Calculate Power on a Nexus 5596UP
brianpjaus
                   Noob here. I have done many power calculations for non-Cisco equipment. I found a calculator "cpc" but it did not cover nexus 5k. The data sheet shows specs for the 1100W power supply, but that is just for the power supply. Do I double it because the 5596UP has two power supplies ? And as far as BTUs per hour, the Power supplies put out heat but so do the fans. So I need the BTU/hr for the entire switch. My switch has all 4 quandrants and all available ports are in use. Need accurate figures for Power, Exepected Amperage, and BTU/hr. Thanks.
0 Replies 0
