10-12-2010 07:17 AM - edited 03-04-2019 10:05 AM
I'm configuring 2921 router and connected to network, it can't ping any of the devices in our network but other hosts can telnet into it. can't telnet/ping it from any other cisco router/switch into the network.
following is the configuration:
Router#sh run
Building configuration...
Current configuration : 1698 bytes
! Last configuration change at 13:54:44 UTC Tue Oct 12 2010 by cisco
version 15.0
hostname Router
boot-start-marker
boot-end-marker
card type t1 0 0
no logging console
enable secret 5 $1$LDQB$3FOZPQ0jMgtHo30/mVCmb1
no aaa new-model
no network-clock-participate wic 0
no network-clock-participate wic 1
no ipv6 cef
ip source-route
ip cef
voice-card 0
dspfarm
license udi pid CISCO2921/K9 sn FTX1439AJ8A
hw-module pvdm 0/0
vtp mode transparent
username cisco password 0 cisco
redundancy
controller T1 0/0/0
cablelength long 0db
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 132.226.241.232 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0
no ip address
shutdown
no fair-queue
clock rate 128000
interface Serial0/1/1
no ip address
shutdown
clock rate 128000
interface Serial0/1/2
no ip address
shutdown
clock rate 128000
interface Serial0/1/3
no ip address
shutdown
clock rate 128000
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
Router#telnet 192.168.25.4
Trying 192.168.25.4 ...
% Destination unreachable; gateway or host down
please advise how do i resolve it?
Thanks...
Solved! Go to Solution.
10-12-2010 07:28 AM
Hi Gavin,
at first I would check the routing table for that destination.
From your configuration you should only have the connected routes in table, so I don't see how the router should know how to reach 192.168.25.4.
Please configure any route for that and try again (ex. ip route 192.168.25.4 255.255.255.255
Antonio
10-12-2010 07:26 AM
topology is as follow:
switch interface:
interface FastEthernet1/0/3
switchport access vlan 3
speed 100
duplex full
no mdix auto
please advise...
10-12-2010 08:53 AM
Gavin,
If this router is new to the network, make sure of a few things:
1. As a previous post stated, make sure that the interface is addressed in the same subnet as the facing interface.
The configs shows:
duplex auto
speed auto
and you are trying:
As far as other devices being able to telnet to it, its quite possible that they are actually hitting another device.
2. Make sure that the two interfaces on the the switch are in the same vlan (looks like vlan 3 from your post) or that IP routing is enabled on the switch if its an L3 switch. If it is, what is the IP address of VLAN 3?
10-12-2010 07:28 AM
Hi Gavin,
Antonio
