  Rx Good FC Frames: 12                Rx Bad FC Frames: 0
  Rx Undersize Frames: 0               Rx Fragment Frames: 0
  Rx Oversize Frames: 0                Rx Jabber Frames: 0
  Rx MAC Errors: 0                     Rx Bad CRCs: 0
  Tx Collisions: 0                     Tx Late Collisions: 0
PHY Registers
  Register 0x00:   1000  796D  0020  60E1  05E1  C5E1  000F  2001
  Register 0x08:   4CAD  0200  3C00  xxxx  xxxx  xxxx  xxxx  3000
  Register 0x10:   0000  0323  0000  00FF  1832  xxxx  xxxx  xxxx
  Register 0x18:   4400  FF1F  247E  FFFF  205E  24B8  0000  0000
  PHY Control (0x00):
  AUTONEG_EN
  PHY Status (0x01):
  AUTONEG_DONE LINK_UP
  Auto-Negotiation Advertisement (0x04):
  PAUSE 100FD 100HD 10FD 10HD
  Link Partner Ability (0x05):
  1000BASE-T Control (0x09):
  M/S_AUTO DTE 1000FD
  1000BASE-T Status (0x0A):
  M/S_CFG_OK SLAVE LOCAL_RX_OK REMOTE_RX_OK 1000FD 1000HD
Serial Management Interface Registers (0xB4002000)
  PHYAR    = 0x00002841    SMIR     = 0x0FE10000
  EUDAR    = 0x00000000    EUDIDR   = 0x000000E0    EUICR    = 0x00000010
  EUIMR    = 0x00000000    EUEAR    = 0x00000000    EUIAER   = 0x00000000
  BAR0     = 0x00000E00    SR0      = 0x0FFF0000
  BAR1     = 0x00000000    SR1      = 0x00000000
  BAR2     = 0x00000000    SR2      = 0x00000000
  BAR3     = 0x00000000    SR3      = 0x00000000
  BAR4     = 0x00000000    SR4      = 0x00000000
  BAR5     = 0x00000000    SR5      = 0x00000000
  HARR0    = 0x00000000    HARR1    = 0x00000000
  HARR2    = 0x00000000    HARR3    = 0x00000000
  BARER    = 0x0000003E    EPAPR0   = 0x00000003    EPAPR1   = 0x00000003
Port Control Registers (0xB4002400)
  PCR      = 0x00000000    PCER     = 0x00000000    MII      = 0x00218823
  GMII     = 0x00000006    VLANET   = 0x00008100    MACLO    = 0x00005550
  MACHI    = 0x00070E1F    SDCR     = 0x01000009    DSCP0    = 0x00000000
  DSCP1    = 0x00000000    DSCP2    = 0x00000000    DSCP3    = 0x00000000
  DSCP4    = 0x00000000    DSCP5    = 0x00000000    DSCP6    = 0x00000000
  PSCR     = 0x004A060B    VPT2P    = 0x00000000    PSR      = 0x0000041E
  TQCR     = 0x0000FE00    TQFPC    = 0x000000FF    PTTBRC   = 0x000003FF
  MTU      = 0x00000006    PMTBS    = 0x0000FFFF    ICR      = 0x00000000
  ICER     = 0x00000000    IMR      = 0xF807FFFF    IMER     = 0xFFFFFFFF
  PRFUTR   = 0x00000008    PTFUTR   = 0x00000000    PMFSR    = 0x00000040
  PDFC     = 0x00000000    POFC     = 0x00000000    EUIAER   = 0x00000000
  CRDP0    = 0x0F7A9D90    CRDP1    = 0x00000000    CRDP2    = 0x00000000
  CRDP3    = 0x00000000    CRDP4    = 0x00000000    CRDP5    = 0x00000000
  CRDP6    = 0x00000000    CRDP7    = 0x00000000    RQCR     = 0x0003FE01
  TCSDP    = 0x0F7AA4D0    TCQDP0   = 0x0F7AA4D0    TCQDP1   = 0x00000000
  TCQDP2   = 0x00000000    TCQDP3   = 0x00000000    TCQDP4   = 0x00000000
  TCQDP5   = 0x00000000    TCQDP6   = 0x00000000    TCQDP7   = 0x00000000
  TQTBCTR0 = 0x3FFFC8FA    TQTBCFG0 = 0x03FFFFFF    TQARCFG0 = 0x00000006
  TQTBCTR1 = 0x279FB1C7    TQTBCFG1 = 0x03FFFFFF    TQARCFG1 = 0x00000006
  TQTBCTR2 = 0x3C3FE6A8    TQTBCFG2 = 0x03FFFFFF    TQARCFG2 = 0x00000006
  TQTBCTR3 = 0x3BA9514F    TQTBCFG3 = 0x03FFFFFF    TQARCFG3 = 0x00000006
  TQTBCTR4 = 0x2E7F3EFE    TQTBCFG4 = 0x03FFFFFF    TQARCFG4 = 0x00000006
  TQTBCTR5 = 0x3C27D369    TQTBCFG5 = 0x03FFFFFF    TQARCFG5 = 0x00000006
  TQTBCTR6 = 0x379FBFEE    TQTBCFG6 = 0x03FFFFFF    TQARCFG6 = 0x00000006
  TQTBCTR7 = 0x13F84F78    TQTBCFG7 = 0x03FFFFFF    TQARCFG7 = 0x00000006
  PTTBC    = 0x3FFFFBF1
Hardware MAC Address Filters
  Unicast Filter
  [00-03]  = 0x00000001 0x00000000 0x00000000 0x00000000
  Special Multicast Filter
  [00-03]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [04-07]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [08-11]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [12-15]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [16-19]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [20-23]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [24-27]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [28-31]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [32-35]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [36-39]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [40-43]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [44-47]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [48-51]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [52-55]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [56-59]  = 0x00000000 0x00000000 0x00000000 0x00000000
  [60-63]  = 0x00000000 0x00000000 0x00000000 0x00000000
  Other Multicast Filter
  [48-51]  = 0x00000000 0x00000000 0x00000000 0x00000100
Software MAC Address Filter (hash:length/addr/mask/hits)
  0x000:  0  ffff.ffff.ffff  0000.0000.0000     12719
  0x05E:  0  0007.0e1f.5550  0000.0000.0000         0
  0x0C0:  0  0100.0ccc.cccc  0000.0000.0000        33
  Software filtered frames: 0
  Unicast overflow mode: 0
  Multicast overflow mode: 1
  Promiscuous mode: 0
Rx Rings
  Rx Ring 0                         Rx Ring 1
  - size        = 64               - size        = 0
  - head        = 31               - head        = 0
  - shadow      = 0x42B64734        - shadow      = 0x00000000
  - ring        = 0x0F7A9BA0        - ring        = 0x00000000
  - ring_malloc = 0x3F7A9BA0        - ring_malloc = 0x00000000
  Rx Ring 2                         Rx Ring 3
  - size        = 0                - size        = 0
  - head        = 0                - head        = 0
  - shadow      = 0x00000000        - shadow      = 0x00000000
  - ring        = 0x00000000        - ring        = 0x00000000
  - ring_malloc = 0x00000000        - ring_malloc = 0x00000000
  Rx Ring 4                         Rx Ring 5
  Rx Ring 6                         Rx Ring 7
Tx Rings
  Tx Ring 0                         Tx Ring 1
  - size        = 128              - size        = 0
  - head        = 79               - head        = 0
  - tail        = 79               - tail        = 0
  - usedtxds    = 0                - usedtxds    = 0
  - framecnt    = 0                - framecnt    = 0
  - shadow      = 0x42B64868        - shadow      = 0x00000000
  - ring        = 0x0F7A9FE0        - ring        = 0x00000000
  - ring_malloc = 0x3F7A9FE0        - ring_malloc = 0x00000000
  - tx_stopped  = 2097             - tx_stopped  = 0
  Tx Ring 2                         Tx Ring 3
  - tail        = 0                - tail        = 0
  - tx_stopped  = 0                - tx_stopped  = 0
  Tx Ring 4                         Tx Ring 5
  Tx Ring 6                         Tx Ring 7
Port Stopped: N
Interface GigabitEthernet0/1
Hardware is MV96340
HWIDB: 42B68F50, INSTANCE: 42B6A018, FASTSEND: 41553670, MCI_INDEX: 0
  Rx Good Bytes: 31829826661294451     Rx Good Frames: 3149413021
  Rx Broadcast Frames: 1286108665      Rx Multicast Frames: 3034535515
  Tx Good Bytes: 20989188208558        Tx Good Frames: 166207648
  Tx Broadcast Frames: 2153553         Tx Multicast Frames: 2722914
  Rx+Tx Min-64B Frames: 1572769478     Rx+Tx 65-127B Frames: 1519902984
  Rx+Tx 128-255B Frames: 2608000225    Rx+Tx 256-511B Frames: 2326784417
  Rx+Tx 512-1023B Frames: 2854965113   Rx+Tx 1024-MaxB Frames: 1023133045
  Rx Good FC Frames: 0                 Rx Bad FC Frames: 0
PHY Registers
  Register 0x00:   1000  796D  0020  60E1  05E1  D101  000F  2001
  Register 0x08:   4800  0200  3800  xxxx  xxxx  xxxx  xxxx  3000
  Register 0x10:   0000  0321  0000  00FF  0507  xxxx  xxxx  xxxx
  Register 0x18:   4400  FF1C  243E  FFFF  205E  244C  0000  0000
  PHY Control (0x00):
  AUTONEG_EN
  PHY Status (0x01):
  100FD
  M/S_AUTO DTE 1000FD
  PHYAR    = 0x00002841    SMIR     = 0x0FE20000
Port Control Registers (0xB4002800)
  GMII     = 0x00000006    VLANET   = 0x00008100    MACLO    = 0x00005551
  PSCR     = 0x004A062B    VPT2P    = 0x00000000    PSR      = 0x0000041E
  MTU      = 0x00000006    PMTBS    = 0x0000FFFF    ICR      = 0x00000C05
  ICER     = 0x00000000    IMR      = 0x00000000    IMER     = 0x00000000
  PDFC     = 0x1399C44E    POFC     = 0x00000002    EUIAER   = 0x00000000
  CRDP0    = 0x0F7F7190    CRDP1    = 0x00000000    CRDP2    = 0x00000000
  CRDP6    = 0x00000000    CRDP7    = 0x00000000    RQCR     = 0x0002FE01
  TCSDP    = 0x0F7F77E0    TCQDP0   = 0x0F7F77E0    TCQDP1   = 0x00000000
  TQTBCTR0 = 0x3FE1FF55    TQTBCFG0 = 0x03FFFFFF    TQARCFG0 = 0x00000006
  TQTBCTR1 = 0x3FD4023D    TQTBCFG1 = 0x03FFFFFF    TQARCFG1 = 0x00000006
  TQTBCTR2 = 0x0F96ACF7    TQTBCFG2 = 0x03FFFFFF    TQARCFG2 = 0x00000006
  TQTBCTR3 = 0x3320DC7E    TQTBCFG3 = 0x03FFFFFF    TQARCFG3 = 0x00000006
  TQTBCTR4 = 0x3EBDE8FE    TQTBCFG4 = 0x03FFFFFF    TQARCFG4 = 0x00000006
  TQTBCTR5 = 0x0BEDFAE6    TQTBCFG5 = 0x03FFFFFF    TQARCFG5 = 0x00000006
  TQTBCTR6 = 0x3B3E29FC    TQTBCFG6 = 0x03FFFFFF    TQARCFG6 = 0x00000006
  TQTBCTR7 = 0x0EFD87CF    TQTBCFG7 = 0x03FFFFFF    TQARCFG7 = 0x00000006
  PTTBC    = 0x3FFFDBF9
  Unicast Filter
  [00-03]  = 0x00000100 0x00000000 0x00000000 0x00000000
  [00-03]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [04-07]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [08-11]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [12-15]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [16-19]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [20-23]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [24-27]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [28-31]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [32-35]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [36-39]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [40-43]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [44-47]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [48-51]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [52-55]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [56-59]  = 0x01010101 0x01010101 0x01010101 0x01010101
  [60-63]  = 0x01010101 0x01010101 0x01010101 0x01010101
  0x000:  0  ffff.ffff.ffff  0000.0000.0000    367124
  0x05F:  0  0007.0e1f.5551  0000.0000.0000         0
  0x0C0:  0  0100.0ccc.cccc  0000.0000.0000       196
  0x100:  0  0100.5e7f.ffff  0000.007f.ffff -2072334924
  Software filtered frames: 32989041
  Promiscuous mode: 0
Rx Rings
  Rx Ring 0                         Rx Ring 1
  - head        = 19               - head        = 0
  - shadow      = 0x42B6A498        - shadow      = 0x00000000
  - ring        = 0x0F7F7060        - ring        = 0x00000000
  - ring_malloc = 0x3F7F7060        - ring_malloc = 0x00000000
  Rx Ring 2                         Rx Ring 3
  Rx Ring 4                         Rx Ring 5
  Rx Ring 6                         Rx Ring 7
Tx Rings
  Tx Ring 0                         Tx Ring 1
  - head        = 41               - head        = 0
  - tail        = 41               - tail        = 0
  - shadow      = 0x42B6A5CC        - shadow      = 0x00000000
  - ring        = 0x0F7F74A0        - ring        = 0x00000000
  - ring_malloc = 0x3F7F74A0        - ring_malloc = 0x00000000
  - tx_stopped  = 129              - tx_stopped  = 0
  Tx Ring 2                         Tx Ring 3
  Tx Ring 4                         Tx Ring 5
  Tx Ring 6                         Tx Ring 7
Port Stopped: N
Interface Serial0/1/0
Hardware is GT96K
No serial cable attached
idb at 0x42B76C48, driver data structure at 0x42B7E36C
wic_info 0x42B7E968
Physical Port 3, SCC Num 3
MPSC Registers:
MMCR_L=0x00030400, MMCR_H=0x00000000, MPCR=0x00000100
CHR1=0x00FE007E, CHR2=0x80000000, CHR3=0x0000064A, CHR4=0x00000000
CHR5=0x00000000, CHR6=0x00000000, CHR7=0x00000000, CHR8=0x00000000
CHR9=0x00000000, CHR10=0x00000003
SDMA Registers:
SDC=0x00002201, SDCM=0x00000000
CRDP=0x0F844520, CTDP=0x0F846040, FTDB=0x0F846040
Main Routing Register=0x77770777 BRG Conf Register=0x00490018
Rx Clk Routing Register=0x00008000 Tx Clk Routing Register=0x00003000
GPP Registers:
Conf=0x53055600, Io=0x53055600, Data=0xFFFFFFFF, Level=0x00000000
TDM FPGA Registers:
vmcr[0] = 0x00000000, vmcr[1] = 0x00010080,
vmcr[2] = 0x00000000, vmcr[3] = 0x00000000
ntrcr0 = 0x00000000, ntrcr1 = 0x00000000
tdmcr = 0x0000006A, labcr = 0x00000000, tpllr_cr = 0x00000000
nhr = 0x66666766, isr = 0x00000000, imr = 0x00000000
0 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
0 transmitter CTS losts
0 rxintr, 0 txintr, 0 rxerr, 0 txerr
0 mpsc_rx, 0 mpsc_rxerr, 0 mpsc_rlsc, 0 mpsc_rhnt, 0 mpsc_rfsc
0 mpsc_rcsc, 0 mpsc_rovr, 0 mpsc_rcdl, 0 mpsc_rckg, 0 mpsc_bper
0 mpsc_txerr, 0 mpsc_teidl, 0 mpsc_tudr, 0 mpsc_tctsl, 0 mpsc_tckg
0 sdma_rx_sf, 0 sdma_rx_mfl, 0 sdma_rx_or, 0 sdma_rx_abr, 0 sdma_rx_no
0 sdma_rx_de, 0 sdma_rx_cdl, 0 sdma_rx_ce, 0 sdma_tx_rl, 0 sdma_tx_ur, 0 sdma_tx_ctsl
0 sdma_rx_reserr, 0 sdma_tx_reserr
0 rx_bogus_pkts, rx_bogus_flag FALSE
0 sdma_tx_ur_processed
tx_limited = 1(2), errata19 count1 - 0, count2 - 0
Receive Ring
rxr head (0)(0x0F844520), rxr tail (0)(0x0F844520)
  rmd(F844520): nbd F844530 cmd_sts 80800000 buf_sz 06000000 buf_ptr F8468E0
  rmd(F844530): nbd F844540 cmd_sts 80800000 buf_sz 06000000 buf_ptr F846F40
  rmd(F844540): nbd F844550 cmd_sts 80800000 buf_sz 06000000 buf_ptr F8475A0
  rmd(F844550): nbd F844560 cmd_sts 80800000 buf_sz 06000000 buf_ptr F847C00
  rmd(F844560): nbd F844570 cmd_sts 80800000 buf_sz 06000000 buf_ptr F848260
  rmd(F844570): nbd F844580 cmd_sts 80800000 buf_sz 06000000 buf_ptr F8488C0
  rmd(F844580): nbd F844590 cmd_sts 80800000 buf_sz 06000000 buf_ptr F848F20
  rmd(F844590): nbd F8445A0 cmd_sts 80800000 buf_sz 06000000 buf_ptr F849580
  rmd(F8445A0): nbd F8445B0 cmd_sts 80800000 buf_sz 06000000 buf_ptr F849BE0
  rmd(F8445B0): nbd F8445C0 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84A240
  rmd(F8445C0): nbd F8445D0 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84A8A0
  rmd(F8445D0): nbd F8445E0 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84AF00
  rmd(F8445E0): nbd F8445F0 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84B560
