04-25-2012 04:00 AM - edited 03-04-2019 04:08 PM
Hi everyone,
We are having 3 internet connections coming in to one of our customer's main offices for redundancy and etc. I would like to replace the 3 routers with a one for easier support and management. One of the connections is an ADSL and the other 2 are leased lines so they terminate with an RJ45 connection.
Would something like a Cisco 2911 + HWIC ADSL card be sufficient enough or would you recommend something else?
Many thanks,
Dmitry
04-26-2012 12:33 AM
Many thanks for all your help guys!
I am probably going to go with 2 2911 routers with IPS modules and an ESW switch in front of them for failover between the routers. Hopefully the client can stretch his budget!
04-26-2012 03:08 AM
I would skup the IPS modules. They introduce a lot of complexity and cost for little or no actual benefit.
Also having a single switch introduce a single point of failure. Just connect one or two router to the circuits and be done.
Overengineering simple things is a major and common mistake in networking.
