3650 QOS
yishaky_ub
I am getting this error while I apply
class-map match-all rate-limit
match input-interface FastEthernet0/4
policy-map 3M
class rate-limit
police 3000000 8000 exceed-action drop
DR-EdgeRouter(config-if)#service-policy output 3M
Match input interface is not supported for this interface
any help?
7 Replies 7
Which interface are you applying the service policy to ?
on interface FastEthernet0/4
your input interface is the same as the interface where the policy is applied to ?
I don't  think that is supported...
Try applying the service policy to a different interface to check if you get the same error...
I tried and it is the same
DR-EdgeRouter(config)#interface FastEthernet0/3
Bu here the interface aren't connected and I don't think it has effect on this
Are these layer 2 (switchport) or layer 3 (no switchport) interfaces ?
Hello
input-interface is just specifying the interface you wish to match traffic, you use an access-list to do the same thing but matching on certain traffic .
In this case the switch is trying to tell you, you cannot apply a policing policy Outbound using the input-interface from the class map, it should allow you though to specify a service-policy INPUT, or if you use an access list in the class-map instead it should allow you to use service-policy OUTPUT
res
Paul
Kind Regards
Paul