  rmd(F8445F0): nbd F844600 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84BBC0
  rmd(F844600): nbd F844610 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84C220
  rmd(F844610): nbd F844620 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84C880
  rmd(F844620): nbd F844630 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84CEE0
  rmd(F844630): nbd F844640 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84D540
  rmd(F844640): nbd F844650 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84DBA0
  rmd(F844650): nbd F844660 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84E200
  rmd(F844660): nbd F844670 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84E860
  rmd(F844670): nbd F844680 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84EEC0
  rmd(F844680): nbd F844690 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84F520
  rmd(F844690): nbd F8446A0 cmd_sts 80800000 buf_sz 06000000 buf_ptr F84FB80
  rmd(F8446A0): nbd F8446B0 cmd_sts 80800000 buf_sz 06000000 buf_ptr F8501E0
  rmd(F8446B0): nbd F8446C0 cmd_sts 80800000 buf_sz 06000000 buf_ptr F850840
  rmd(F8446C0): nbd F8446D0 cmd_sts 80800000 buf_sz 06000000 buf_ptr F850EA0
  rmd(F8446D0): nbd F8446E0 cmd_sts 80800000 buf_sz 06000000 buf_ptr F851500
  rmd(F8446E0): nbd F8446F0 cmd_sts 80800000 buf_sz 06000000 buf_ptr F851B60
  rmd(F8446F0): nbd F844700 cmd_sts 80800000 buf_sz 06000000 buf_ptr F8521C0
  rmd(F844700): nbd F844710 cmd_sts 80800000 buf_sz 06000000 buf_ptr F852820
  rmd(F844710): nbd F844520 cmd_sts 80800000 buf_sz 06000000 buf_ptr F852E80
Transmit Ring
txr head (0)(0x0F846040), txr tail (0)(0x0F846040)
  tmd(F846040): nbd F846050 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846050): nbd F846060 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846060): nbd F846070 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846070): nbd F846080 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846080): nbd F846090 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846090): nbd F8460A0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8460A0): nbd F8460B0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8460B0): nbd F8460C0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8460C0): nbd F8460D0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8460D0): nbd F8460E0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8460E0): nbd F8460F0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8460F0): nbd F846100 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846100): nbd F846110 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846110): nbd F846120 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846120): nbd F846130 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846130): nbd F846140 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846140): nbd F846150 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846150): nbd F846160 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846160): nbd F846170 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846170): nbd F846180 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846180): nbd F846190 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846190): nbd F8461A0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8461A0): nbd F8461B0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8461B0): nbd F8461C0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8461C0): nbd F8461D0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8461D0): nbd F8461E0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8461E0): nbd F8461F0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8461F0): nbd F846200 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846200): nbd F846210 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846210): nbd F846220 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846220): nbd F846230 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846230): nbd F846240 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846240): nbd F846250 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846250): nbd F846260 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846260): nbd F846270 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846270): nbd F846280 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846280): nbd F846290 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846290): nbd F8462A0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8462A0): nbd F8462B0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8462B0): nbd F8462C0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8462C0): nbd F8462D0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8462D0): nbd F8462E0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8462E0): nbd F8462F0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8462F0): nbd F846300 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846300): nbd F846310 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846310): nbd F846320 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846320): nbd F846330 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846330): nbd F846340 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846340): nbd F846350 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846350): nbd F846360 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846360): nbd F846370 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846370): nbd F846380 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846380): nbd F846390 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846390): nbd F8463A0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8463A0): nbd F8463B0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8463B0): nbd F8463C0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8463C0): nbd F8463D0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8463D0): nbd F8463E0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8463E0): nbd F8463F0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8463F0): nbd F846400 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846400): nbd F846410 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846410): nbd F846420 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846420): nbd F846430 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846430): nbd F846440 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846440): nbd F846450 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846450): nbd F846460 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846460): nbd F846470 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846470): nbd F846480 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846480): nbd F846490 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846490): nbd F8464A0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8464A0): nbd F8464B0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8464B0): nbd F8464C0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8464C0): nbd F8464D0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8464D0): nbd F8464E0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8464E0): nbd F8464F0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8464F0): nbd F846500 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846500): nbd F846510 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846510): nbd F846520 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846520): nbd F846530 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846530): nbd F846540 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846540): nbd F846550 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846550): nbd F846560 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846560): nbd F846570 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846570): nbd F846580 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846580): nbd F846590 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846590): nbd F8465A0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8465A0): nbd F8465B0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8465B0): nbd F8465C0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8465C0): nbd F8465D0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8465D0): nbd F8465E0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8465E0): nbd F8465F0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8465F0): nbd F846600 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846600): nbd F846610 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846610): nbd F846620 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846620): nbd F846630 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846630): nbd F846640 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846640): nbd F846650 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846650): nbd F846660 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846660): nbd F846670 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846670): nbd F846680 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846680): nbd F846690 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846690): nbd F8466A0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8466A0): nbd F8466B0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8466B0): nbd F8466C0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8466C0): nbd F8466D0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8466D0): nbd F8466E0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8466E0): nbd F8466F0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8466F0): nbd F846700 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846700): nbd F846710 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846710): nbd F846720 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846720): nbd F846730 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846730): nbd F846740 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846740): nbd F846750 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846750): nbd F846760 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846760): nbd F846770 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846770): nbd F846780 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846780): nbd F846790 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846790): nbd F8467A0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8467A0): nbd F8467B0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8467B0): nbd F8467C0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8467C0): nbd F8467D0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8467D0): nbd F8467E0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8467E0): nbd F8467F0 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F8467F0): nbd F846800 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846800): nbd F846810 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846810): nbd F846820 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846820): nbd F846830 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
  tmd(F846830): nbd F846040 cmd_sts 00C30000 byt_cnt ABCDABCD buf_ptr 0
buffer size 1524
------------------ show user ------------------
    Line       User       Host(s)              Idle       Location
*323 vty 1     rsadmin    idle                 00:00:27 172.24.41.40
  Interface    User               Mode         Idle     Peer Address
------------------ show file systems ------------------
File Systems:
     Size(b)     Free(b)      Type  Flags  Prefixes
           -           -    opaque     rw   archive:
           -           -    opaque     rw   system:
           -           -    opaque     rw   null:
           -           -   network     rw   tftp:
*   64016384    35733504      disk     rw   flash:#
      245752      228138     nvram     rw   nvram:
           -           -    opaque     rw   xmodem:
           -           -    opaque     rw   ymodem:
           -           -   network     rw   rcp:
           -           -   network     rw   ftp:
           -           -   network     rw   http:
           -           -   network     rw   scp:
           -           -   network     rw   https:
           -           -    opaque     ro   cns:
------------------ show flash: all ------------------
-#- --length-- -----date/time------ path
1     17970504 Jul 19 2007 01:24:30 +05:30 c2800nm-ipbasek9-mz.124-10b.bin
2         1826 Jul 19 2007 01:33:08 +05:30 sdmconfig-28xx.cfg
3      6036480 Jul 19 2007 01:33:32 +05:30 sdm.tar
4       861696 Jul 19 2007 01:33:48 +05:30 es.tar
5      1164288 Jul 19 2007 01:34:04 +05:30 common.tar
6         1038 Jul 19 2007 01:34:20 +05:30 home.shtml
7       113152 Jul 19 2007 01:34:34 +05:30 home.tar
8      1697952 Jul 19 2007 01:34:54 +05:30 securedesktop-ios-3.1.1.45-k9.pkg
9       416354 Jul 19 2007 01:35:10 +05:30 sslclient-win-1.1.3.173.pkg
35733504 bytes available (28282880 bytes used)
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
   Number of Heads:       8
   Number of Cylinders    490
   Sectors per Cylinder   32
   Sector Size            512
   Total Sectors          125440
ATA CARD FORMAT
   Number of FAT Sectors  62
   Sectors Per Cluster    8
   Number of Clusters     15629
   Number of Data Sectors 125301
   Base Root Sector       231
   Base FAT Sector        107
   Base Data Sector       263
ATA MONLIB INFO
   Image Monlib size = 61240
   Disk monlib size = 54784
   Name = piptom-atafslib-m
   Monlib Start sector = 2
   Monlib End sector = 100
   Monlib updated by = C2800NM-IPBASE-M12.3(8)T8
   Monlib version = 1
------------------ dir nvram: ------------------
Directory of nvram:/
  224  -rw-       13964                    <no date>  startup-config
  225  ----        1550                    <no date>  private-config
  226  -rw-       13964                    <no date>  underlying-config
    1  -rw-         455                    <no date>  ifIndex-table
    2  ----          12                    <no date>  persistent-data
245752 bytes total (228138 bytes free)
