2nd subnet has no internet
erick.hemmen
Hi all,
This is about a Cisco Asa 5512-X which I configured succesfully for the first subnet to get to internet. Remotevpn to this subnet is working as wel. The Cisco has several ethernet ports and I configured an extra subnet on a new physical port. Whatever I'll try, the new subnet doesn't get to the internet. Please see my config attached below. What am I missing or what am I doing wrong?
Config:
ASA Version 8.6(1)2
hostname ASA
domain-name domain.lan
names
interface GigabitEthernet0/0
speed 100
duplex full
nameif outside
security-level 0
pppoe client vpdn group INT
ip address pppoe setroute
interface GigabitEthernet0/1
speed 100
duplex full
nameif inside
security-level 100
ip address 10.0.11.254 255.255.255.0
interface GigabitEthernet0/2
duplex full
nameif Wifi
security-level 100
ip address 192.168.11.254 255.255.255.0
interface Management0/0
nameif management
security-level 0
ip address 172.16.251.254 255.255.255.0
management-only
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network Internal
subnet 10.0.11.0 255.255.255.0
object network Vid
host 10.0.0.240
object network Wifi
subnet 192.168.11.0 255.255.255.0
object network obj_any_Wifi
access-list PermitOutsideIn extended permit icmp any any echo
access-list PermitOutsideIn extended permit icmp any any echo-reply
access-list PermitOutsideIn extended permit icmp any any source-quench
access-list PermitOutsideIn extended permit icmp any any time-exceeded
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
mtu Wifi 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (Wifi,outside) source dynamic Wifi interface
nat (inside,outside) dynamic interface
access-group PermitOutsideIn in interface outside
route outside 0.0.0.0 0.0.0.0 37.0.81.170 1
route inside 10.0.12.0 255.255.255.0 10.0.11.99 2
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable 4433
http 172.16.251.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
sysopt noproxyarp inside
telnet timeout 5
ssh 172.16.151.0 255.255.255.0 management
ssh timeout 5
console timeout 0
vpdn group INT request dialout pppoe
vpdn group INT localname ...
vpdn group INT ppp authentication pap
vpdn username ... password ***** store-local
dhcpd auto_config outside
dhcpd address 192.168.11.10-192.168.11.40 Wifi
dhcpd dns 8.8.8.8 208.67.222.222 interface Wifi
dhcpd enable Wifi
threat-detection basic-threat
threat-detection scanning-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
username admin password ***** encrypted privilege 15
olicy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map type inspect http block-url-policy
parameters
class block-url-class
  drop-connection log
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
policy-map tcp_bypass_policy
class bypass_traffic
  set connection conn-max 256 random-sequence-number disable
policy-map custom-shaper-10000kbps
class class-default
service-policy global_policy global
service-policy custom-shaper-10000kbps interface outside
prompt hostname context
Did you remove the nat(wifi,outside) source dynamic interface command?
Run the following command and paste the output:
packet-tracer input Wifi tcp 192.168.11.10 80 8.8.8.8 80
6 Replies 6
jj27
I assume the 'inside' subnet can get to the internet, but the Wifi cannot.
In that case, you're missing these command:
nat (Wifi,outside) dynamic interface
It looks like you attempted to set something up by the following command, which I do not believe you need at this point if you put in the others above:
Thank you for your answer. The inside subnet is indeed the one that has internet, the Wifi doesnt. I tried the suggested command earlier, but without any success. At this moment I'm thinking of clearing the config and starting with building the config form scratch again.
Any help is greatly appreciated.
I did remove the nat as you suggested and added the nat in the object network like this:
The trace usually isn't a problem, neither is it now, but still no internet :(:
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   0.0.0.0         0.0.0.0         outside
Phase: 2
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 3
Type: INSPECT
Subtype: inspect-http
Result: ALLOW
Config:
Phase: 4
Type: NAT
Subtype:
Result: ALLOW
Config:
Dynamic translate 192.168.11.10/80 to 137.190.181.176/166
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 992342, packet dispatched to next module
Result:
input-interface: Wifi
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
erick.hemmen
I got it working, well sort of. The config in the ASA was good after all, the switches behind the ASA are ruining the internet access. Next thing to do for now is to find out how to get this working.
Thanks jjohnston for having a look at my config.
That's good. I was beginning to go a little bit insane since it should have worked!
Good luck figuring out your switch problem.
