3620 router and "WIC-1DSU-T1-V2" T1 card support.
dtochilovsky
Hello All. Anyone know if the 3620 router supports the WIC-1DSU-T1-V2 T1 WIC?
I insert the card into the NM-1FE2W Port adapter but the card is not being recognized. I get: " WIC Slot 1: Unknown WAN daughter card"
The router is running IOS version 12.2(5d) and I know that the IOS must be 12.2.17 for the card to be supported.
Do I need to just update the IOS to a newer version?
This is the output of the "show diag" on the router :
Slot 1:
NM-1FE2W Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
Top Assy. Part Number : 800-04796-01
Board Revision : G0
Deviation Number : 0-0
Fab Version : 05
PCB Serial Number : JAD061105M9
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 D7 41 01 00 C0 46 03 20 00 12 BC 01
0x10: 42 47 30 80 00 00 00 00 02 05 C1 8B 4A 41 44 30
0x20: 36 31 31 30 35 4D 39 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
FT1
Hardware revision 1.4 Board revision F1
Serial number 17175863 Part number 800-03279-04
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 2
0x20: 02 11 01 04 01 06 15 37 50 0C CF 04 00 00 00 00
0x30: 79 00 00 00 99 11 24 01 FF FF FF FF FF FF FF FF
WIC Slot 1:
Hardware revision 64.0 Board revision >5
Serial number 1379991810 Part number 800-7441222-79
Test history 0x43 RMA number 49-49-52
Connector type PCI
0x20: 04 FF 40 00 52 41 01 02 C1 8B 46 4F 43 31 31 34
0x30: 35 32 52 55 51 82 49 20 9A 05 42 41 30 03 00 81
This is the "show ver" output:
IOS (tm) 3600 Software (C3620-I-M), Version 12.2(5d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sat 02-Feb-02 01:51 by kellythw
Image text-base: 0x600089A8, data-base: 0x60A54000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
MAN-RTR-3620 uptime is 6 days, 18 hours, 59 minutes
System image file is "flash:c3620-i-mz.122-5d.bin"
cisco 3620 (R4700) processor (revision 0x81) with 49152K/16384K bytes of memory.
Processor board ID 30404845
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
3 Serial network interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Thank you.
Dmitry.
Edison Ortiz
Yup.
__
Edison.
Thank you!