------------------ show memory statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   425B9740   218392768    11604492   206788276   205046884   204918472
      I/O   3F600000    10485760     2759820     7725940     7682160     7716924
------------------ show process memory ------------------
Processor Pool Total:  218392768 Used:   11603696 Free:  206789072
      I/O Pool Total:   10485760 Used:    2759696 Free:    7726064
 PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0   20317476    5620888   11348016        581  933727334 *Init*
   0   0     133200  308675244     133200          0          0 *Sched*
   0   0  856214056  894527720     739196      25245      25236 *Dead*
   1   0     119924     109872      17024          0          0 Chunk Manager
   2   0        196        196       3972          0          0 Load Meter
   4   0       3304        196      10080          0          0 Check heaps
   5   0  400314876  359154528     308108         45          0 Pool Manager
   6   0        196        196       6972          0          0 Timers
   7   0          0          0       6972          0          0 IPC Dynamic Cach
   8   0          0          0       6972          0          0 IPC Zone Manager
   9   0          0          0       6972          0          0 IPC Periodic Tim
  10   0          0          0       6972          0          0 IPC Deferred Por
  11   0        744          0       7716          0          0 IPC Seat Manager
  12   0          0          0       6972          0          0 IPC BackPressure
  13   0          0          0      12972          0          0 OIR Handler
  14   0          0          0      24972          0          0 Crash writer
  15   0        196        196       6972          0          0 Environmental mo
  16   0       8376   41431420       7188 1271800909 1271800801 ARP Input
  17   0        196        196       6972          0          0 ATM Idle Timer
  18   0        196        196       6972          0          0 AAA high-capacit
  19   0          0          0       6972          0          0 AAA_SERVER_DEADT
  20   0          0          0      12972          0          0 Policy Manager
  21   0        196        196       6972          0          0 DDR Timers
  22   0       3660          0      10632         24         24 Entity MIB API
  23   0          0          0       6972          0          0 HC Counter Timer
  24   0        196        196       6972          0          0 Serial Backgroun
  25   0          0          0       6972          0          0 RO Notify Timers
  26   0        196        196       6972          0          0 SMART
  27   0        196        196       6972          0          0 GraphIt
  28   0        196        196      12972          0          0 Dialer event
  29   0          0          0       6972          0          0 SERIAL A'detect
  30   0        196        196      12972          0          0 XML Proxy Client
  31 323    2175496    2145952      42260        492        483 SSH Process
  32   0          0          0       3972          0          0 Inode Table Dest
  33   0          0          0       6972          0          0 Critical Bkgnd
  34   0     277596       7524     106236    8359541    8359541 Net Background
  35   0        868        608      13232          0          0 IDB Work
  36   0        196        196      12972        638        638 Logger
  37   0        196       5484       6972          0          0 TTY Background
  38   0          0          0       9972    3807889    3807888 Per-Second Jobs
  39   0        196        196       6972          0          0 c2800 Periodic
  40   0          0          0       6972          0          0 AggMgr Process
  41   0          0          0       6972          0          0 Token Daemon
  42   0          0          0       3972          0          0 dev_device_inser
  43   0          0          0       3972          0          0 dev_device_remov
  44   0          0          0      12972          0          0 sal_dpc_process
  45   0          0          0       6972          0          0 ARL Table Manage
  46   0        196        196       6972          0          0 ESWPPM
  47   0        196        196       3972          0          0 Eswilp Storm Con
  48   0        196        196       6972          0          0 ESWILPPM
  49   0        196        196       3972          0          0 Eswilp Storm Con
  50   0        196        196       6972          0          0 Netclock Backgro
  51   0        196        196       6972          0          0 SM Monitor
  53   0        196        196       6972          0          0 Ether-Switch RBC
  54   0          0          0       3972          0          0 IGMP Snooping Pr
  55   0          0          0       3972          0          0 IGMP Snooping Re
  56   0        196        196       6972          0          0 Call Management
  57   0        196        196       6972          0          0 dot1x
  58   0       2444        196       9220          0          0 DTP Protocol
  59   0        196        196       6972          0          0 PI MATM Aging Pr
  60   0        196        196       6972          0          0 EtherChnl
  61   0        196        196       6972          0          0 AAA Dictionary R
  62   0        196        196       6972          0          0 AAA Server
  63   0          0          0       6972          0          0 AAA ACCT Proc
  64   0          0          0       6972          0          0 ACCT Periodic Pr
  65   0       5416       4472       7916    2166357    2166357 CDP Protocol
  66   0  199356776   27889456      17784 1717313005 1717313568 IP Input
  67   0          0          0       6972          0          0 ICMP event handl
  68   0        196        196       6972          0          0 TurboACL
  69   0        196        196       6972          0          0 TurboACL chunk
  70   0        196        196       6972     139006     139006 MOP Protocols
  71   0        392        392      12972          0          0 PPP Hooks
  73   0          0          0      12972          0          0 SSS Manager
  74   0          0          0      12972          0          0 SSS Test Client
  75   0          0          0       6972          0          0 SSS Feature Mana
  76   0          0          0       6972          0          0 SSS Feature Time
  77   0          0          0      12972          0          0 VPDN call manage
  78   0          0          0      12972          0          0 L2X Socket proce
  79   0          0          0      12972          0          0 L2X SSS manager
  80   0       1396       1396      12972          6          6 L2TP mgmt daemon
  81   0          0          0       6972          0          0 X.25 Encaps Mana
  82   0      10484       9924      11120          0          0 IP Background
  83   0        164          0      10136          0          0 IP RIB Update
  84   0        196        196      12972          0          0 PPP IP Route
  85   0        196        196      12972          0          0 PPP IPCP
  86   0          0          0       6972          0          0 Socket Timers
  87   0          0      20468      12972       1023       1023 TCP Timer
  88   0  345357596          0      14516          0          0 TCP Protocols
  89   0          0          0      24972          0          0 COPS
  90   0      73300          0      73300          0          0 CEF process
  91   0        492        156       7464          0          0 L2MM
  92   0          0          0       6972          0          0 MRD
  93   0          0          0       6972          0          0 IGMPSN
  94   0          0          0       6972          0          0 SNMP Timers
  95   0      13816        196      20592          0          0 SCTP Main Proces
  96   0          0          0       6972          0          0 IUA Main Process
  97   0        196        196       6972          0          0 RUDPV1 Main Proc
  98   0          0          0       6972          0          0 bsm_timers
  99   0          0          0       6972          0          0 bsm_xmt_proc
 100   0     169424        196     168196          0          0 DHCPD Receive
 101   0        196        196       6972          0          0 Dialer Forwarder
 102   0          0          0       6972          0          0 IP Cache Ager
 103   0        196        196       9972          0          0 Adj Manager
 104   0        940          0      10912          0          0 HTTP CORE
 105   0          0          0       6972          0          0 IP Traceroute
 106   0       5052          0      12024     361377     361377 RARP Input
 107   0          0          0       6972          0          0 PAD InCall
 108   0        196        196      13024          0          0 X.25 Background
 109   0        196        196       6972          0          0 PPP Bind
 110   0        196        196       6972          0          0 PPP SSS
 111   0        196        196       6972          0          0 CRM_CALL_UPDATE_
 112   0        196        196       6972          0          0 ENABLE AAA
 113   0          0          0       6972          0          0 EM Background Pr
 114   0          0          0       6972          0          0 Key chain liveke
 115   0        196        196       6972          0          0 LINE AAA
 116   0     312660     692636       6972          0          0 LOCAL AAA
 117   0        956        196       7732          0          0 TPLUS
 118   0          0          0      12972          0          0 encrypt proc
 119   0          0          0       6972          0          0 crypto engine pr
 120   0       1372        596       9748          1          1 Crypto CA
 121   0          0          0       8972          0          0 Crypto PKI-CRL
 122   0          0          0       8972          0          0 Crypto SSL
 123   0          0          0       6972          0          0 PM Callback
 124   0        196        196       6972          0          0 AAA SEND STOP EV
 125   0        196        196       6972          0          0 RMON Recycle Pro
 126   0        196        196       6972          0          0 RMON Deferred Se
 127   0          0          0       6972          0          0 Syslog Traps
 128   0       9160       1508      14468          0          0 VLAN Manager
 129   0          0          0       7032          0          0 DHCPD Timer
 130   0      86244      83968      15248       2100       2100 Syslog
 131   0          0          0       6988          0          0 VPDN Scal
 132   0          0          0       6972    1752015    1752015 Net Input
 133   0        196        196       6972          0          0 Compute load avg
 134   0     134148          0       6972          0          0 Per-minute Jobs
 135   0        164          0       7136          0          0 CEF Scanner
 136   0        196          0      25168          0          0 tHUB
 137   0        392        196      13168          0          0 tENM
 138   0    1389336          0      77096          1          1 SSH Event handle
 139   0        196        196       6972          0          0 IP Flow Backgrou
 140   0    1269444     880516      14992   19052311   19052311 IGMP Input
 141   0  678307464  678151524       9220   13782966   13782966 PIM Process
 142   0        164  171084036       7136     209579     209579 Mwheel Process
 143   0 1693967920 1693964308      13864   15640678   15640678 IP SNMP
 144   0   33213684        800      12972          0          0 PDU DISPATCHER
 145   0 2857395536 2890611140      12972          0          0 SNMP ENGINE
 146   0          0          0      12972          0          0 SNMP ConfCopyPro
 147   0          0          0      12972          0          0 SNMP Traps
 148   0      51656      47620       7348    1048980    1048980 NTP
 149   0        196          0       7168          0          0 DHCPD Database
 150   0  409651448  410876700      93992       3468       3468 crypto sw pk pro
                                 14357572 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 99%/97%; one minute: 99%; five minutes: 99%
 PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1          20       115        173  0.00%  0.00%  0.00%   0 Chunk Manager
   2       89076   8359011         10  0.00%  0.00%  0.00%   0 Load Meter
   4    11956016   4274319       2797  0.00%  0.02%  0.00%   0 Check heaps
   5       44252     46682        947  0.00%  0.00%  0.00%   0 Pool Manager
   6           0         2          0  0.00%  0.00%  0.00%   0 Timers
   7          28    696585          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
   8           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
   9        8684  41794242          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  10        7688  41794239          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  11           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  12           0         1          0  0.00%  0.00%  0.00%   0 IPC BackPressure
  13           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
  14           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  15       15012   1393169         10  0.00%  0.00%  0.00%   0 Environmental mo
  16    73002352 959343422         76  0.16%  0.09%  0.08%   0 ARP Input
  17           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  18           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  19           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  20           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  21           0         2          0  0.00%  0.00%  0.00%   0 DDR Timers
  22           0         2          0  0.00%  0.00%  0.00%   0 Entity MIB API
  23       39376   8358971          4  0.00%  0.00%  0.00%   0 HC Counter Timer
