2901 Configuration Question
davidk
Let me start by saying I am not an expert in configuring Cisco routers.  I'm trying to figure out what service or what I have enabled in my config allowing the open ports on a 2901 cisco router. The router is a passthrough to a firewall so I do not want any ports open on the public side. Any help would be appreciated!
NMAP results below:
PORT STATE SERVICE
25/tcp filtered smtp
465/tcp filtered smtps
1099/tcp filtered rmiregistry
3369/tcp filtered satvid-datalnk
8873/tcp filtered dxspider
Basic Config:
This is the running config of the router: xxxxx
!version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname xxxx
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 xxx
enable password 7 xxxx
no aaa new-model
clock timezone PCTime -5 0
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no ipv6 cef
no ip source-route
ip cef
no ip bootp
server
ip
domain name
xxxx.com
crypto
pki
token default removal timeout 0
license udi pid xx sn xx
ip tcp synwait-time 10
interface Embedded-Service-Engine0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
interface GigabitEthernet0/0
description $ES_LAN$
ip address xxxxx 255.255.255.192
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed
auto
no mop enabled
interface GigabitEthernet0/1
description $ES_WAN$
ip address xxxxx 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
duplex auto
speed auto
no mop enabled
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 xxxxxx
logging trap debugging
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output none
stopbits 1
line vty 0 4
password XXX
no login
transport input none
scheduler allocate 20000 1000
end
7 Replies 7
paulstone80
Level 3
Level 3
Hi David,
As there are no ACL's applied to any of the interfaces, the router will not being performing any traffic filtering, so it will allow everything through that it has a matching route for.
Paul
****Please rate useful posts****
HTH Paul ****Please rate useful posts****
That makes sense. My only concern is with my nmap results below I read that as someone could connect to ports 25, 465 etc. to the router and attempt altering the configuration etc. vs traffic just passing through.  Am I not interperating this correctly? Thanks for the feedback.
When you run nmap, are you targetting an IP on one of the routers' interfaces?
Paul
Yes the public facing WAN.
Sorry that was for the lan interface which I was surprised at the results.  The wan side only looks like SMTP is open.
PORT STATE SERVICE
Ah ok. If you run 'show control-plane host open-ports' you'll see what service/process on the router has the ports opened.
You can also use 'show ip sockets' but it does not show the process/service.
Paul
My concern is I had a company setup the device and I want to make sure its not exposed.  Do you see anything that poses vulnerability?
