2911 Router Mitigation 4431 Router Cyrpto Map
Portfast
We apply cyrpto map under port-channel on 2911 router. The new 4431 router also does not allow entering this definition. What is the best method you can suggest to solve this? We do not have control of the other party. Is there a way to run the tunnel running from this interface without making any changes on the other side?
config-if)#crypto map XnameX
% NOTE: crypto map is configured on tunnel or port-channel interface.
        Currently only GDOI crypto map is supported on tunnel or port-channel interface.
9 Replies 9
Richard Burts
The post describes a 2911 router with a port channel and a crypto map applied to the port channel and asks this question " Is there a way to run the tunnel running from this interface without making any changes on the other side?". There is much that we do not know about this environment but one thing we can say with confidence is that if you are trying to accomplish encryption of traffic going over the tunnel then no it is not possible to implement this without making changes on the other side.
Rick
That true' new router not accept add crypto map under the interface'
For tunnel you dont need anything except IP to tunnel and route toward tunnel head
Interface tunnel 0
Tunnel source <portchannel interface >
Tunnel destination <peer port channel IP>
Tunnel protection ipsec profile <name>
And instead of use acl use static route
Ip route  remote-lan tunnel-head
MHM
Giuseppe Larosa
Hello @Portfast ,
support for crypto map has been removed in latest IOS XE and you need to use  a static VTI configuration instead.
consider the config example provided by @MHM Cisco World
Hope to help
Giuseppe
since you can only migrate one (your) side, and you have no control of the other side, check the document linked below:
https://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-ipsec/white-paper-c11-744879.pdf
Portfast
hello all
I will create a test area and try it today. Thank you for your support
I recheck my note yesterday'
In IOS XE 16.12 and later you can use vti (tunnel) to connect to legacy crypto map router'
So since 4431 can not support legacy you can use vti as I mention before and peer no need to change it crypto map but in 4431 add
Tunnel protection ipsec police ipv4 <Acl>
This make your VTI in 4431 work as legacy crypto map
MHM
Portfast
greetings to everyone
I applied the mitigation document but it did not work. Below I share the debug errors I received. As I said, I have no information about the configuration of the other site. I only know it does ipsec with Cisco ASA firewall
If you have anything to suggest, I'd love to hear it.
ar  5 21:03:42.489: ISAKMP-ERROR: (0):Encryption algorithm offered does not match policy!
Mar  5 21:03:42.489: ISAKMP-ERROR: (0):atts are not acceptable. Next payload is 3
Mar  5 21:03:42.489: ISAKMP-ERROR: (0):Encryption algorithm offered does not match policy!
Mar  5 21:03:42.495: %CRYPTO_ENGINE-3-CSDL_COMPLIANCE_FAIL: Cisco PSB security compliance violation is detected. Use of MD5 by Crypto IKMP is denied
Mar  5 21:03:42.495: ISAKMP-ERROR: (0):failed to set SKEYID
Mar  5 21:03:50.959: %CRYPTO-5-IKMP_AG_MODE_DISABLED: Unable to initiate or respond to Aggressive Mode while disabled
Mar  5 21:03:50.959: ISAKMP-ERROR: (0):No pre-shared key with 212.x.x.x!
Mar  5 21:03:50.959: ISAKMP-ERROR: (0):No Cert or pre-shared address key.
Mar  5 21:03:50.960: ISAKMP-ERROR: (0):construct_initial_message: Can not start Main mode
Mar  5 21:03:50.961: ISAKMP-ERROR: (0):Error while processing SA request: Failed to initialize SA
Mar  5 21:03:50.961: ISAKMP-ERROR: (0):Error while processing KMI message 0, error 2.
Mar  5 21:03:56.081: %CRYPTO-5-IKMP_AG_MODE_DISABLED: Unable to initiate or respond to Aggressive Mode while disabled
Mar  5 21:03:56.081: ISAKMP-ERROR: (0):No pre-shared key with 212.x.x.x!
Mar  5 21:03:56.082: ISAKMP-ERROR: (0):No Cert or pre-shared address key.
Mar  5 21:03:56.082: ISAKMP-ERROR: (0):construct_initial_message: Can not start Main mode
Mar  5 21:03:56.083: ISAKMP-ERROR: (0):Error while processing SA request: Failed to initialize SA
Mar  5 21:03:56.083: ISAKMP-ERROR: (0):Error while processing KMI message 0, error 2.
Mar  5 21:04:00.583: ISAKMP-ERROR: (0):deleting SA reason "Death by retransmission P1" state (R) MM_SA_SETUP (peer 192.168.225.18)
Mar  5 21:04:01.714: %CRYPTO-5-IKMP_AG_MODE_DISABLED: Unable to initiate or respond to Aggressive Mode while disabled
Mar  5 21:04:01.714: ISAKMP-ERROR: (0):No pre-shared key with 212.x.x.x!
Mar  5 21:04:01.714: ISAKMP-ERROR: (0):No Cert or pre-shared address key.
Mar  5 21:04:01.715: ISAKMP-ERROR: (0):construct_initial_message: Can not start Main mode
Mar  5 21:04:01.716: ISAKMP-ERROR: (0):Error while processing SA request: Failed to initialize SA
Mar  5 21:04:01.716: ISAKMP-ERROR: (0):Error while processing KMI message 0, error 2.