  24           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  25           0         1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  26           0         2          0  0.00%  0.00%  0.00%   0 SMART
  27        8528  41794960          0  0.00%  0.00%  0.00%   0 GraphIt
  28           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  29           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  30           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  31       45348       646      70198  0.32%  0.84%  0.31% 323 SSH Process
  32           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  33           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  34      196212  17836757         11  0.00%  0.00%  0.00%   0 Net Background
  35           0         2          0  0.00%  0.00%  0.00%   0 IDB Work
  36         580       506       1146  0.00%  0.00%  0.00%   0 Logger
  37       13828  41794229          0  0.00%  0.00%  0.00%   0 TTY Background
  38       80140  41795183          1  0.00%  0.01%  0.00%   0 Per-Second Jobs
  39         228   2786336          0  0.00%  0.00%  0.00%   0 c2800 Periodic
  40           0         1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  41           0         1          0  0.00%  0.00%  0.00%   0 Token Daemon
  42           0         1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  43           0         1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  44           0         1          0  0.00%  0.00%  0.00%   0 sal_dpc_process
  45           0         1          0  0.00%  0.00%  0.00%   0 ARL Table Manage
  46           0         2          0  0.00%  0.00%  0.00%   0 ESWPPM
  47           0         2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  48           0         2          0  0.00%  0.00%  0.00%   0 ESWILPPM
  49           0         2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  50       13480 167178885          0  0.00%  0.00%  0.00%   0 Netclock Backgro
  51           0         2          0  0.00%  0.00%  0.00%   0 SM Monitor
  53        4816  41794234          0  0.00%  0.00%  0.00%   0 Ether-Switch RBC
  54           0         1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
  55           0         1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  56          68   1393169          0  0.00%  0.00%  0.00%   0 Call Management
  57           0         2          0  0.00%  0.00%  0.00%   0 dot1x
  58           0         2          0  0.00%  0.00%  0.00%   0 DTP Protocol
  59        6612  41794234          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  60         260   4179499          0  0.00%  0.00%  0.00%   0 EtherChnl
  61           4         2       2000  0.00%  0.00%  0.00%   0 AAA Dictionary R
  62         100      1184         84  0.00%  0.00%  0.00%   0 AAA Server
  63           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  64           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  65      138744   5993563         23  0.00%  0.00%  0.00%   0 CDP Protocol
  66   314274212-1868765727          0  0.08%  0.04%  0.02%   0 IP Input
  67           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  68           0        10          0  0.00%  0.00%  0.00%   0 TurboACL
  69           0         2          0  0.00%  0.00%  0.00%   0 TurboACL chunk
  70         116     69505          1  0.00%  0.00%  0.00%   0 MOP Protocols
  71           0         3          0  0.00%  0.00%  0.00%   0 PPP Hooks
  73           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
  74         624   5572669          0  0.00%  0.00%  0.00%   0 SSS Test Client
  75           0         1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
  76       19040 163260845          0  0.00%  0.00%  0.00%   0 SSS Feature Time
  77           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
  78           0         1          0  0.00%  0.00%  0.00%   0 L2X Socket proce
  79           0         1          0  0.00%  0.00%  0.00%   0 L2X SSS manager
  80           8        14        571  0.00%  0.00%  0.00%   0 L2TP mgmt daemon
  81           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
  82       15436   1329804         11  0.00%  0.00%  0.00%   0 IP Background
  83        1280    696722          1  0.00%  0.00%  0.00%   0 IP RIB Update
  84           0         2          0  0.00%  0.00%  0.00%   0 PPP IP Route
  85           0         2          0  0.00%  0.00%  0.00%   0 PPP IPCP
  86       78168  44278019          1  0.00%  0.00%  0.00%   0 Socket Timers
  87        2980     74167         40  0.00%  0.00%  0.00%   0 TCP Timer
  88       20624     46589        442  0.00%  0.00%  0.00%   0 TCP Protocols
  89           0         1          0  0.00%  0.00%  0.00%   0 COPS
  90       50612  48159526          1  0.00%  0.00%  0.00%   0 CEF process
  91           0         2          0  0.00%  0.00%  0.00%   0 L2MM
  92           0         1          0  0.00%  0.00%  0.00%   0 MRD
  93           0         1          0  0.00%  0.00%  0.00%   0 IGMPSN
  94           0         2          0  0.00%  0.00%  0.00%   0 SNMP Timers
  95           0         2          0  0.00%  0.00%  0.00%   0 SCTP Main Proces
  96           0         1          0  0.00%  0.00%  0.00%   0 IUA Main Process
  97       15948  41794274          0  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
  98           0         1          0  0.00%  0.00%  0.00%   0 bsm_timers
  99        5652  41794235          0  0.00%  0.00%  0.00%   0 bsm_xmt_proc
 100     2079008  88621215         23  0.08%  0.02%  0.00%   0 DHCPD Receive
 101           0         2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
 102         300    696512          0  0.00%  0.00%  0.00%   0 IP Cache Ager
 103        6904    696604          9  0.00%  0.00%  0.00%   0 Adj Manager
 104          12    139318          0  0.00%  0.00%  0.00%   0 HTTP CORE
 105           0         1          0  0.00%  0.00%  0.00%   0 IP Traceroute
 106        6208    153541         40  0.00%  0.00%  0.00%   0 RARP Input
 107           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
 108           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
 109           0         2          0  0.00%  0.00%  0.00%   0 PPP Bind
 110           0         2          0  0.00%  0.00%  0.00%   0 PPP SSS
 111         324   1671804          0  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
 112           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
 113           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
 114           0         1          0  0.00%  0.00%  0.00%   0 Key chain liveke
 115           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
 116        7956     38353        207  0.00%  0.00%  0.00%   0 LOCAL AAA
 117           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
 118           0         1          0  0.00%  0.00%  0.00%   0 encrypt proc
 119           0         1          0  0.00%  0.00%  0.00%   0 crypto engine pr
 120          36         4       9000  0.00%  0.00%  0.00%   0 Crypto CA
 121           0         1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
 122           0         1          0  0.00%  0.00%  0.00%   0 Crypto SSL
 123           0         1          0  0.00%  0.00%  0.00%   0 PM Callback
 124           4         2       2000  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
 125         276   4179499          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
 126           0         2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
 127           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
 128          12         2       6000  0.00%  0.00%  0.00%   0 VLAN Manager
 129         124    348293          0  0.00%  0.00%  0.00%   0 DHCPD Timer
 130        2276       254       8960  0.00%  0.00%  0.00%   0 Syslog
 131           0         1          0  0.00%  0.00%  0.00%   0 VPDN Scal
 132       55028   1539139         35  0.00%  0.00%  0.00%   0 Net Input
 133       76096   8359153          9  0.00%  0.00%  0.00%   0 Compute load avg
 134     6132264    709628       8641  0.00%  0.01%  0.00%   0 Per-minute Jobs
 135       28124   1449586         19  0.00%  0.00%  0.00%   0 CEF Scanner
 136           0         1          0  0.00%  0.00%  0.00%   0 tHUB
 137           0         2          0  0.00%  0.00%  0.00%   0 tENM
 138        1656     23219         71  0.00%  0.00%  0.00%   0 SSH Event handle
 139           0         2          0  0.00%  0.00%  0.00%   0 IP Flow Backgrou
 140     1854888  58075536         31  0.08%  0.03%  0.05%   0 IGMP Input
 141      506584  53001338          9  0.00%  0.02%  0.00%   0 PIM Process
 142       53508 417907775          0  0.00%  0.01%  0.00%   0 Mwheel Process
 143     1678668  15634238        107  0.00%  0.00%  0.00%   0 IP SNMP
 144      613504   7818377         78  0.00%  0.00%  0.00%   0 PDU DISPATCHER
 145     3822476   7818481        488  0.08%  0.01%  0.00%   0 SNMP ENGINE
 146           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
 147           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
 148       83644  42316918          1  0.00%  0.00%  0.00%   0 NTP
 149          52    696590          0  0.00%  0.00%  0.00%   0 DHCPD Database
 150     4405412     28005     157313  0.00%  0.00%  0.00%   0 crypto sw pk pro
------------------ show process cpu history ------------------
MH-NMVIKROLI-NMDC-RT-C2861-1.146   12:19:17 AM Sunday Jul 5 2020 IST
    999999999999999999999999999999999999999999999999999999999999
100 ************************************************************
 90 ************************************************************
 80 ************************************************************
 70 ************************************************************
 60 ************************************************************
 50 ************************************************************
 40 ************************************************************
 30 ************************************************************
 20 ************************************************************
 10 ************************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....6
             0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
    1                            1                             1
    099999999999999999999999999990999999999999999999999999999990
100 ############################################################
 90 ############################################################
 80 ############################################################
 70 ############################################################
 60 ############################################################
 50 ############################################################
 40 ############################################################
 30 ############################################################
 20 ############################################################
 10 ############################################################
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    11
    009 1 1        1  12 11 1       11  11    111          1  11 11     1 11
    009425279796856155007619184996663787419475105769876984808920904684761600
100 ###
 90 ###
 80 ###
 70 ###
 60 ###
 50 ###
 40 ###
 30 ###
 20 ###                * *           *          *
 10 ### ********************** ************ ************* *********** ******
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
------------------ show diag ------------------
Slot 0:
      C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
      Port adapter is analyzed
      Port adapter insertion time unknown
      EEPROM contents at hardware discovery:
      PCB Serial Number        : FOC11282KTJ
      Hardware Revision        : 1.0
      Top Assy. Part Number    : 800-26921-03
      Board Revision           : A0
      Deviation Number         : 0
      Fab Version              : 03
      RMA Test History         : 00
      RMA Number               : 0-0-0-0
      RMA History              : 00
      Processor type           : 87
      Hardware date code       : 20070714
      Chassis Serial Number    : FHK1129F29Y
      Chassis MAC Address      : 0007.0e1f.5550
      MAC Address block size   : 32
      CLEI Code                : COM7M00ARA
      Product (FRU) Number     : CISCO2821
      Part Number              : 73-8853-05
      Version Identifier       : V04
      EEPROM format version 4
      EEPROM contents (hex):
        0x00: 04 FF C1 8B 46 4F 43 31 31 32 38 32 4B 54 4A 40
        0x10: 03 E8 41 01 00 C0 46 03 20 00 69 29 03 42 41 30
        0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
        0x30: 09 87 83 01 32 41 3A C2 8B 46 48 4B 31 31 32 39
        0x40: 46 32 39 59 C3 06 00 07 0E 1F 55 50 43 00 20 C6
        0x50: 8A 43 4F 4D 37 4D 30 30 41 52 41 CB 8F 43 49 53
        0x60: 43 4F 32 38 32 31 20 20 20 20 20 20 82 49 22 95
        0x70: 05 89 56 30 34 20 D9 02 40 C1 FF FF FF FF FF FF
      WIC Slot 1:
      Serial 1T WAN daughter card
      Hardware revision 1.0               Board revision D0
      Serial number     35857142    Part number    800-01514-02
      FRU Part Number     WIC-1T=
      Test history      0x0               RMA number     00-00-00
      Connector type    Wan Module
      EEPROM format version 1
        0x20: 01 02 01 00 02 23 22 F6 50 05 EA 02 00 00 00 00
        0x30: 68 00 00 00 07 06 25 01 FF FF FF FF FF FF FF FF
------------------ show platform ------------------
 2821 Network IO Interrupt Throttling:
 throttle count=313199827, timer count=834134
 throttle counts= 313199827 0 0 0 0
 active=1, configured=1
 netint usec=20000, netint mask usec=1000
 real netint usec=4000, real netint mask usec=200
 IO Mask is 0
 Per Slot Intr Mask is 0
2821 Backplane EEPROM:
      Board Revision           : A0
      Fab Version              : 03
      RMA History              : 00
      Processor type           : 87
