01-05-2015 04:05 AM - edited 03-05-2019 12:29 AM
my cisco router 2911/k9 with release 15.2(4)m6a lose default and static routing table entry every day, and after a reload the entry came back to my routing table.
this is an extract of my config:
interface Serial0/0/0:0
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type cisco
interface Serial0/0/0:0.1 point-to-point
ip address xxxxx.1
ip access-group 100 in
ip load-sharing per-packet
ip inspect cccc in
no cdp enable
frame-relay interface-dlci 100
interface Serial0/1/0:0
no ip address
interface Serial0/1/0:0.1 point-to-point
ip address yyyyy.1
ip inspect cccc in
no cdp enable
ip route 0.0.0.0 0.0.0.0 xxxxx.2
ip route 0.0.0.0 0.0.0.0 yyyyyy.2
and more ip route static specific
Please, Who can help me? Can be a bug ?
01-05-2015 05:09 AM
It could be a bug but at this point, I am not that bold to assume that. We need more information.
Best regards,
Peter
01-05-2015 06:54 AM
1 the frame relay connection don't flap.
2 wait time for log.
3 they completely disappear from routing table, but stay configured, dissappear static route, default and directly connected route. i don't verify the configuration, but after reload the problem was solved.
4 i wai for log. But i can't see nothing.
01-05-2015 08:13 AM
Are snmp community protected by ACL? Btw don't use default private/public community.
Also check access-list on line vty.
01-05-2015 09:06 AM
i put limited access on snmp and vty.
01-05-2015 09:13 AM
There are strange activity on the internet. Some malware software try to find devices with default community and disable ip routing ;-)
01-05-2015 09:29 AM
thank you, maybe...
at the moment i wait the event to observe the log.
