3 MB copper
Robin Heeraman
Can anyone advice. I have a T1 line is looking for faster speed. Att is proposing 2 T1 (bonded). My router is Cisco 2911/K9. Do I need sperate T1 card or in a bonded situation the line from Att come to my one existing port on the 2911.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Normally you need another T1 port.
BTW, you might look at the compression options of a 2911 especially the WAAS option.
brianwilliams99
You actually have 2 options.
1. If you have an extra HWIC slot you can purchase another VWIC3-1MFT-T1 card.
2. You can purchase a 2 port VWIC3-2MFT-T1 card.
You will also need a config like this: (slot/port maybe different in your setup)
controller T1 0/0
framing esf
clock source line primary
linecode b8zs
channel-group 1 timeslots 1-24 speed 64
controller T1 0/1
framing esf
linecode b8zs
interface Multilink1
ip address 10.31.100.22 255.255.255.252
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
interface Serial0/0:1
no ip address
encapsulation ppp
ip route-cache flow
tx-ring-limit 26
tx-queue-limit 26
no fair-queue
ppp multilink
interface Serial0/1:1
no ip address
encapsulation ppp
ip route-cache flow
tx-ring-limit 26
tx-queue-limit 26
no keepalive
no fair-queue
ppp multilink