TLB entries :
Size  Virt Address range      Phy Address range       Attributes
 4M   0x40000000:0x407FFFFF   0x00000000:0x007FFFFF   CacheMode=3, RO, Valid
 4M   0x40800000:0x40FFFFFF   0x00800000:0x00FFFFFF   CacheMode=3, RO, Valid
 1M   0x41000000:0x411FFFFF   0x01000000:0x011FFFFF   CacheMode=3, RO, Valid
 1M   0x41200000:0x413FFFFF   0x01200000:0x013FFFFF   CacheMode=3, RO, Valid
 256K 0x41400000:0x4147FFFF   0x01400000:0x0147FFFF   CacheMode=3, RO, Valid
 256K 0x41480000:0x414FFFFF   0x01480000:0x014FFFFF   CacheMode=3, RO, Valid
 64K  0x41500000:0x4151FFFF   0x01500000:0x0151FFFF   CacheMode=3, RO, Valid
 64K  0x41520000:0x4153FFFF   0x01520000:0x0153FFFF   CacheMode=3, RO, Valid
 64K  0x41540000:0x4155FFFF   0x01540000:0x0155FFFF   CacheMode=3, RO, Valid
 64K  0x41560000:0x4157FFFF   0x01560000:0x0157FFFF   CacheMode=3, RW, Valid
 256K 0x41580000:0x415FFFFF   0x01580000:0x015FFFFF   CacheMode=3, RW, Valid
 1M   0x41600000:0x417FFFFF   0x01600000:0x017FFFFF   CacheMode=3, RW, Valid
 4M   0x41800000:0x41FFFFFF   0x01800000:0x01FFFFFF   CacheMode=3, RW, Valid
 16M  0x42000000:0x43FFFFFF   0x02000000:0x03FFFFFF   CacheMode=3, RW, Valid
 16M  0x44000000:0x45FFFFFF   0x04000000:0x05FFFFFF   CacheMode=3, RW, Valid
 16M  0x46000000:0x47FFFFFF   0x06000000:0x07FFFFFF   CacheMode=3, RW, Valid
 16M  0x48000000:0x49FFFFFF   0x08000000:0x09FFFFFF   CacheMode=3, RW, Valid
 16M  0x4A000000:0x4BFFFFFF   0x0A000000:0x0BFFFFFF   CacheMode=3, RW, Valid
 16M  0x4C000000:0x4DFFFFFF   0x0C000000:0x0DFFFFFF   CacheMode=3, RW, Valid
 16M  0x4E000000:0x4FFFFFFF   0x0E000000:0x0FFFFFFF   CacheMode=3, RW, Valid
 1M   0x0F600000:0x0F7FFFFF   0x0F600000:0x0F7FFFFF   CacheMode=2, RW, Valid
 4M   0x0F800000:0x0FFFFFFF   0x0F800000:0x0FFFFFFF   CacheMode=2, RW, Valid
 1M   0x3F600000:0x3F7FFFFF   0x0F600000:0x0F7FFFFF   CacheMode=0, RW, Valid
 4M   0x3F800000:0x3FFFFFFF   0x0F800000:0x0FFFFFFF   CacheMode=0, RW, Valid
Dimm 0 SPD data :
Size of dimm                 = 256 Megabytes
Memory Type                  = 0x7
Row Addresses                = 0xD
Column Address               = 0xA
Module Rows                  = 0x1
Data Width                   = 0x48
Voltage Interface            = 0x4
Cycle Time                   = 0x60
Access Time                  = 0x70
Configuration Type           = 0x2
Refresh Rate/Type            = 0x82
Primary Width                = 0x8
Error Width                  = 0x8
Minimum Clock Delay          = 0x1
Burst Lengths                = 0xE
Number of Banks              = 0x4
Cas Latencies                = 0xC
Write Latency                = 0x2
Module Attributes            = 0x20
General Attributes           = 0xC0
Min Cycle Time, CAS of 2     = 0x75
Access Clock Cycle, CAS of 2 = 0x70
Min Cycle Time, CAS of 1     = 0x0
Access Clock Cycle, CAS of 2 = 0x0
Row Precharge                = 0x48
Row Active to Row Active     = 0x30
RAS CAS Delay                = 0x48
Ras Pulse Width              = 0x2A
Row Density                  = 0x40
Vendor Id                    = 7F94FFFFFFFFFFFF
Module Part Number           = SG5723285D8D6CLSH2
Module Revision Code         = 00FF
      SPD contents (hex):
       0x00: 80 08 07 0D 0A 01 48 00 04 60 70 02 82 08 08 01
       0x10: 0E 04 0C 01 02 20 C0 75 70 00 00 48 30 48 2A 40
       0x20: 75 75 45 45 00 00 00 00 00 3C 48 30 2D 55 00 00
       0x30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12
       0x40: 7F 94 FF FF FF FF FF FF 04 53 47 35 37 32 33 32
       0x50: 38 35 44 38 44 36 43 4C 53 48 32 00 FF 06 39 78
       0x60: 72 04 35 53 4D 41 52 54 4D 6F 64 75 6C 61 72 54
       0x70: 65 63 68 6E 6F 6C 6F 67 69 65 73 FF FF FF FF FF
Dimm 1 SPD data :
Memory Slot Empty
 System RTC device                 = DS1337
------------------ show pci hardware ------------------
MV64340 External PCI Configuration registers:
PCI_0:
Vendor / Device ID   : 0xAB113496 (b/s 0x963411AB)
Status / Command     : 0x4601B002 (b/s 0x02B00146)
Class / Revision     : 0x03008005 (b/s 0x05800003)
Latency              : 0x07000000 (b/s 0x00000007)
CS[0] BAR(Low)       : 0x0C000000 (b/s 0x0000000C)
CS[0] BAR(High)      : 0x00000000 (b/s 0x00000000)
CS[1] BAR(Low)       : 0x0C008000 (b/s 0x0080000C)
CS[1] BAR(High)      : 0x00000000 (b/s 0x00000000)
CS[2] BAR(Low)       : 0x0C000001 (b/s 0x0100000C)
CS[2] BAR(High)      : 0x00000000 (b/s 0x00000000)
CS[3] BAR(Low)       : 0x0C008001 (b/s 0x0180000C)
CS[3] BAR(High)      : 0x00000000 (b/s 0x00000000)
PCI_1:
PCI Clocks Info:
PCI0         running at 50 MHz
PCI1         running at 50 MHz
PCI2 (AIM0)  running at 25 MHz
PCI3 (AIM1)  running at 25 MHz
PCI4 (Slot2) running at 25 MHz
PCI5 (Slot1) running at 25 MHz
------------------ show pci controller ------------------
MV64340 Channel 1 DMA (Packet coalescing DMA channel):
 dma_list=0x42B2FE70, dma_ring=0xF79DB20, dma_entries=256
 dma_free=0x42B307A8, dma_reqt=0x42B307A8, dma_done=0x42B307A8
 thread=0x42B30794, thread_end=0x42B30794
 backup_thread=0x0, backup_thread_end=0x42B31090
 dma_working=0, dma_stalls=0, dma_stall_loop=0
 dma_complete=2965017500, post_coalesce_frames=2965463926
 exhausted_dma_entries=0, post_dma_callback=2288662752
MV64340 Channel 0 DMA (Push Model DMA channel):
 dma_list=0x42B25D5C, dma_ring=0xF799AE0, dma_entries=1024
 dma_free=0x42B25D5C, dma_reqt=0x42B25D5C, dma_done=0x42B25D5C
 thread=0x0, thread_end=0x0
 backup_thread=0x0, backup_thread_end=0x0
 dma_complete=0, post_coalesce_frames=0
 exhausted_dma_entries=0, post_dma_callback=0
GT 0, Timer 0, Remap 0, ptr->func 0x40038CB8
GT 0, Timer 1, Remap 1, ptr->func 0x40224F64
GT 0, Timer 2, Remap 2, ptr->func 0x4022E4F8
GT 0, Timer 3, Remap 0, ptr->func 0x40038CB8
GT 1, Timer 0, Remap 0, ptr->func 0x40038CB8
GT 1, Timer 1, Remap 0, ptr->func 0x40038CB8
GT 1, Timer 2, Remap 0, ptr->func 0x40038CB8
GT 1, Timer 3, Remap 0, ptr->func 0x40038CB8
MV64340 Rev level     : 0
MV6430 Register Dump : Registers at 0xB4000000
CPU Interface :
 cpu_interface_conf             : 0x00200B00 (b/s 0x000B2000)
 multi_gt                       : 0x0B000000 (b/s 0x0000000B)
Processor Address Space :
 cs0_base                       : 0x00000000 (b/s 0x00000000)
 cs0_size                       : 0xFF0F0000 (b/s 0x00000FFF)
 cs1_base                       : 0x80000000 (b/s 0x00000080)
 cs1_size                       : 0x7F000000 (b/s 0x0000007F)
 cs2_base                       : 0x00010000 (b/s 0x00000100)
 cs2_size                       : 0x7F000000 (b/s 0x0000007F)
 cs3_base                       : 0x80010000 (b/s 0x00000180)
 devcs0_base                    : 0xA01F0000 (b/s 0x00001FA0)
 devcs0_size                    : 0x03000000 (b/s 0x00000003)
 devcs1_base                    : 0xA41F0000 (b/s 0x00001FA4)
 devcs1_size                    : 0x03000000 (b/s 0x00000003)
 devcs2_base                    : 0xA81F0000 (b/s 0x00001FA8)
 devcs2_size                    : 0x01000000 (b/s 0x00000001)
 devcs3_base                    : 0xB01F0000 (b/s 0x00001FB0)
 devcs3_size                    : 0x0F000000 (b/s 0x0000000F)
 bootcs_base                    : 0xC01F0000 (b/s 0x00001FC0)
 bootcs_size                    : 0x1F000000 (b/s 0x0000001F)
 pci0_mem0_base                 : 0x00100001 (b/s 0x01001000)
 pci0_mem0_size                 : 0xFF030000 (b/s 0x000003FF)
 pci1_mem0_base                 : 0x00180001 (b/s 0x01001800)
 pci1_mem0_size                 : 0xFF030000 (b/s 0x000003FF)
 internal_spc_decode            : 0x00140001 (b/s 0x01001400)
 base_addr_enable               : 0x0E7A0700 (b/s 0x00077A0E)
 netgx_decode.netgx_base_addr0  : 0x01EFC01F (b/s 0x1FC0EF01)
 netgx_decode.netgx_size0       : 0x00000100 (b/s 0x00010000)
 netgx_decode.netgx_base_addr1  : 0x000E0000 (b/s 0x00000E00)
 netgx_decode.netgx_size1       : 0x0000FF0F (b/s 0x0FFF0000)
SDRAM/Device Address Space :
 dram_config                    : 0x00032418 (b/s 0x18240300)
 dunit_cntrl_low                : 0x5104F103 (b/s 0x03F10451)
 sdram_timing_low               : 0x20124111 (b/s 0x11411220)
 sdram_timing_high              : 0x07000000 (b/s 0x00000007)
 sdram_addr_cntrl               : 0x12000000 (b/s 0x00000012)
 sdram_opage_cntrl              : 0x00000000 (b/s 0x00000000)
 sdram_oper                     : 0x00000000 (b/s 0x00000000)
 sdram_mode                     : 0x22000000 (b/s 0x00000022)
 extend_dram_mode               : 0x00000000 (b/s 0x00000000)
 dunit_cntrl_high               : 0x77F7000B (b/s 0x0B00F777)
 sdram_xbar_cntl_low            : 0x25272423 (b/s 0x23242725)
 sdram_xbar_cntl_high           : 0x26272423 (b/s 0x23242726)
 sdram_xbar_timeout             : 0xFF000100 (b/s 0x000100FF)
Device Parameters :
 device_bank0_param             : 0xBA4B028C (b/s 0x8C024BBA)
 device_bank1_param             : 0xBA4B028C (b/s 0x8C024BBA)
 device_bank2_param             : 0x97FF8F80 (b/s 0x808FFF97)
 device_bank3_param             : 0xA7FFDB84 (b/s 0x84DBFFA7)
 boot_bank_param                : 0xFFFF5F80 (b/s 0x805FFFFF)
IDMA Channels :
 ch0_dma_count                  : 0x00000000 (b/s 0x00000000)
 ch1_dma_count                  : 0x00000000 (b/s 0x00000000)
 ch2_dma_count                  : 0x00000000 (b/s 0x00000000)
 ch3_dma_count                  : 0x00000000 (b/s 0x00000000)
 ch0_dma_src                    : 0x00000000 (b/s 0x00000000)
 ch1_dma_src                    : 0xDEC8800F (b/s 0x0F80C8DE)
 ch2_dma_src                    : 0x00000000 (b/s 0x00000000)
 ch3_dma_src                    : 0x00000000 (b/s 0x00000000)
 ch0_dma_dst                    : 0x00000000 (b/s 0x00000000)
 ch1_dma_dst                    : 0xC608860F (b/s 0x0F8608C6)
 ch2_dma_dst                    : 0x00000000 (b/s 0x00000000)
 ch3_dma_dst                    : 0x00000000 (b/s 0x00000000)
 ch0_next_ptr                   : 0x00000000 (b/s 0x00000000)
 ch1_next_ptr                   : 0x00000000 (b/s 0x00000000)
 ch2_next_ptr                   : 0x00000000 (b/s 0x00000000)
 ch3_next_ptr                   : 0x00000000 (b/s 0x00000000)
 ch0_current_ptr                : 0x00000000 (b/s 0x00000000)
 ch1_current_ptr                : 0xE0E4790F (b/s 0x0F79E4E0)
 ch2_current_ptr                : 0x00000000 (b/s 0x00000000)
 ch3_current_ptr                : 0x00000000 (b/s 0x00000000)
Timer/Counters :
 ct0                            : 0x00000000 (b/s 0x00000000)
 ct1                            : 0xAD110000 (b/s 0x000011DF)
 ct2                            : 0xA1870400 (b/s 0x000487CB)
 ct3                            : 0x00000000 (b/s 0x00000000)
 counter_ctrl                   : 0x00010100 (b/s 0x00010100)
PCI Internal Registers :
 pci0_cmd                       : 0x410F1700 (b/s 0x00170F41)
 pci1_cmd                       : 0x410F1700 (b/s 0x00170F41)
 pci0_mode                      : 0x00000080 (b/s 0x80000000)
 pci1_mode                      : 0x01000080 (b/s 0x80000001)
 pci0_retry                     : 0x00000000 (b/s 0x00000000)
 pci1_retry                     : 0x00000000 (b/s 0x00000000)
 pci0_discard_timer             : 0x00000000 (b/s 0x00000000)
 pci1_discard_timer             : 0x00000000 (b/s 0x00000000)
 pci0_cs0_size                  : 0x00F0FF1F (b/s 0x1FFFF000)
 pci1_cs0_size                  : 0x00F0FF1F (b/s 0x1FFFF000)
 pci1_cs1_size                  : 0x00F07F00 (b/s 0x007FF000)
 pci0_cs2_size                  : 0x00F07F00 (b/s 0x007FF000)
 pci1_cs2_size                  : 0x00F07F00 (b/s 0x007FF000)
 pci0_cs3_size                  : 0x00F07F00 (b/s 0x007FF000)
 pci1_cs3_size                  : 0x00F07F00 (b/s 0x007FF000)
 pci0_base_addr_regs_enable     : 0xFEFDFFFF (b/s 0xFFFFFDFE)
 pci1_base_addr_regs_enable     : 0xFEFDFFFF (b/s 0xFFFFFDFE)
Interrupt Control :
 main_int_cause_l               : 0x00000000 (b/s 0x00000000)
 main_int_cause_h               : 0x00000000 (b/s 0x00000000)
 cpu_int0_mask_l                : 0x300F0000 (b/s 0x00000F30)
 cpu_int0_mask_h                : 0x03000000 (b/s 0x00000003)
 cpu_int0_selcause              : 0x00000000 (b/s 0x00000000)
 int0_mask_l                    : 0x0000000F (b/s 0x0F000000)
 int0_mask_h                    : 0x5000000F (b/s 0x0F000050)
ECC information :
 sdram_err_addr                 : 0x00000000 (b/s 0x00000000)
 sdram_err_data_high            : 0x00000000 (b/s 0x00000000)
 sdram_err_data_low             : 0x00000000 (b/s 0x00000000)
 sdram_rcv_ecc                  : 0x00000000 (b/s 0x00000000)
 sdram_calc_ecc                 : 0x00000000 (b/s 0x00000000)
 sdram_ecc_cntrl                : 0x00000000 (b/s 0x00000000)
 sdram_ecc_counter              : 0x00000000 (b/s 0x00000000)
------------------ show controllers t1 ------------------
------------------ show controllers e1 ------------------
------------------ show controllers j1 ------------------
------------------ show ip nbar version ------------------
NBAR software version:  4
1   base                 Mv: 2
2   ftp                  Mv: 2
3   http                 Mv: 9
4   static               Mv: 6
5   tftp                 Mv: 1
6   exchange             Mv: 1
7   vdolive              Mv: 1
8   sqlnet               Mv: 1
9   rcmd                 Mv: 1
10  netshow              Mv: 1
11  sunrpc               Mv: 2
12  streamwork           Mv: 1
13  citrix               Mv: 7
14  napster              Mv: 3
15  fasttrack            Mv: 2
16  gnutella             Mv: 2
17  kazaa2               Mv: 6
18  custom-protocols     Mv: 1
19  rtsp                 Mv: 3
20  rtp                  Mv: 3
21  mgcp                 Mv: 2
22  skinny               Mv: 1
23  h323                 Mv: 1
24  sip                  Mv: 1
25  rtcp                 Mv: 1
26  edonkey              Mv: 2
27  winmx                Mv: 1
{<No.>}<PDLM name> Mv: <PDLM Version>, {Nv: <NBAR Software Version>; <File name>}
            {Iv: <PDLM Interdependency Name>   - <PDLM Interdependency Version>}
------------------ show crypto key mypubkey rsa ------------------
% Key pair was generated at: 13:16:49 IST Dec 1 2018
Key name: MH-NMVIKROLI-NMDC-RT-C2861-1.146.Indiainfoline.com
 Usage: General Purpose Key
 Key is not exportable.
