2911 router VPN Tunnel and default routing
fdouble08
I have a Cisco 2911 that I am configuring for a remote site.  I have configured a IPSec Tunnel from our main site ( ASA 5510 ).  The Tunnel is up and I can connect from the main site LAN to the address of the 2911 through the IPSec Tunnel.  The 2911 is equipped with a 16port switch service module.  The switch is configured with an address and I can open a telnet session to the switch.  From that session, I am able to reach hosts on the LAN across the IPSec tunnel.  However, when I open a telnet session to the 2911 router, I cannot reach hosts on the main site LAN from that address.  When I do, the traffic is sent outside of the tunnel instead of inside it.  It works from the service module as traffic between the interfaces have the ACL for insteresting traffic applied, but traffic generated from the address of the 2911 router does not seem to get picked up by the ACL on the IPSec tunnel and it is getting the default route applied and going directly to the outside interface instead of to the tunnel.  Any ideas on how to make this work?
paolo bevilacqua
Seems like you have a configuration problem.
Not seeing your configuration, one cannot say which one.
Config provided.
Here's a twist:
From the CLI on the 2911, if I ping an address that is on the far side fo the tunnel, I get no response.  If I traceroute to the same address, it reveals that the traffic is not entering the tunnel and is being sent directly to the outside interface (internet).  If I issue the ping command, and specify the source address as the inside address of the 2911, it gets a response.  If I issue the traceroute and specify the source address as the inside address of the 2911, it also completes and reveals that it goes through the tunnel.  My problem is that the 2911 router needs to be able to communicate with a radius server that is on the far side of the tunnel, but by default the traffic from the 2911 to the radius server is going to the outside internet interface instead of through the IPSec tunnel.
fdouble08
Config follows:
hw-module sm 1
redundancy
ip ssh version 2
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key ***** address 46.21.190.93
crypto isakmp client configuration group IPSecTunnel1
key *****
dns 46.21.190.93
domain vlrna.vlrad.loc
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set T-Set ah-sha-hmac esp-aes 256
crypto ipsec profile Tunnel1
set security-association lifetime seconds 3600
crypto dynamic-map Tunnel1 1
set transform-set T-Set
reverse-route
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to46.21.190.93
set peer 46.21.190.93
set transform-set ESP-3DES-SHA
match address 100
crypto map Tunnel1 client configuration address respond
crypto map Tunnel1 1 ipsec-isakmp
match address Tunnel1
crypto map Tunnel1 2 ipsec-isakmp
crypto map crypto-map-1 isakmp authorization list IPSecTunnel1
interface Embedded-Service-Engine0/0
no ip address
interface GigabitEthernet0/1
description $ETH-LAN$
ip address 99.50.50.222 255.255.255.240
duplex auto
speed auto
interface GigabitEthernet1/0
description $ETH-LAN$$SWDMADDR:10.10.144.2:80$
ip address 10.10.144.1 255.255.255.0
ip helper-address 10.6.24.93
interface GigabitEthernet1/1
description Internal switch interface connected to EtherSwitch Service Module
no ip address
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 99.50.50.209
ip route 10.10.144.0 255.255.255.0 GigabitEthernet1/0
ip access-list extended Tunnel1
permit ip 10.10.144.0 0.0.0.255 any
permit ip 10.10.144.0 0.0.0.255 172.30.52.0 0.0.0.255
ip access-list extended Tunnel1end
access-list 23 permit 10.6.0.0 0.0.255.255
access-list 100 remark IPSec Rule
access-list 100 permit ip 10.10.144.0 0.0.0.255 10.0.0.0 0.255.255.255
control-plane
