2901 router, ACL with object-group, stops working after a router reboot
arunjangid
Hi all,
i have a cisco 2901 running (C2900-UNIVERSALK9-M), Version 15.1(1)T2) with 2 built in interfaces, with no additional cards installed. On the interface gi0/0 there is an inbound ACL using one object-group network with a bunch of hosts. The ACL works fine untill the router is rebooted, after a reboot no conditions of the ACL get hits and all traffic gets logged by the last ACL statement of deny any any log. Removing the ACL and typing it in again makes it to work all good again unitll it is rebooted again. Any known issue with particular IOS version with a bug of some sort? Any IOS recommendations to upgrade to?
Arun
paolo bevilacqua
Wrong forum, post in "Infrastructure, WAN and routing". You can move your post using the actions panel on the right.
SOcchiogrosso
Level 4
Level 4
I'd speak to TAC in reference to which IOS version to upgrade to.
You typically don't go wrong with the latest release but don't quote me.
Sent from Cisco Technical Support Android App
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