 Key Data:
  307C300D 06092A86 4886F70D 01010105 00036B00 30680261 00B71F7E CA8BC36B
  524F0C47 52CB4102 9E53A4CF 430F66EF E9555BA6 42F6C7D4 ABF1C4B4 A4C325CB
  F33F5A1F 2FE56896 10BA7F37 0D6F7336 89C0F5F3 384200E0 DE64A8B0 5BC84516
  5055B765 0C2BAEE6 33A1845D FC7BB2DE D6F21000 AC761778 9D020301 0001
% Key pair was generated at: 23:48:27 IST Jul 4 2020
Key name: MH-NMVIKROLI-NMDC-RT-C2861-1.146.Indiainfoline.com.server
 Usage: Encryption Key
 Key Data:
  306C300D 06092A86 4886F70D 01010105 00035B00 30580251 00C75674 14C3D677
  061E37BE 9BA212C7 F3974F14 C354FCB5 F43A84ED 8462036C CB2A8625 A6972A98
  CA34804A 12FF61C7 A0272F8C F9E0CD79 32FD177E 56FEF42F 9F3F5082 4601D134
  ECC79DE9 0B12804F 53020301 0001
------------------ show buffers ------------------
Buffer elements:
     1115 in free list (1119 max allowed)
     78637927 hits, 0 misses, 619 created
Public buffer pools:
Small buffers, 104 bytes (total 175, permanent 50, peak 229 @ 7w0d):
     93 in free list (20 min, 150 max allowed)
     1918140366 hits, 601618 misses, 193104 trims, 193229 created
     130664 failures (0 no memory)
Middle buffers, 600 bytes (total 87, permanent 25, peak 94 @ 7w0d):
     79 in free list (10 min, 150 max allowed)
     1021230876 hits, 97385 misses, 29500 trims, 29562 created
     45303 failures (0 no memory)
Big buffers, 1536 bytes (total 50, permanent 50, peak 62 @ 7w0d):
     49 in free list (5 min, 150 max allowed)
     84278628 hits, 2800 misses, 1120 trims, 1120 created
     2045 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 11 @ 7w0d):
     10 in free list (0 min, 100 max allowed)
     1302 hits, 743 misses, 102 trims, 102 created
     743 failures (0 no memory)
Large buffers, 5024 bytes (total 1, permanent 0, peak 2 @ 7w0d):
     1 in free list (0 min, 10 max allowed)
     101 hits, 642 misses, 4352 trims, 4353 created
     642 failures (0 no memory)
Huge buffers, 18024 bytes (total 1, permanent 0, peak 2 @ 7w0d):
     1 in free list (0 min, 4 max allowed)
     94 hits, 548 misses, 4347 trims, 4348 created
     548 failures (0 no memory)
Interface buffer pools:
CD2430 I/O buffers, 1536 bytes (total 0, permanent 0):
     0 in free list (0 min, 0 max allowed)
     0 hits, 0 fallbacks
IPC buffers, 4096 bytes (total 2, permanent 2):
     2 in free list (1 min, 8 max allowed)
     0 hits, 0 fallbacks, 0 trims, 0 created
     0 failures (0 no memory)
Header pools:
Header buffers, 0 bytes (total 768, permanent 768):
     256 in free list (128 min, 1024 max allowed)
     512 hits, 0 misses, 0 trims, 0 created
     512 max cache size, 512 in cache
     1556 hits in cache, 0 misses in cache
Particle Clones:
     1024 clones, 53861913 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 768, permanent 768):
     53861913 hits in cache, 0 misses in cache
Normal buffers, 1548 bytes (total 768, permanent 768):
     768 in free list (128 min, 1024 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
Private particle pools:
IDS SM buffers, 240 bytes (total 128, permanent 128):
     0 in free list (0 min, 128 max allowed)
     128 hits, 0 fallbacks
     128 max cache size, 128 in cache
     0 hits in cache, 0 misses in cache
GigabitEthernet0/0 buffers, 1536 bytes (total 192, permanent 192):
     0 in free list (0 min, 192 max allowed)
     192 hits, 0 fallbacks
     192 max cache size, 128 in cache
     153001867 hits in cache, 0 misses in cache
GigabitEthernet0/1 buffers, 1536 bytes (total 192, permanent 192):
     4160215260 hits in cache, 0 misses in cache
Serial0/1/0 buffers, 1536 bytes (total 64, permanent 64):
     0 in free list (0 min, 64 max allowed)
     64 hits, 0 fallbacks
     64 max cache size, 32 in cache
     32 hits in cache, 0 misses in cache
------------------ show inventory ------------------
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821         , VID: V04 , SN: FHK1129F29Y
NAME: "WAN Interface Card - Serial (1T)", DESCR: "WAN Interface Card - Serial (1T)"
PID: WIC-1T=           , VID: 1.0, SN: 35857142
------------------ Mempool statistics ------------------
Processor   425B9740   218392768    11587220   206805548   205046884   204918472
      I/O   3F600000    10485760     2754632     7731128     7682160     7716924
------------------ show memory summary -----------------
          Processor memory
Alloc PC        Size     Blocks      Bytes    What
0x40011208 0000000368 0000000001 0000000368    Init
0x40012588 0000000848 0000000001 0000000848    *In-use Packet Header*
0x4001346C 0000000128 0000000002 0000000256    Init
0x40013484 0000000128 0000000002 0000000256    Init
0x400134C8 0000003072 0000000002 0000006144    Init
0x40014760 0000000052 0000000004 0000000208    Init
0x40014808 0000000136 0000000001 0000000136    Init
0x40022880 0000001480 0000000001 0000001480    Init
0x400228F4 0000000072 0000000001 0000000072    Init
0x40028E30 0000000152 0000000001 0000000152    Init
0x400294F8 0000000024 0000000001 0000000024    Init
0x40029638 0000000024 0000000001 0000000024    Init
0x40029698 0000001480 0000000001 0000001480    Init
0x4002975C 0000000072 0000000001 0000000072    Init
0x40038280 0000001536 0000000001 0000001536    Init
0x40038D94 0000000120 0000000001 0000000120    Init
0x4003B02C 0000000024 0000000001 0000000024    USB Startup
0x40043B04 0000000028 0000000006 0000000168    MV64340 Ethernet AF Entry
0x40043B04 0000000100 0000000001 0000000100    MV64340 Ethernet AF Entry
0x40045D30 0000000848 0000000002 0000001696    *In-use Packet Header*
0x40046A74 0000000792 0000000002 0000001584    Init
0x40046E24 0000000256 0000000002 0000000512    MV64340 Ethernet Rx Shadow
0x40046EA8 0000001024 0000000002 0000002048    MV64340 Ethernet Tx Shadow
0x40046F1C 0000000024 0000000002 0000000048    Init
0x40046F34 0000001028 0000000002 0000002056    MV64340 Ethernet AF Table
0x40088E14 0000065536 0000000001 0000065536    CPU RO RU Chunks
0x40089448 0000000024 0000000001 0000000024    *Sched*
0x400897A0 0000000256 0000000001 0000000256    Init
0x4008E224 0000000112 0000000005 0000000560    Process Signals
0x4008E224 0000000144 0000000003 0000000432    Process Signals
0x4008E754 0000003000 0000000008 0000024000    Process Stack
0x4008E754 0000006000 0000000096 0000576000    Process Stack
0x4008E754 0000008000 0000000004 0000032000    Process Stack
0x4008E754 0000009000 0000000005 0000045000    Process Stack
0x4008E754 0000012000 0000000032 0000384000    Process Stack
0x4008E754 0000024000 0000000003 0000072000    Process Stack
0x4008E754 0000054000 0000000001 0000054000    Interrupt Stack
0x4008EE90 0000000232 0000000001 0000000232    *Init*
0x400983D0 0000065536 0000000005 0000327680    MallocLite
0x400983D0 0000121020 0000000001 0000121020    MallocLite
0x4009E138 0000000960 0000000001 0000000960    Check heaps
0x4009E16C 0000001728 0000000001 0000001728    Check heaps
0x400A69F0 0000065536 0000000001 0000065536    Memory RO RU Chunks
0x400A6B38 0000065536 0000000001 0000065536    Memory RO RU Index Chunks
0x400A76FC 0000020000 0000000001 0000020000    Managed Chunk Queue Elements
0x400A7B90 0000010000 0000000001 0000010000    List Elements
0x400ABE78 0000000336 0000000017 0000005712    Pool Info
0x400AC57C 0000000256 0000000001 0000000256    Pool Cache
0x400AC57C 0000000512 0000000001 0000000512    Pool Cache
0x400AC57C 0000000768 0000000002 0000001536    Pool Cache
0x400AC57C 0000002048 0000000002 0000004096    Pool Cache
0x400B0E4C 0000000040 0000000001 0000000040    *Init*
0x400C7950 0000000848 0000000001 0000000848    *In-use Packet Header*
0x400D1B10 0000000848 0000000001 0000000848    *In-use Packet Header*
0x400DB6DC 0000000024 0000000006 0000000144    Init
0x400ED278 0000000156 0000000001 0000000156    Device Info
0x400ED294 0000000328 0000000001 0000000328    Dev: Cons Info
0x400ED2B0 0000001836 0000000001 0000001836    Dev: Chip Info
0x400F405C 0000000060 0000000001 0000000060    FileSys Callback
0x400F4138 0000000088 0000000001 0000000088    FileSys Info
0x400F4154 0000016384 0000000001 0000016384    Init
0x400F41D4 0000001024 0000000001 0000001024    Init
0x400F41E8 0000001024 0000000001 0000001024    Init
0x400F4214 0000000512 0000000001 0000000512    Init
0x400F4334 0000008192 0000000001 0000008192    FileSys Scratch
0x400F48CC 0000000052 0000000001 0000000052    Init
0x400FFC14 0000000320 0000000001 0000000320    IPC Seat Manager
0x400FFC2C 0000000320 0000000001 0000000320    IPC Seat Manager
0x4010300C 0000000440 0000000001 0000000440    IPC Global Info
0x4010302C 0000000440 0000000001 0000000440    IPC Global Cache Info
0x401031D8 0000001500 0000000001 0000001500    IPC Split Init Func Cache
0x40103254 0000000556 0000000001 0000000556    IPC Split Init level
0x401032DC 0000020000 0000000001 0000020000    IPC port info
0x401062D4 0000000840 0000000003 0000002520    IPC Port
0x401062F4 0000000024 0000000003 0000000072    IPC Name
0x4010AB90 0000000060 0000000001 0000000060    IPC Seat
0x4010CBEC 0000065536 0000000001 0000065536    IPC Message Header Cache
0x4010CC68 0000065536 0000000002 0000131072    IPC Message He
0x4010CCF8 0000000400 0000000001 0000000400    IPC Msg Cache
0x4010CD24 0000000136 0000000100 0000013600    IPC Message
0x4010CD60 0000000128 0000000001 0000000128    IPC Frag Cache
0x4010CD7C 0000000024 0000000032 0000000768    IPC Fragment
0x4010E124 0000000044 0000000008 0000000352    IPC Thread
0x4010E144 0000000064 0000000001 0000000064    IPC Thread Slot
0x4010E144 0000000172 0000000001 0000000172    IPC Thread Slot
0x4010E144 0000000388 0000000006 0000002328    IPC Thread Slot
0x4010EC40 0000000024 0000000005 0000000120    IPC Name String
0x40112DD4 0000000092 0000000001 0000000092    IPC Zone
0x40114E94 0000000340 0000000001 0000000340    IP mtrie node
0x40114E94 0000065536 0000000001 0000065536    IP mtrie node
0x40119F48 0000003000 0000000001 0000003000    FDNODE
0x40119F94 0000032768 0000000001 0000032768    PCMCIAFS LFN Node
0x40119FE0 0000010000 0000000001 0000010000    DFS Sector
0x4011A02C 0000005000 0000000001 0000005000    Super Dir entry
0x4011A078 0000065536 0000000001 0000065536    DFS stream buffer
0x4011A0C4 0000065536 0000000001 0000065536    PFS inode table
0x4011A110 0000010000 0000000001 0000010000    Device Info Block
0x4011A15C 0000010000 0000000001 0000010000    Directory Entry
0x401231B4 0000004096 0000000001 0000004096    Init
0x401231CC 0000069120 0000000001 0000069120    Init
0x401231E0 0000058368 0000000001 0000058368    Init
0x40123220 0000000192 0000000003 0000000576    Init
0x40123244 0000000032 0000000003 0000000096    Init
0x4012CDC4 0000140796 0000000001 0000140796    (coalesced) (Free Blocks)
0x401319A4 0000000100 0000000001 0000000100    Init
0x4016B970 0000000064 0000000009 0000000576    DTP Protocol
0x40177E50 0000000120 0000000001 0000000120    Init
0x401C1A28 0000000024 0000000267 0000006408    Init
0x401C1A28 0000000088 0000000001 0000000088    Init
0x40226898 0000000848 0000000002 0000001696    *In-use Packet Header*
0x4022A854 0000245752 0000000001 0000245752    Init
0x402329A4 0000000024 0000000002 0000000048    Init
0x402329A4 0000000044 0000000001 0000000044    Init
0x40232D88 0000000024 0000000003 0000000072    Init
0x4023B330 0000000136 0000000001 0000000136    Init
0x40240B58 0000000024 0000000003 0000000072    *Init*
0x40240FDC 0000000120 0000000002 0000000240    Init
0x40240FE8 0000005120 0000000001 0000005120    Init
0x40240FE8 0000020480 0000000001 0000020480    Init
0x40240FF8 0000006144 0000000001 0000006144    Init
0x40240FF8 0000020480 0000000001 0000020480    Init
0x4024AC74 0000000128 0000000001 0000000128    *Init*
0x40268684 0000002000 0000000001 0000002000    fslib file record pool chunk
0x402854F8 0000000024 0000000001 0000000024    ISDN-t-callmib
0x402A4C2C 0000026880 0000000001 0000026880    cd2430 stb
0x402BC8F4 0000000032 0000000048 0000001536    CDAPI-RtgTbl
0x402BCB5C 0000000632 0000000001 0000000632    CDAPI Msg Chunk
0x402BCB5C 0000065536 0000000001 0000065536    CDAPI Msg Chunk
0x402D9088 0000000064 0000000001 0000000064    Init
0x402D90AC 0000000064 0000000001 0000000064    Init
0x402D90CC 0000000024 0000000001 0000000024    Init
0x402D90EC 0000000064 0000000001 0000000064    Init
0x402D910C 0000000064 0000000001 0000000064    Init
0x402D912C 0000000024 0000000001 0000000024    Init
0x402D914C 0000000064 0000000001 0000000064    Init
0x402D916C 0000000064 0000000001 0000000064    Init
0x402D918C 0000000024 0000000001 0000000024    Init
0x402EA3D8 0000000848 0000001089 0000923472    *Free Packet Header*
0x402EA3D8 0000000872 0000000001 0000000872    *Free Packet Header*
0x402EA3D8 0000000888 0000000002 0000001776    *Free Packet Header*
0x402EA3D8 0000000096 0000000001 0000000096    (fragment) (Free Blocks)
0x402EA3D8 0000000100 0000000001 0000000100    (fragment) (Free Blocks)
0x402EA3D8 0000000140 0000000001 0000000140    (fragment) (Free Blocks)
0x402EA3D8 0000000848 0000000013 0000011024    *Packet Header* (Free Blocks)
0x402EA3D8 0000000972 0000000001 0000000972    (coalesced) (Free Blocks)
0x402EA3D8 0000001368 0000000001 0000001368    (coalesced) (Free Blocks)
0x402EA3D8 0000001548 0000000001 0000001548    (coalesced) (Free Blocks)
0x402EA3D8 0000001748 0000000002 0000003496    (coalesced) (Free Blocks)
0x402EA3D8 0000002648 0000000001 0000002648    (coalesced) (Free Blocks)
0x402EA3D8 0000007620 0000000001 0000007620    (coalesced) (Free Blocks)
0x402EA3D8 0001657568 0000000001 0001657568    (coalesced) (Free Blocks)
0x402EA3D8 0204918472 0000000001 0204918472    (coalesced) (Free Blocks)
0x402F1794 0000010000 0000000001 0000010000    Packet Elements Cache
0x402F17C4 0000010000 0000000001 0000010000    Packet Elements
0x402F37D8 0000002912 0000000018 0000052416    *Hardware IDB*
