Cisco 2811 WIC support
asadullahbutt18
Does cisco 2811 support GE WICs ?
If so kindly share detail
5 Replies 5
GRANT3779
I believe the only GE option you would have is the following -
HWIC-1GE-SFP
https://www.cisco.com/c/en/us/products/routers/2800-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
Yes, it supports HWIC-1GE-SFP  (Maximum 1 card)
https://www.cisco.com/c/dam/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/aag_c07_563807.pdf
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Which ios version supports that
According to here you can be running a minimum 12.4(15)T9
https://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-ser bvices-routers-isr/product_bulletin_c25_528661.html
Leo Laohoo
It's not whether or not the appliance can support GE modules but whether or not the appliance can PUSH 1 Gbps (with the module).
Sadly, the answer is no.
