3640 Performance
wwbach
Relative Performance ? 3640 ? 2821
We are currently using a 3640 with an ATM (NM-1A-T3) interface and a Fast Ethernet interface. Most of the traffic is multicast udp inbound from the ATM/T3 circuit. Under load, we are dropping packets. The traffic is limited to 20mb/s. Everyone upstream swears they are getting sent so we are now focusing on the 3640. Under load, I see pretty high cpu usage using ?show proc cpu hist? ? say 40-60% with peaks up to 90%. Are we just over taxing this router? Is there something in the config that is causing the high load? If I were to look to replace this router with something faster (cost is an issue), how should I determine what router to go with? Thanks. -- Bud
Here is some of our config:
# show tech-support
------------------ show version ------------------
IOS (tm) 3600 Software (C3640-JS-M), Version 12.3(17a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Mon 12-Dec-05 16:29 by evmiller
Image text-base: 0x60008B00, data-base: 0x61F08000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3640-JS-M), Version 12.3(17a), RELEASE SOFTWARE (fc2)
Cisco uptime is 1 week, 2 days, 22 hours, 47 minutes
System image file is "flash:c3640-js-mz.123-17a.bin"
cisco 3640 (R4700) processor (revision 0x00) with 124928K/6144K bytes of memory.
Processor board ID 26878521
R4700 CPU at 100MHz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
1 FastEthernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
------------------ show running-config ------------------
Building configuration...
Current configuration : 1813 bytes
version 12.3
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cisco
boot-start-marker
boot-end-marker
logging buffered 20000 debugging
enable secret 5 <removed>
no aaa new-model
ip subnet-zero
ip tcp synwait-time 5
no ip domain lookup
no ip bootp server
ip multicast-routing
ip cef
buffers small permanent 200
buffers small max-free 300
buffers middle permanent 300
buffers middle max-free 500
interface Loopback0
no ip address
shutdown
interface FastEthernet0/0
ip address 172.21.x.x 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim neighbor-filter PIMFilter
ip pim sparse-mode
no ip mroute-cache
duplex auto
speed auto
no cdp enable
hold-queue 200 in
interface ATM1/0
no ip address
atm scrambling cell-payload
no atm ilmi-keepalive
hold-queue 200 in
interface ATM1/0.1 point-to-point
ip address 172.20.x.x 255.255.255.252
ip pim sparse-mode
pvc 1/40
vbr-nrt 44209 44209 1
oam-pvc manage 30
oam ais-rdi 30 3
encapsulation aal5snap
no ip http server
ip classless
ip route 65.164.x.x 255.255.255.0 172.20.x.x
ip route 204.167.x.x 255.255.255.0 172.20.x.x
ip pim bidir-enable
ip pim rp-address 65.164.x.x WAN
ip pim spt-threshold infinity
ip access-list standard PIMFilter
deny any
ip access-list standard WAN
permit 233.119.160.0 0.0.0.63
deny any
no logging trap
no cdp run
snmp-server community <removed> RO
line con 0
exec-timeout 0 0
login
line aux 0
login
transport input all
line vty 0 5
exec-timeout 120 0
password 7 <removed>
logging synchronous
login
length 0
end
7 Replies 7
jackyoung
Level 6
Level 6
The config. looks fine, I could like to clarify is there any external factor to cause the problem.
Could you please also provide the capture of "sh process cpu" and "sh interface" ?
Moreover, if it is possible, try to upgrade the router to a more updated release (e.g. 12.3(20) and test again.
Hope this helps.
Thanks for looking at this Jack (or anyone else). Here is the info you
asked for. Looks like "IP Input" is the only thing using CPU time.
As for any external factors, nothing I can think of other than a fair
amount of udp multicast traffic which is sometimes bursty as it is
market data. We should be limited to less than 20mb/sec -- should the
3640 be able to handle that? I can try to get a new IOS -- do you
think that is likely to make that much of a difference?
If we were to upgrade the router, any recommendations as to what would
be the most cost effective router to go with to support this application?
I know there are other sites handling this traffic with a 2811 but they
are getting the feed over metro ethernet not atm.