0x402F37F4 0000001280 0000000018 0000023040    *Software IDB*
0x402F4B1C 0000000024 0000000011 0000000264    Init
0x402F4B1C 0000000052 0000000001 0000000052    Init
0x402F4B1C 0000000096 0000000001 0000000096    Init
0x402F4BA8 0000000024 0000000012 0000000288    Init
0x402F4BA8 0000000052 0000000001 0000000052    Init
0x402F7DB4 0000000032 0000000002 0000000064    Init
0x40301F5C 0000000024 0000000004 0000000096    Init
0x40301F5C 0000000032 0000000001 0000000032    Init
0x40304DF8 0000065536 0000000001 0000065536    Buffer Display Chunks
0x40305084 0000065536 0000000001 0000065536    Buffer RO RU Chunks
0x403050B0 0000065536 0000000001 0000065536    Buffer RU Notify Chunks
0x40313F50 0000000024 0000000001 0000000024    MTU RANGE SUBBLOCK
0x40313F50 0000000080 0000000001 0000000080    MTU RANGE SUBBLOCK
0x403145B8 0000065536 0000000001 0000065536    Clones
0x40314780 0000000248 0000000001 0000000248    Normal
0x40314780 0000000348 0000000002 0000000696    Serial0/1/0
0x40314780 0000000404 0000000002 0000000808    Normal
0x40314780 0000000604 0000000002 0000001208    IDS SM
0x40314780 0000000836 0000000001 0000000836    F/S
0x40314780 0000000860 0000000004 0000003440    GigabitEthernet0/0
0x40314780 0000004096 0000000001 0000004096    Serial0/1/0
0x40314780 0000005000 0000000002 0000010000    Normal
0x40314780 0000008192 0000000001 0000008192    IDS SM
0x40314780 0000012288 0000000002 0000024576    GigabitEthernet0/0
0x40314814 0000000404 0000000018 0000007272    Normal
0x40314814 0000005000 0000000018 0000090000    Normal
0x40314838 0000000248 0000000019 0000004712    Normal
0x40314838 0000000836 0000000004 0000003344    F/S
0x4031D800 0000065536 0000000001 0000065536    IDB List Element Chunks
0x40321C80 0000000400 0000000001 0000000400    *Init*
0x40332CCC 0000000024 0000000058 0000001392    Init
0x40332E44 0000000024 0000000011 0000000264    Init
0x40333128 0000000104 0000000008 0000000832    Init
0x40333138 0000000024 0000000008 0000000192    Init
0x4033329C 0000000024 0000000001 0000000024    Init
0x4033332C 0000000024 0000000006 0000000144    Init
0x4033332C 0000000076 0000000001 0000000076    Init
0x40357E30 0000000196 0000000001 0000000196    Init
0x4035C4B0 0000000808 0000000001 0000000808    CSM data
0x403D03D0 0000001500 0000000001 0000001500    DTP messages
0x403F3358 0000000152 0000000001 0000000152    ESWILP NMs table
0x4040D28C 0000001316 0000000001 0000001316    ESWILP NMs table
0x4040F174 0000000576 0000000001 0000000576    ESWILP VLAN MAC addr table
0x4040F4EC 0000002552 0000000001 0000002552    logical-tab-phy-ports
0x4043B314 0000005000 0000000001 0000005000    FEC XDR chunk
0x404B9790 0000000104 0000000001 0000000104    L2MM
0x404BBB58 0000000096 0000000001 0000000096    L2MM
0x404BEFA8 0000000136 0000000001 0000000136    L2MM
0x405285B8 0000001044 0000000001 0000001044    ISDN Called Number Chunk
0x405285B8 0000020000 0000000001 0000020000    ISDN Called Number Chunk
0x405285E8 0000000232 0000000001 0000000232    ISDN Router Message Chunk
0x405285E8 0000010000 0000000001 0000010000    ISDN Router Message Chunk
0x405BE260 0000000032 0000000001 0000000032    shadow tsi str control
0x405C3B3C 0000000280 0000000001 0000000280    TDM Clock Information
0x405C65EC 0000065536 0000000001 0000065536    Mat Addr Tbl Chunk
0x405C6618 0000010000 0000000001 0000010000    Mat Addr Entry Chunk
0x405C6644 0000000848 0000000001 0000000848    Mat Port List Chunk
0x40603ED4 0000027332 0000000001 0000027332    Init
0x4062DDE0 0000004324 0000000001 0000004324    Init
0x4062DF1C 0000000296 0000000001 0000000296    VLAN Manager
0x4062DF7C 0000000024 0000000001 0000000024    VLAN Manager
0x40635590 0000000024 0000000001 0000000024    VLAN Manager
0x406777E0 0000000072 0000000001 0000000072    SSS Switch Information
0x40677834 0000001024 0000000001 0000001024    SSS Switch Handle
0x4068286C 0000000848 0000000001 0000000848    ESWILP_OIDB
0x40691FE8 0000000056 0000000002 0000000112    VLAN Manager
0x40697BA4 0000000076 0000000005 0000000380    VLAN Manager
0x40699A8C 0000005664 0000000001 0000005664    VLAN Manager
0x406AFC04 0000000572 0000000001 0000000572    TGRM Trunk Groups Head
0x406C2D30 0000000848 0000000001 0000000848    CRM call update events chunk
0x406D05E4 0000000848 0000000001 0000000848    *In-use Packet Header*
0x406D7FF8 0000008196 0000000001 0000008196    L2TP Session ID Table
0x4072F3E8 0000000036 0000002048 0000073728    USB Startup
0x4072F484 0000001372 0000000256 0000351232    USB Startup
0x4072F514 0000000132 0000000001 0000000132    USB Startup
0x40730350 0000000024 0000000001 0000000024    USB Startup
0x4073042C 0000000112 0000000001 0000000112    USB Startup
0x4073060C 0000000028 0000000001 0000000028    USB Startup
0x40731DD0 0000001544 0000000001 0000001544    USB Startup
0x407343B8 0000000872 0000000001 0000000872    USB Startup
0x407347D8 0000000560 0000000001 0000000560    USB Startup
0x407354E0 0000000028 0000000001 0000000028    USB Startup
0x40736230 0000000024 0000000001 0000000024    USB Startup
0x40736258 0000000068 0000000001 0000000068    USB Startup
0x407362AC 0000000024 0000000001 0000000024    USB Startup
0x407362CC 0000000024 0000000001 0000000024    USB Startup
0x4073634C 0000000032 0000000001 0000000032    USB Startup
0x40736370 0000000024 0000000001 0000000024    USB Startup
0x40736390 0000000024 0000000001 0000000024    USB Startup
0x407363D4 0000000128 0000000001 0000000128    USB Startup
0x407363F4 0000000128 0000000001 0000000128    USB Startup
0x40736564 0000000088 0000000004 0000000352    USB Startup
0x40736604 0000000024 0000000003 0000000072    USB Startup
0x40736604 0000000052 0000000001 0000000052    USB Startup
0x40736630 0000000324 0000000004 0000001296    USB Startup
0x4073668C 0000000072 0000000032 0000002304    USB Startup
0x40736708 0000000064 0000000032 0000002048    USB Startup
0x40736728 0000000128 0000000032 0000004096    USB Startup
0x4073A2B8 0000000080 0000000001 0000000080    USB Startup
0x4073A338 0000000024 0000000001 0000000024    USB Startup
0x4073A398 0000000184 0000000001 0000000184    USB Startup
0x4073D8DC 0000000036 0000000001 0000000036    USB Startup
0x4073D92C 0000000332 0000000001 0000000332    USB Startup
0x4073F7BC 0000000024 0000000012 0000000288    USB Startup
0x4073F7D4 0000000024 0000000001 0000000024    USB Startup
0x4073F7D4 0000000128 0000000001 0000000128    USB Startup
0x4073F7D4 0000000200 0000000002 0000000400    USB Startup
0x4073F7D4 0000000256 0000000004 0000001024    USB Startup
0x4073F7D4 0000002048 0000000004 0000008192    USB Startup
0x4073F7F0 0000000024 0000000001 0000000024    USB Startup
0x4073F7F0 0000000384 0000000001 0000000384    USB Startup
0x4073F7F0 0000000768 0000000004 0000003072    USB Startup
0x4073F7F0 0000004400 0000000002 0000008800    USB Startup
0x4073F7F0 0000006144 0000000004 0000024576    USB Startup
0x4073FB1C 0000000024 0000000001 0000000024    USB Startup
0x4073FB1C 0000000032 0000000001 0000000032    USB Startup
0x4073FD68 0000000036 0000000013 0000000468    USB Startup
0x4073FDB8 0000000024 0000000001 0000000024    USB Startup
0x4073FDB8 0000000028 0000000005 0000000140    USB Startup
0x4073FDB8 0000000032 0000000005 0000000160    USB Startup
0x4073FDB8 0000000048 0000000001 0000000048    USB Startup
0x4073FDB8 0000000052 0000000001 0000000052    USB Startup
0x4073FDEC 0000000024 0000000001 0000000024    USB Startup
0x4073FDEC 0000000032 0000000006 0000000192    USB Startup
0x4073FDEC 0000000036 0000000004 0000000144    USB Startup
0x4073FDEC 0000000048 0000000002 0000000096    USB Startup
0x407403F4 0000000048 0000000012 0000000576    USB Startup
0x40740430 0000000024 0000000002 0000000048    USB Startup
0x40740430 0000000032 0000000007 0000000224    USB Startup
0x40740430 0000000048 0000000003 0000000144    USB Startup
0x407404F4 0000000024 0000000002 0000000048    USB Startup
0x407404F4 0000000028 0000000004 0000000112    USB Startup
0x407404F4 0000000032 0000000005 0000000160    USB Startup
0x407404F4 0000000048 0000000001 0000000048    USB Startup
0x40745B00 0000000528 0000000001 0000000528    USB Startup
0x4074D3AC 0000000452 0000000001 0000000452    (coalesced) (Free Blocks)
0x4074D3AC 0000000468 0000000001 0000000468    (coalesced) (Free Blocks)
0x40752848 0000008064 0000000001 0000008064    Init
0x4075B498 0000000144 0000000001 0000000144    Crypto CA
0x4075B498 0000000528 0000000001 0000000528    Crypto CA
0x4078D728 0000000024 0000000001 0000000024    Init
0x4078D728 0000000048 0000000001 0000000048    Init
0x4078E1F4 0000000060 0000000020 0000001200    Init
0x40795B20 0000010240 0000000001 0000010240    Init
0x40795B38 0000013312 0000000001 0000013312    Init
0x407A075C 0000000864 0000000001 0000000864    EXEC ACCT LISTS
0x407A07A4 0000009600 0000000001 0000009600    NET ACCT LISTS
0x407A07E8 0000009600 0000000001 0000009600    SYS ACCT LISTS
0x407A3EB4 0000005000 0000000001 0000005000    AAA chunk
0x407A9068 0000001024 0000000001 0000001024    AAA mlist ID table
0x407B4F48 0000000836 0000000001 0000000836    CEF: Adjacency chunk
0x407B4F48 0000065536 0000000001 0000065536    CEF: Adjacency chunk
0x407B4F74 0000003000 0000000001 0000003000    CEF: Protocol adjacency chunk
0x407B4F84 0000001024 0000000001 0000001024    Init
0x407B4FF4 0000000336 0000000001 0000000336    CEF: NULL adjacency
0x407B509C 0000000336 0000000001 0000000336    CEF: NULL (drop) adjacency
0x407B5144 0000000336 0000000001 0000000336    CEF: PUNT adjacency
0x407B51E0 0000000336 0000000001 0000000336    CEF: DROP adjacency
0x407B5284 0000000336 0000000001 0000000336    CEF: Glean adjacency
0x407B5328 0000000336 0000000001 0000000336    CEF: Discard adjacency
0x407B53C4 0000000336 0000000001 0000000336    DoS Punt adjacency
0x407B5470 0000000336 0000000001 0000000336    CEF: Default route adjacency
0x407C33F8 0000003000 0000000001 0000003000    ARP Entry
0x407CAED0 0000000024 0000000001 0000000024    Init
0x407E5B40 0000054432 0000000001 0000054432    Init
0x407E5B6C 0000003024 0000000001 0000003024    Init
0x407E5B94 0000013824 0000000001 0000013824    Init
0x408AC5E0 0000000024 0000000014 0000000336    *Init*
0x408B5C28 0000001984 0000000001 0000001984    Init
0x408B5CC4 0000002368 0000000001 0000002368    Init
0x408B5D68 0000003776 0000000001 0000003776    Init
0x4090C86C 0000000228 0000000001 0000000228    MPPE ID bits
0x4090DB54 0000000192 0000000001 0000000192    CDP Protocol
0x4090DB54 0000000084 0000000001 0000000084    (fragment) (Free Blocks)
0x4090DEEC 0000000260 0000000001 0000000260    Init
0x4090E0E4 0000000108 0000000001 0000000108    Init
0x409158C4 0000000024 0000000001 0000000024    CDP hw subblock
0x409158C4 0000000044 0000000001 0000000044    CDP hw subblock
0x409158C4 0000000072 0000000001 0000000072    CDP hw subblock
0x40917664 0000000064 0000000002 0000000128    CDP sw subblock
0x40917664 0000000120 0000000001 0000000120    CDP sw subblock
0x40919238 0000000024 0000000001 0000000024    Init
0x409192FC 0000000024 0000000001 0000000024    Init
0x40919FEC 0000000848 0000000001 0000000848    *In-use Packet Header*
0x4091A00C 0000000060 0000000001 0000000060    Init
0x4091C97C 0000000104 0000000001 0000000104    chat script
0x40921908 0000000024 0000000001 0000000024    Init
0x409296D8 0000000056 0000000001 0000000056    Init
0x409863CC 0000001024 0000000001 0000001024    Init
0x409893D8 0000000140 0000000002 0000000280    AAA SG HEAD
0x40989414 0000000024 0000000002 0000000048    AAA SG NAME
0x409895E0 0000000144 0000000002 0000000288    AAA SG HQ
0x4098BB8C 0000001024 0000000001 0000001024    AAA attr list handle IDs
0x4098BC6C 0000011200 0000000001 0000011200    AAA attr list handle IDs
0x4098CCE0 0000000060 0000000001 0000000060    AAA Attr String (Free Blocks)
0x4098CCE0 0000000072 0000000001 0000000072    AAA Attr String (Free Blocks)
0x409986D8 0000004096 0000000001 0000004096    AAA Unique Id Hash Table
0x4099878C 0000065536 0000000001 0000065536    AAA DB Chunk
0x409AF8D0 0000000056 0000000001 0000000056    Init
0x409B18E4 0000000032 0000000001 0000000032    Init
0x409B1B9C 0000001024 0000000001 0000001024    AAA SG ID table
0x409B200C 0000000024 0000000002 0000000048    AAA nvgend sg elt
0x409B2040 0000000140 0000000002 0000000280    AAA Public Server Group
0x409B206C 0000000028 0000000002 0000000056    AAA Public Server Group wrapper
0x409B20AC 0000000024 0000000001 0000000024    AAA pub SG servers
0x409B2120 0000000024 0000000002 0000000048    AAA pub SG wrap name
0x409B2130 0000032768 0000000001 0000032768    AAA SG ID table
0x409B2164 0000000024 0000000002 0000000048    AAA pub SG name
0x409B2D04 0000000360 0000000002 0000000720    AAA Server handleConnection to 172.16.1.146 closed.
]0;noc@VIKDCPVONAS051:~[noc@VIKDCPVONAS051 ~]$ ssh rsadmin@172.16.1.146
C
                        -----"Warning"-----
This system is for use by authorized users only.
Any individual using this system, with, without, excess authorization acknowledges and consents
to the right of the company to monitor, access,use, and disclose any information generated,
received, or stored on the systems,and waives any right of privacy or expectation of privacy
on the part of the individual in connection with his or her use of this system.
If monitoring / investigation reveals possible conduct of criminal activity, system personnel
may provide the evidence of such activity to law enforcement officers.
Unauthorized and / or improper use of this system, as delineated by corporate policies,
is not tolerated and the company may take formal action against such individuals.
rsadmin@172.16.1.146's password:
CCC
MH-NMVIKROLI-NMDC-RT-C2861-1.146#show proc cpu sort              Connection to 172.16.1.146 closed by remote host.
