Extend VLAN across WAN
johnnyenglish
My company has 3 sites with point to point connections. These are configured on the routers as layer 3 interfaces. We want to extend a couple of VLANs (VLANs 10 and 20 at site 1 and 2, (VLANs 30 and 40 at site 1 and 3) and we will also be virtualizing our routing tables. My question is, how can I extend these VLANs? Should I use MPLS between the core routers and use EoMPLS and if so, are there any issues with each router essentially being in the PE role?
J
jawad-mukhtar
Level 4
Level 4
Which Router & Swithes are you using
Jawad
vmiller
Level 7
Level 7
You could take a look at this:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtl2tpv3.html
Why not just route? is there a technical reason to extend VLANS?
