VPN Issue
ajayvmccie
Please let me know if Cisco Router 3600 series can support bandwidth of 512 K IPVPN
spremkumar
Level 9
Level 9
Hi Ajay
AFAIK if this is the only link connected on the router it should be able to support the same.
If you have some other links also getting terminated onto the box then better check out for the required resources such as memory etc.,
regds