-- Bud
[note: snipped everything with less than 100ms runtime]
Cisco#sh process cpu
CPU utilization for five seconds: 39%/21%; one minute: 41%; five minutes: 48%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
2 740 220513 3 0.00% 0.00% 0.00% 0 Load Meter
3 7056 14331 492 0.00% 0.00% 0.00% 0 IP SNMP
5 532256 112331 4738 0.00% 0.04% 0.03% 0 Check heaps
12 17664 48191 366 0.00% 0.00% 0.00% 0 ARP Input
13 664 275604 2 0.00% 0.00% 0.00% 0 HC Counter Timer
18 1064 1102560 0 0.00% 0.00% 0.00% 0 GraphIt
21 1084 220528 4 0.00% 0.00% 0.00% 0 Net Background
23 1460 1102452 1 0.00% 0.00% 0.00% 0 TTY Background
24 7444 1102589 6 0.00% 0.01% 0.00% 0 Per-Second Jobs
36 864 220514 3 0.00% 0.00% 0.00% 0 Compute load avg
37 380320 18403 20666 0.00% 0.04% 0.00% 0 Per-minute Jobs
41 2388 115301 20 0.00% 0.00% 0.00% 0 ATM Periodic
43 21852 85805 254 0.00% 0.00% 0.00% 0 ATM OAM Input
44 1244 50971 24 0.00% 0.00% 0.00% 0 ATM OAM TIMER
50 25886684 27503210 941 17.75% 19.38% 22.66% 0 IP Input
58 692 1102456 0 0.00% 0.00% 0.00% 0 PI MATM Aging Pr
65 5536 4306922 1 0.00% 0.00% 0.00% 0 SSS Feature Time
66 156 2370 65 0.00% 0.00% 0.00% 0 TCP Timer
72 812 36611 22 0.00% 0.00% 0.00% 0 IP Background
81 5844 548365 10 0.00% 0.00% 0.00% 0 ILMI Timer Proce
85 1532 1102469 1 0.00% 0.00% 0.00% 0 ATMSIG Timer
96 276 18382 15 0.00% 0.00% 0.00% 0 Adj Manager
98 6164 1758280 3 0.00% 0.00% 0.00% 0 CEF process
100 1568 1102473 1 0.00% 0.00% 0.00% 0 RUDPV1 Main Proc
102 568 1102467 0 0.00% 0.00% 0.00% 0 bsm_xmt_proc
112 168 111 1513 0.00% 0.00% 0.00% 130 Virtual Exec
114 100 2 50000 0.00% 0.00% 0.00% 0 CCVPM_HDSPRM
124 2568 7166 358 0.00% 0.00% 0.00% 0 PDU DISPATCHER
129 768 38238 20 0.00% 0.00% 0.00% 0 CEF Scanner
130 1384 1836257 0 0.00% 0.00% 0.00% 0 Inline Power
132 792 1102016 0 0.00% 0.00% 0.00% 0 trunk conditioni
134 26628 1140960 23 0.07% 0.01% 0.00% 0 IGMP Input
135 16676 11016870 1 0.15% 0.02% 0.00% 0 Mwheel Process
136 15380 1230412 12 0.15% 0.02% 0.00% 0 PIM Process
137 12220 11017764 1 0.00% 0.01% 0.00% 0 fastblk backgrou
140 14544 7167 2029 0.00% 0.00% 0.00% 0 SNMP ENGINE
143 256 123 2081 0.00% 0.07% 0.03% 131 Virtual Exec
Cisco#show interface
FastEthernet0/0 is up, line protocol is up
Hardware is AmdFE, address is 0008.2156.0b40 (bia 0008.2156.0b40)
Description: LAN segment
Internet address is 172.21.x.x/27
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 2/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 3d00h
Input queue: 1/200/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2000 bits/sec, 2 packets/sec
5 minute output rate 799000 bits/sec, 721 packets/sec
944066 packets input, 213139879 bytes
Received 538438 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
11297627 packets output, 1671881286 bytes, 0 underruns
0 lost carrier, 0 no carrier
ATM1/0 is up, line protocol is up
Hardware is RS8234 ATM DS3
MTU 4470 bytes, sub MTU 4470, BW 45000 Kbit, DLY 190 usec,
reliability 255/255, txload 1/255, rxload 4/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5
1023 maximum active VCs, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Input queue: 19/200/324555/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: Per VC Queueing
5 minute input rate 785000 bits/sec, 718 packets/sec
11334587 packets input, 1651601993 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
425646 packets output, 41411309 bytes, 0 underruns
ATM1/0.1 is up, line protocol is up
Description: PVC on WAN
Internet address is 172.20.x.x/30
MTU 4470 bytes, BW 45000 Kbit, DLY 190 usec,
Encapsulation ATM
11659142 packets input, 1698107996 bytes
17490 OAM cells input, 17490 OAM cells output
AAL5 CRC errors : 0
AAL5 SAR Timeouts : 0
AAL5 Oversized SDUs : 0
AAL5 length violation : 0
AAL5 CPI Error : 0
2197880768 packets input, 2680635648 bytes
132062473 packets output, 2680548148 bytes
Loopback0 is administratively down, line protocol is down
Hardware is Loopback
MTU 1514 bytes, BW 8000000 Kbit, DLY 5000 usec,
Encapsulation LOOPBACK, loopback not set
Last input never, output never, output hang never
Output queue: 0/0 (size/max)
0 packets input, 0 bytes, 0 no buffer
0 packets output, 0 bytes, 0 underruns
Thanks for the info., it looks like the IP inputs took part of the cpu process but the overall loading is not high. I believe it does not require to upgrade the router at the moment, you can consider if the router loading up to 70% then start to plan to upgrade the router. The router model depends on your future requirement. It is hard to tell.
For the interface capture, I found there are lots of broadcast received from Ethernet. I believe it is the traffic that you mentioned of multicast. There is no abnormal symptom at all interfaces, it is healthy.
The 3640 should be able to handle 20Mbps bandwidth, but the issue is the no. of packet per second that it can handle. Checked CCO, 3640 able to support 50-70kpps that you router should far enough to carry the traffic.
You can use traffic policier to limit the througput of different kind of traffic. Check below for more info.
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800a3a25.shtml
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a00801b2404.html
Hope this helps.
Check the attached file. It may show better why I believe the 3640 doesn't have enough juice for this application. We are getting peaks to 100%.
-- Bud
Probabaly way overkill but we upgraded to an 3825 and now we are at 15% CPU max and no dropped packets,
Sorry for missing your pervious message.
Thanks for the update, this is good to know the upgrade solved the problem. I believe there is hardware accerlation in 38xx to load share the CPU loading. :)