]0;noc@VIKDCPVONAS051:~[noc@VIKDCPVONAS051 ~]$ ssh rsadmin@172.16.1.146[1P[1P[1@n[1@m
C
                        -----"Warning"-----
nmadmin@172.16.1.146's password:
CCC
MH-NMVIKROLI-NMDC-RT-C2861-1.146#tre    er len 0
CPU utilization for five seconds: 99%/98%; one minute: 99%; five minutes: 99%
 134     6138012    709638       8649  0.24%  0.02%  0.00%   0 Per-minute Jobs
  31        5744        82      70048  0.16%  0.07%  0.02% 323 SSH Process
  66   314280220-1868763802          0  0.08%  0.03%  0.02%   0 IP Input
  16    73020476 959347705         76  0.08%  0.09%  0.08%   0 ARP Input
  50       14112 167180868          0  0.08%  0.00%  0.00%   0 Netclock Backgro
   7          28    696594          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
   5       44328     46684        949  0.00%  0.00%  0.00%   0 Pool Manager
   9        9204  41794741          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  10        8124  41794738          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  15       15572   1393186         11  0.00%  0.00%  0.00%   0 Environmental mo
   4    11966448   4274611       2799  0.00%  0.03%  0.00%   0 Check heaps
   3        4868        22     221272  0.00%  0.03%  0.01% 322 SSH Process
  23       41004   8359075          4  0.00%  0.00%  0.00%   0 HC Counter Timer
   2       92628   8359116         11  0.00%  0.01%  0.00%   0 Load Meter
  27        8968  41795473          0  0.00%  0.00%  0.00%   0 GraphIt
  34      198220  17836883         11  0.00%  0.00%  0.00%   0 Net Background
  36         592       510       1160  0.00%  0.00%  0.00%   0 Logger
  37       14260  41794729          0  0.00%  0.00%  0.00%   0 TTY Background
  39         232   2786370          0  0.00%  0.00%  0.00%   0 c2800 Periodic
  53        5024  41794733          0  0.00%  0.00%  0.00%   0 Ether-Switch RBC
  56          76   1393187          0  0.00%  0.00%  0.00%   0 Call Management
  59        6908  41794733          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  60         268   4179551          0  0.00%  0.00%  0.00%   0 EtherChnl
  62         124      1190        104  0.00%  0.00%  0.00%   0 AAA Server
  65      139200   5993631         23  0.00%  0.00%  0.00%   0 CDP Protocol
  38       83388  41795697          1  0.00%  0.00%  0.00%   0 Per-Second Jobs
  70         132     69507          1  0.00%  0.00%  0.00%   0 MOP Protocols
  74         660   5572737          0  0.00%  0.00%  0.00%   0 SSS Test Client
  76       19844 163262794          0  0.00%  0.00%  0.00%   0 SSS Feature Time
  82       16060   1329822         12  0.00%  0.00%  0.00%   0 IP Background
  83        1340    696731          1  0.00%  0.00%  0.00%   0 IP RIB Update
  86       78308  44278513          1  0.00%  0.00%  0.00%   0 Socket Timers
  87        3408     74209         45  0.00%  0.00%  0.00%   0 TCP Timer
  88       20752     46593        445  0.00%  0.00%  0.00%   0 TCP Protocols
  90       52432  48160228          1  0.00%  0.00%  0.00%   0 CEF process
  97       16764  41794773          0  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
  99        5892  41794735          0  0.00%  0.00%  0.00%   0 bsm_xmt_proc
 100     2085360  88622203         23  0.00%  0.02%  0.00%   0 DHCPD Receive
 102         304    696521          0  0.00%  0.00%  0.00%   0 IP Cache Ager
 103        7180    696613         10  0.00%  0.00%  0.00%   0 Adj Manager
 104          12    139320          0  0.00%  0.00%  0.00%   0 HTTP CORE
 111         336   1671825          0  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
 116        8964     38548        232  0.00%  0.00%  0.00%   0 LOCAL AAA
 125         316   4179551          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
 129         124    348297          0  0.00%  0.00%  0.00%   0 DHCPD Timer
 130        2324       256       9078  0.00%  0.00%  0.00%   0 Syslog
 133       78024   8359257          9  0.00%  0.00%  0.00%   0 Compute load avg
 135       28144   1449604         19  0.00%  0.00%  0.00%   0 CEF Scanner
 140     1866360  58076271         32  0.00%  0.04%  0.05%   0 IGMP Input
 141      513232  53001943          9  0.00%  0.02%  0.00%   0 PIM Process
 142       55468 417912251          0  0.00%  0.02%  0.00%   0 Mwheel Process
 143     1679616  15634378        107  0.00%  0.00%  0.00%   0 IP SNMP
 144      613892   7818447         78  0.00%  0.00%  0.00%   0 PDU DISPATCHER
 145     3824512   7818551        489  0.00%  0.00%  0.00%   0 SNMP ENGINE
 148       84104  42317428          1  0.00%  0.00%  0.00%   0 NTP
 149          56    696599          0  0.00%  0.00%  0.00%   0 DHCPD Database
MH-NMVIKROLI-NMDC-RT-C2861-1.146#show interface
GigabitEthernet0/0 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0007.0e1f.5550 (bia 0007.0e1f.5550)
  Internet address is 202.87.34.66/30
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is T
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:05, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     153002010 packets input, 245921299 bytes, 0 no buffer
     Received 12745 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast, 12 pause input
     299347835 packets output, 2931995753 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0007.0e1f.5551 (bia 0007.0e1f.5551)
  Internet address is 172.16.1.146/16
     reliability 254/255, txload 1/255, rxload 96/255
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 1/75/1505667/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 379045000 bits/sec, 166859 packets/sec
  5 minute output rate 2000 bits/sec, 3 packets/sec
     4208056531 packets input, 3419334905 bytes, 548 no buffer
     Received 2945866398 broadcasts, 0 runts, 0 giants, 1302290 throttles
     18102253 input errors, 0 CRC, 0 frame, 4 overrun, 18102305 ignored
     0 watchdog, 0 multicast, 0 pause input
     166208494 packets output, 3186731516 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 18107918 pause output
Serial0/1/0 is administratively down, line protocol is down
  Hardware is GT96K Serial
  MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Last input never, output never, output hang never
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 carrier transitions
     DCD=down  DSR=down  DTR=down  RTS=down  CTS=down
Loopback0 is up, line protocol is up
  Hardware is Loopback
  MTU 1514 bytes, BW 8000000 Kbit, DLY 5000 usec,
  Encapsulation LOOPBACK, loopback not set
  Output queue: 0/0 (size/max)
Loopback1 is up, line protocol is up
  Internet address is 202.87.34.68/32
  Last input 00:09:53, output never, output hang never
     3 packets output, 213 bytes, 0 underruns
Loopback2 is up, line protocol is up
  Internet address is 202.87.34.70/32
Loopback3 is up, line protocol is up
  Internet address is 202.87.34.71/32
Loopback4 is up, line protocol is up
  Internet address is 202.87.34.72/32
Loopback5 is up, line protocol is up
  Internet address is 202.87.34.73/32
Loopback6 is up, line protocol is up
  Internet address is 202.87.34.74/32
Tunnel0 is up, line protocol is up
  Hardware is Tunnel
  Description: ***GRE Tunnel to WebWorks DC***
  Internet address is 10.10.101.17/30
  MTU 1514 bytes, BW 9 Kbit, DLY 500000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 202.87.34.71, destination 180.149.240.17
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255
  Fast tunneling enabled
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input never, output 00:00:13, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 93
     56224830 packets output, 270921831 bytes, 0 underruns
Tunnel1 is up, line protocol is up
  Hardware is Tunnel
  Description: ***NMG BLORE GRE***
  Internet address is 10.10.100.1/30
  Keepalive not set
  Tunnel source 202.87.34.68, destination 180.179.234.74
  Tunnel TTL 255
  Last input 00:00:02, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 87
     145911085 packets input, 1927225111 bytes, 0 no buffer
     141413831 packets output, 4184760924 bytes, 0 underruns
Tunnel2 is administratively down, line protocol is down
  Hardware is Tunnel
  Description: ***NMG_Banglore_GRE***
  Internet address is 10.10.101.29/30
  Keepalive not set
  Tunnel source 202.87.34.74, destination 180.179.234.74
  Tunnel TTL 255
  Last input never, output 1y3w, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 33
     90973031 packets output, 1692808797 bytes, 0 underruns
Tunnel4 is administratively down, line protocol is down
  Hardware is Tunnel
  Description: ***Tunnel for UAT***
  Internet address is 10.10.101.21/30
  Keepalive not set
  Tunnel source 202.87.34.72, destination 180.179.100.178
  Tunnel TTL 255
  Last input 1y3w, output 1y2w, output hang never
     442272 packets output, 30702706 bytes, 0 underruns
Tunnel5 is administratively down, line protocol is down
  Hardware is Tunnel
  Description: ***NMG Chennai GRE***
  Internet address is 10.10.101.25/30
  Keepalive not set
  Tunnel source 202.87.34.73, destination 180.179.33.250
  Tunnel TTL 255
  Last input 1y0w, output 1y0w, output hang never
     924990 packets input, 67713388 bytes, 0 no buffer
     2378304 packets output, 441529376 bytes, 0 underruns
MH-NMVIKROLI-NMDC-RT-C2861-1.146#show ip cef if runningshow ip cef if running
% Invalid input detected at '^' marker.
MH-NMVIKROLI-NMDC-RT-C2861-1.146#show ip cef if running            f
Prefix              Next Hop             Interface
0.0.0.0/0           202.87.34.65         GigabitEthernet0/0
0.0.0.0/32          receive
10.10.100.0/30      attached             Tunnel1
10.10.100.0/32      receive
10.10.100.1/32      receive
10.10.100.3/32      receive
10.10.101.16/30     attached             Tunnel0
10.10.101.16/32     receive
10.10.101.17/32     receive
10.10.101.19/32     receive
172.16.0.0/16       attached             GigabitEthernet0/1
172.16.0.0/32       receive
172.16.1.1/32       172.16.1.1           GigabitEthernet0/1
172.16.1.7/32       172.16.1.7           GigabitEthernet0/1
172.16.1.8/32       172.16.1.8           GigabitEthernet0/1
172.16.1.146/32     receive
172.16.1.182/32     172.16.1.182         GigabitEthernet0/1
172.16.3.59/32      172.16.3.59          GigabitEthernet0/1
172.16.3.251/32     172.16.3.251         GigabitEthernet0/1
172.16.255.255/32   receive
172.17.10.0/24      172.16.1.1           GigabitEthernet0/1
172.17.11.0/24      172.16.1.1           GigabitEthernet0/1
172.17.12.64/32     172.16.1.1           GigabitEthernet0/1
172.17.13.0/24      172.16.1.1           GigabitEthernet0/1
172.24.41.0/24      172.16.1.1           GigabitEthernet0/1
172.24.41.39/32     172.16.1.1           GigabitEthernet0/1
172.24.41.40/32     172.16.1.1           GigabitEthernet0/1
172.24.41.44/32     172.16.1.1           GigabitEthernet0/1
172.24.41.61/32     172.16.1.1           GigabitEthernet0/1
172.24.41.68/32     172.16.1.1           GigabitEthernet0/1
172.24.41.210/32    172.16.1.1           GigabitEthernet0/1
172.26.0.0/16       172.16.1.1           GigabitEthernet0/1
192.168.0.0/24      172.16.1.1           GigabitEthernet0/1
192.168.14.0/24     172.16.1.1           GigabitEthernet0/1
192.168.24.177/32   172.16.1.1           GigabitEthernet0/1
192.168.27.0/24     attached             Tunnel0
192.168.72.0/24     attached             Tunnel1
192.168.74.0/24     172.16.1.1           GigabitEthernet0/1
192.168.76.0/24     attached             Tunnel1
192.168.120.0/24    172.16.1.1           GigabitEthernet0/1
192.168.121.0/24    172.16.1.1           GigabitEthernet0/1
192.168.130.0/24    172.16.1.1           GigabitEthernet0/1
192.168.140.0/24    172.16.1.1           GigabitEthernet0/1
192.168.142.115/32  172.16.1.1           GigabitEthernet0/1
192.168.142.160/29  172.16.1.1           GigabitEthernet0/1
192.168.142.201/32  172.16.1.1           GigabitEthernet0/1
192.168.142.202/32  172.16.1.1           GigabitEthernet0/1
192.168.142.203/32  172.16.1.1           GigabitEthernet0/1
192.168.142.204/32  172.16.1.1           GigabitEthernet0/1
192.168.149.251/32  172.16.1.1           GigabitEthernet0/1
192.168.160.0/24    172.16.1.1           GigabitEthernet0/1
192.168.175.202/32  172.16.1.1           GigabitEthernet0/1
192.168.180.0/24    172.16.1.1           GigabitEthernet0/1
192.168.189.25/32   172.16.1.1           GigabitEthernet0/1
192.168.189.26/32   172.16.1.1           GigabitEthernet0/1
192.168.189.27/32   172.16.1.1           GigabitEthernet0/1
192.168.191.213/32  172.16.1.1           GigabitEthernet0/1
202.87.34.64/30     attached             GigabitEthernet0/0
202.87.34.64/32     receive
202.87.34.65/32     202.87.34.65         GigabitEthernet0/0
202.87.34.66/32     receive
202.87.34.67/32     receive
202.87.34.68/32     receive
202.87.34.70/32     receive
202.87.34.71/32     receive
202.87.34.72/32     receive
202.87.34.73/32     receive
202.87.34.74/32     receive
224.0.0.0/4         0.0.0.0
224.0.0.0/24        receive
255.255.255.255/32  receive
you are running a very old IOS version on and end of life / end of sale router.
There used to be a way to create a CPU profile and find out where the CPU spends its time. Your output does not show a specific process that is responsible for the high CPU, so you might want to create a profile:
https://community.cisco.com/t5/routing/cpu-profiling-cisco-router/td-p/1028639
https://www.cisco.com/c/en/us/support/docs/routers/7500-series-routers/41120-highcpu-interrupts.html#cd
Looking at both your high interrupt CPU utilization and the 5 minute 379 Mbps on your one gig interface, I suspect you've just hit the performance limits of a 2821 (which is not really a gig capable router although it has gig interfaces).
