3620 router
resfat2001
Is the card WIC 1T on router 3620 support a rate of 4Mbps and if it is compatible with a V35 interface?
thanks
Collin Clark
No it is not.
HTH and please rate.
Hi ,
You need to use a NM-4T card , and you can use the two interfaces out of that for your 4 M connectivity .
Hope this helps
regards
vanesh k
is the NM-4T card supported by cisco3620?
can you please send me the router configuration of this card?
Your configuration in the earlier post is fine
interface Serial0/0
ip address 10.0.70.109 255.255.255.252
encapsulation ppp
bandwith 2048
In case if both the connecting routers are cisco , you can go for " encapsulation hdlc " also , which is by default in cisco devices.
Hope this helps
regards
vanesh k
