3650 upgraded to ipservices not getting routes across WAN
georgebales
I have 2 3650 switches that were purchased with lan base image. we purchased and upgraded the switches to ipservices, and now the switches have been configured with ip routing, eigrp, a WAN vlan and a wan trunk.
when the device is linked up, the wan link shows up and up, as does the wan vlan. but my switch gets no routes from its wan peer.
I can ping the WAN vlan on my own device but not of the WAN peer, a cisco 6509. nor can i see the WAN peer as any type of neighbor, cdp or eigrp.
i've done show license right-to-use command sets and they all show ipservices active and in use, but one; show license right-to-use default shows lan base, which is the only anomaly i see and is what i believe to be the problem.
I have started a TAC case. Has anyone on this forum had similar issues with a 3650 being upgraded to ipservices? I aske the question this way because I have another 3650 in production that was purchased with ipservices, not upgraded by us and it works fine.
OK, thanks.
Hello.
Could you provide your TAC ticket number?
here it is:
638638871
thank you Vasilii
Hello.
All the symptoms you described, sounds like L2 issue.
Have you had a chance to check interface/trunk/STP status of 6500 for the port? Does your provider (in the middle) see any MACs from 3560 and 6509 sides?
PS: if the issue is severe and you need immediate assistance from TAC - just call CIN and raise ticket severity.
