2911 - %SMC-2-BAD_ID_HW and license lost after rommon upgrade
sebastian.lemke
First of all I had a 2911 with IOS c2900-universalk9-mz.SPA.151-4.M4 and ROMMON Version 15.0(1r)M6. The following licenses were installed as permanent: ipbasek9, securityk9.
Router#show version
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
When trying to upgrade to IOS c2900-universalk9-mz.SPA.152-4.M5 I received the following error message during boot:
*** Bus Error (Load) Exception ***
Access address = 0xffffffba
  PC = 0x80000a68, SP = 0x8efffd40, RA = 0x80000844
  Cause Reg = 0x4000801c, Status Reg = 0x504080e3
monitor: command "boot" aborted due to exception
I tried this on several 2911 routers, same result: All routers with ROMMON Version 15.0(1r)M6 failed to load IOS 152-4.M5. Routers with ROMMON Version 15.0(1r)M15 loaded the new IOS without any problem.
So i tried to upgrade the ROMMON on the first 2911 to the latest downloadable version from Cisco:
Router#upgrade rom-monitor file flash0:C1900_2900_RM2.srec.SPA.150-1r.M16
Platform Field Upgradeable ROMMON LOAD test
___________________________________________
RSA Signature Verification Passed ...
ROM: Digitally Signed Production Software
This command will result in a  'power-on reset' of the router!
Continue? [yes/no]: yes
ROMMON image upgrade in progress.
Erasing boot flash eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Programming boot flash pppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppp
Now Reloading
After the reboot I now receive the following error messages:
%SMC-2-BAD_ID_HW: Failed Identification Test in 0/-1/-1 [7/0]
       The module in 0/-1/-1 in this router may not be a genuine
       Cisco product.  Cisco warranties and support programs only
       apply to genuine Cisco products.  If Cisco determines that
       your insertion of non-Cisco memory, WIC cards, AIM cards,
       Network Modules, SPA cards, GBICs or other modules into a
       Cisco product is the cause of a support issue, Cisco may
       deny support under your warranty or under a Cisco support
       program such as SmartNet.
And my ipbasek9 and securityk9 licenses are lost:
Router#show version
ipbase        ipbasek9      None           ipbasek9
security      None          None           None
Show diag shows me a failed identification test:
Router#sh diag
Slot 0:
        Failed Identification Test [ 7/0 ]
        C2911 Mother board 3GE, integrated VPN and 4W Port adapter, 3 ports
        Port adapter is analyzed
        Port adapter insertion time 01:41:01 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC171*****
        Hardware Revision        : 1.0
        Part Number              : 73-11833-11
        Top Assy. Part Number    : 800-30797-06
        Board Revision           : A0
        Deviation Number         : 130603
        Fab Version              : 03
        Product (FRU) Number     : CISCO2911/K9
        Version Identifier       : V07
        CLEI Code                : CMMJD00ARA
        Processor type           : C1
        Chassis Serial Number    : FCZ163*****
        Chassis MAC Address      : bc16.654a.****
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1   (...)
So I tried to downgrade ROMMON back to Version 15.0(1r)M6. The problem stays the same.
--> What can I do to recover this router to normal operation?
--> How can I upgrade a 2911 with ROMMON Version 15.0(1r)M6 safely to IOS 152-4.M5 ?
myrdinthemyr
i know it is a veeeery old post, i am having the exact same issue and TAC can't figure it out either. I am wondering if the user managed to fixed and how.
cheers
No, this wasn't fixed unfortunately. The routers went back to our distributor...
well thanks heaps to replying on this...that does not sound promising!
