2900 router Web portal without authentication
Michael Durham
Level 4
Level 4
I have a 2911 router with some custom .html pages that I am storing on the flash drive.  I need for users to be able to JUST access and click links on this custom page WITHOUT the need to enter router login credentials.  This of this as a micro web server that delivers .pdf files to the user.  There is no reason for them to have to logon.
5 Replies 5
Cristian Matei
    It's not recommended, for security reasons to run a "web server" on your router, especially unauthenticated. If you want fo it, ensure the web serves is reachable only from the subnets you want, to minimise the impact. Here's the config:
aaa new-model
aaa authentication login HTTP_LOGIN none
access-list 10 permit 1.1.1.1
ip http server
ip http access-class 10
ip http authentication aaa login-authentication HTTP_LOGIN
   Take note that when you enable aaa, the VTY line automatically convert from line password authentication, to username/password authentication, so if you don't have a username/password configured, you'll loose remote access via telnet/ssh.
Cristian Matei.
I tried that and it still asks for the password.  All I need is for it to be in the view mode.  This internal router web server only allows internal users to download IP phone manuals in the .pdf format.  We will SSH for any router config changes needed.
The code I put in:
aaa new-model
aaa authentication login default local
aaa session-id common
username guest privilege 5 password 7 0705F4D06
username test privilege 15 password 7 000750754
ip forward-protocol nd
ip http server
ip http access-class 20
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:GUI
access-list 20 remark Networks Allowed onto the router's web server
access-list 20 permit 1.2.3.4
access-list 20 permit 192.168.100.0 0.0.0.255
Giving what I am trying to do, would using the interface Embedded-Service-Engine0/0 meet my needs?
   Can you just click on the OK button, without adding any credentials?
Cristian Matei
It just comes back again.  I even tried Chrome browser, same results.
    The configuration is correct, so either you're hitting a bug, either unauthenticated access to the GUI is no longer allowed, probably due to security reasons. Why don't you have a username/password that everyone can use, if you don't really care about authentication?
Cristian Matei.