Mar  5 21:04:06.038: ISAKMP-ERROR: (0):Hash algorithm offered does not match policy!
Mar  5 21:04:06.038: ISAKMP-ERROR: (0):atts are not acceptable. Next payload is 3
Mar  5 21:04:06.038: ISAKMP-ERROR: (0):Encryption algorithm offered does not match policy!
Mar  5 21:04:06.038: ISAKMP-ERROR: (0):atts are not acceptable. Next payload is 0
Mar  5 21:04:06.056: ISAKMP: (1462):No NAT Found for self or peer
Mar  5 21:04:06.089: ISAKMP-ERROR: (1462):IPSec policy invalidated proposal with error 8
Mar  5 21:04:06.090: ISAKMP-ERROR: (1462):IPSec policy invalidated proposal with error 8
Mar  5 21:04:06.091: ISAKMP-ERROR: (1462):IPSec policy invalidated proposal with error 8
Mar  5 21:04:06.092: ISAKMP-ERROR: (1462):IPSec policy invalidated proposal with error 8
Mar  5 21:04:06.093: ISAKMP-ERROR: (1462):IPSec policy invalidated proposal with error 8
Mar  5 21:04:06.094: ISAKMP-ERROR: (1462):IPSec policy invalidated proposal with error 8
Mar  5 21:04:06.095: ISAKMP-ERROR: (1462):IPSec policy invalidated proposal with error 8
Mar  5 21:04:06.095: ISAKMP-ERROR: (1462):phase 2 SA policy not acceptable! (local 172.16.0.22 remote 10.210.36.1)
Mar  5 21:04:06.095: ISAKMP-ERROR: (1462):deleting node 2997991346 error TRUE reason "QM rejected"
Mar  5 21:04:07.619: ISAKMP-ERROR: (0):Encryption algorithm offered does not match policy!
Mar  5 21:04:07.619: ISAKMP-ERROR: (0):atts are not acceptable. Next payload is 3
Mar  5 21:04:07.619: ISAKMP-ERROR: (0):Hash algorithm offered does not match policy!
Mar  5 21:04:07.619: ISAKMP-ERROR: (0):atts are not acceptable. Next payload is 0
Mar  5 21:04:07.626: ISAKMP: (1463):No NAT Found for self or peer
Mar  5 21:04:07.642: ISAKMP-ERROR: (1463):IPSec policy invalidated proposal with error 8
Mar  5 21:04:07.643: ISAKMP-ERROR: (1463):IPSec policy invalidated proposal with error 8
Mar  5 21:04:07.644: ISAKMP-ERROR: (1463):IPSec policy invalidated proposal with error 8
Mar  5 21:04:07.645: ISAKMP-ERROR: (1463):IPSec policy invalidated proposal with error 8
Mar  5 21:04:07.646: ISAKMP-ERROR: (1463):IPSec policy invalidated proposal with error 8
Mar  5 21:04:07.647: ISAKMP-ERROR: (1463):IPSec policy invalidated proposal with error 8
Mar  5 21:04:07.648: ISAKMP-ERROR: (1463):IPSec policy invalidated proposal with error 8
Mar  5 21:04:07.648: ISAKMP-ERROR: (1463):phase 2 SA policy not acceptable! (local 172.16.0.22 remote 10.10.36.1)
Mar  5 21:04:07.649: ISAKMP-ERROR: (1463):deleting node 79940397 error TRUE reason "QM rejected"
Mar  5 21:04:12.490: ISAKMP-ERROR: (0):Encryption algorithm offered does not match policy!
Mar  5 21:04:12.490: ISAKMP-ERROR: (0):atts are not acceptable. Next payload is 3
Mar  5 21:04:12.495: %CRYPTO_ENGINE-3-CSDL_COMPLIANCE_FAIL: Cisco PSB security compliance violation is detected. Use of MD5 by Crypto IKMP is denied
Mar  5 21:04:12.495: ISAKMP-ERROR: (0):failed to set SKEYID
Mar  5 21:04:20.958: %CRYPTO-5-IKMP_AG_MODE_DISABLED: Unable to initiate or respond to Aggressive Mode while disabled
Mar  5 21:04:20.958: ISAKMP-ERROR: (0):No pre-shared key with 212x.x.x!
Mar  5 21:04:20.959: ISAKMP-ERROR: (0):No Cert or pre-shared address key.
Mar  5 21:04:20.959: ISAKMP-ERROR: (0):construct_initial_message: Can not start Main mode
Mar  5 21:04:20.960: ISAKMP-ERROR: (0):Error while processing SA request: Failed to initialize SA
Mar  5 21:04:20.960: ISAKMP-ERROR: (0):Error while processing KMI message 0, error 2.no debug all
All possible debugging has been turned off
Thanks for the update. There are a few things that I notice in the debug output:
The bottom line is that your router is seriously not in sync with the peer device (probably ASA if I interpret your post correctly). To get an encrypted tunnel to work you need to agree on certain parameters such as encryption keys, encryption algorithm, etc.
Rick
We can not know what exactly issue without know the config you use
Can you share config
MHM
