how to find out other dhcp server in my network?
CHUN FAI LAW
i have my own network with dhcp pool already, how can i find that if there is some client connection their own dhcp server to my network?
how can i find that though my router? i know it can be prevent by dhcp snooping. but due to some of our switch not support this function.
Is there any suggestion or anything i can check the problem through my router?
5 Replies 5
Paul Preston
Hi Chun,
I can't think of a specific command on the IOS router to discover dhcp servers - I don't believe there is one.
Why don't you simply setup "ip address dhcp" on the interface connected to that network and check whether you have received an ip address?
Paul Preston
Proxar IT Ltd. Registered in England and Wales: 6744401- VAT: 942985479
Tubs Hill House, London Road, Sevenoaks, Kent, TN13 1BL
Tel:  (+44) 0844 809 4335
Fax: (+44) 01732 468 574
Mob: (+44) 077 9509 3450
Web: www.proxar.co.uk
Email: paul.preston@proxar.co.uk
Paul Preston
Cisco Support Team
may be i can simply check the client computer, and find the source mac with arp -a
and then search the mac address in switch mac address table to find where is the source dhcp server...haha
SOcchiogrosso
Level 4
Level 4
There are many different ways:
1. Packet capture looking dhcp offer packets
2. Configure dhcp snooping on your LAN switches
3. So an ipconfig /all on the client (windows) PC to see the IP address of the dhcp server or received its address from
Sent from Cisco Technical Support Android App
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
CHUN FAI LAW
Thankyou for your advice, i think capture program is one of the good tools to get the rogue dhcp.
SOcchiogrosso
Level 4
Level 4
It will also be very time consuming unless you trigger the dhcp process manually
