3725 Router slot details
raju
I have a 3725 Router with 4 FE and 1 serial interface. Can I add one more wic-1T card in this Router.Since , I don't have physical access to Router, I can't verify the free slot available for new card . As per show diag,all the slots are occupied, just want to confirm with someone.
I have attached sh ver and sh diag FYI
Raju
pkhatri
Level 11
Level 11
The 3725 router comes with 3 WIC slots. You have a WIC-1T card installed in slot 2, which means that slots 0 and 1 are free. You should be able to install another WIC-1T in one of these slots.
I would appreciate you rating the post if it helps.
Paresh
