2960X-40LPS-L switch ports unable to ping
Hello Team,
I Am having troubling in pinging the switch. Switch is connected to my laptop and i have created a basic Valn 1.
Switch#config t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#int Vlan 1
Switch(config-if)#ip add
Switch(config-if)#ip address 192.168.1.1 255.255.255.0
Switch(config-if)#no shut
Switch(config-if)#exit
Switch(config)#exit
Switch#wr mem
Building configuration...
Mar 30 01:46:59.554: %SYS-5-CONFIG_I: Configured from console by console[OK]
I am able to ping the ports successfully
Switch#show vlan
VLAN Name Status Ports
1 default active Gi1/0/1, Gi1/0/2, Gi1/0/3
Gi1/0/4, Gi1/0/5, Gi1/0/6
Gi1/0/7, Gi1/0/8, Gi1/0/9
Gi1/0/10, Gi1/0/11, Gi1/0/12
Gi1/0/13, Gi1/0/14, Gi1/0/15
Gi1/0/16, Gi1/0/17, Gi1/0/18
Gi1/0/19, Gi1/0/20, Gi1/0/21
Gi1/0/22, Gi1/0/23, Gi1/0/24
Gi1/0/25, Gi1/0/26, Gi1/0/27
Gi1/0/28, Gi1/0/29, Gi1/0/30
Gi1/0/31, Gi1/0/32, Gi1/0/33
Gi1/0/34, Gi1/0/35, Gi1/0/36
Gi1/0/37, Gi1/0/38, Gi1/0/39
Gi1/0/40, Gi1/0/41, Gi1/0/42
Gi1/0/43, Gi1/0/44, Gi1/0/45
Gi1/0/46, Gi1/0/47, Gi1/0/48
Gi1/0/49, Gi1/0/50, Gi1/0/51
Gi1/0/52
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
Switch#
Switch#
Mar 30 01:51:08.575: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
Mar 30 01:51:10.562: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/20, changed state to up
Mar 30 01:51:11.564: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/20, changed state to up
Switch#ping 192.168.1.10
Sending 5, 100-byte ICMP Echos to 192.168.1.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/5 ms
But when connected to port 21-24
Success rate is 0 percent (0/5)
remains the same for 22, 23 and 24. SO can somebody help me understand what is the issue??? the switch is just powered on and this was the PROBLEM i was able to find.
luis_cordova
Hi vedanth@tglobalin.com,
Could you show us the configuration of the ports of your device?
Moaz.Elzhrawey
once you configured interface vlan 1, then you were able to ping 192.168.1.10 from the switch, where is this .10 is connected to ?
It should be connected to one of switch ports, so assuming that this host .10 is connected to Gi1/0/12
so, instead of sharing your config and we investigate then reply back, do the follwoing,
1- show run interface Gi1/0/12
2- copy the output.
3- config t
interface range g 1/0/1 - 48
no shutdown
### past the copied configs ###
end
copy run start
that's it, you should have it working smoothly.
*** Please rate this as helpful and correct answer if it helped you and solved your problem ***
Moaz Elzhrawey
Solutions Architect, CCIE 2x RS | DC, VCP 3x NV | DCV | DTM
+966 596822551
Moaz.Elzhrawey
2- copy the output.
3- config t
no shutdown
end
copy run start
Moaz Elzhrawey
+966 596822551
The first thing you want to do is to verify that the VLAN1 interface is up and operational.
Run the command sh interfaces vlan 1
The following should be shown, once the highlighted section shows up /up you should be fine, you may want to verify your ip configurations for your PC to ensure that it matches the assigned VLAN 1 details.
If it shows other wise as listed below down, ensure that your computer or device is connected to a port that is assigned to VLAN1.
****Please remember to rate the post****
P.Williams
