3560x limit bandwidth on a GigabitEthernet trunk port
fabiogarcia
Hello Everyone!!
I have a P2P link between 2 Offices (layer2 link)
3560x------3560x
I need to limit the bandwidth (we pay for 10Mbps), tried the commando below but users are still getting higher speeds
SW-CORE-01#sh run int g0/20
Building configuration...
Current configuration : 182 bytes
interface GigabitEthernet0/20
description UPLINK_SD
switchport mode trunk
speed 100 <<<<<<<<<<<<<<<<<<<
srr-queue bandwidth limit 90 <<<<<<<<
mls qos vlan-based
end
I configured speed 100 and limit to 90%, so we should see a max bw of 10Mbps.. right ?
Local users sent these speedtest to us.... they can easly reach 15Mbps
Can you guys help me with that issue ?
Thanks in advance!!!
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
90% of 100 Mbps is 90 Mbps.  You want to set for 10% if you want to limit to 10 Mbps.
BTW, this command isn't exact.  I.e. you might find your bandwidth is more or less than 10 Mbps.
If you can, if you're limited to 10 Mbps logically, why not run the interface at 10 Mbps physically?
