07-05-2011 01:31 PM - edited 03-04-2019 12:53 PM
I have a 48 port 2960 switch with 2 10/100 ports ( fa0/46-47) setup in an etherchannel with a 2950 48 port switch. I am getting total output drops on port fa0/47.
Below is some show commands, anyone have any idea's why this would be?
FastEthernet0/47 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0026.ca81.c02f (bia 0026.ca81.c02f)
Description: trunk Etherchannel link to fa0/47 switch in server
oom
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 2/255, rxload 51/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:03, output 00:00:05, output hang never
Last clearing of "show interface" counters 4d23h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 19175
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 20011000 bits/sec, 1904 packets/sec
5 minute output rate 877000 bits/sec, 1395 packets/sec
1427492496 packets input, 1872808936374 bytes, 0 no buffer
Received 2762778 broadcasts (2074949 multicasts)
0 watchdog, 2074949 multicast, 0 pause input
772408291 packets output, 340903564586 bytes, 0 underruns
FastEthernet0/46 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0026.ca81.c02e (bia 0026.ca81.c02e)
Description: trunk Etherchannel link to fa0/46 switch in server r
oom.
reliability 255/255, txload 1/255, rxload 9/255
Last input 00:00:20, output 00:00:00, output hang never
Last clearing of "show interface" counters 5d00h
5 minute input rate 3600000 bits/sec, 380 packets/sec
5 minute output rate 141000 bits/sec, 76 packets/sec
193394062 packets input, 239902766720 bytes, 0 no buffer
Received 37177 broadcasts (37175 multicasts)
0 watchdog, 37175 multicast, 0 pause input
302728942 packets output, 28654958491 bytes, 0 underruns
Switch#show platform port-asic stats drop fa0/47
Interface Fa0/47 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 25903
Weight 1 Frames 6
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Switch#show platform port-asic stats drop fa0/46
Interface Fa0/46 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 69845
Switch#sh int po1 counters errors
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize OutDiscard
s
Po1 0 0 0 0 0 1919
Port Single-Col Multi-Col Late-Col Excess-Col Carri-Sen Runts
Giants
Po1 0 0 0 0 0 0
07-06-2011 09:32 AM
That there is more traffic than 100 Mbs, consequently packets are dropped.
If you don't want drops, use gigabit.
07-06-2011 05:16 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Oversubscription of any port's bandwidth will eventually result in drops.
In your posted example, I notice there appears to be a (temporary?) load imbalance between the two ports. Changing the Etherchannel hash algorithm, if possible, might better distribute the load across both links and perhaps reduce the occurrence of oversubscription.
If your oversubscription is transient, adjusting buffer resource allocations might also reduce the occurrence of drops. This might especially pertain to your traffic as your hardware queue drop stats only show drops on two queues for one weight.
