3745 Router Memory Cards
csteinman
How do I know if I have one 128 MB memory card or two 64 MB memory cards in a 3745 router without physically opening it up? Is there an IOS command that will tell me? Any tricks to finding this out from other commands?
jackyoung
Level 6
Level 6
Check here to determine if it works for you :
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_command_reference_chapter09186a00800ca742.html
You can try "sh flash: all" & "sh flash: chips". Please advise the result.
Hope this helps.
My co-worker next to me found the answer. It is 'show platform'. Gives you data on the Dimms in each slot, and if one is empty, it tells you so. Pretty handy for planning memory upgrades!
jolmo
Level 4
Level 4
Hi Curtis
According to: http://www.cisco.com/en/US/products/hw/routers/ps282/prod_module_installation_guide09186a008007e3cb.html#wp168876
it has one 128 MB DIMM since two 64 MB DIMMs is a non allowed configuration.
Hope this helps
sales
try Sh diag & sh ver for slot & memory info
geoff
www.simondirect.com
