09-29-2015 06:33 AM - edited 03-05-2019 02:24 AM
hi
I have issue with bop traffic passing through 3750g. Is there any feature set or sum or platform forwarding I need to enable.
eBGP is establish between 2 router connected via 3750g and and I can see the routes exchanged. But when I traceroute the bop route the switch is for some reason matching the default route and returning it back to the router and route starts to loop.
regrads logesh
09-29-2015 07:15 AM
Is the switch participating using bgp as well? If not, once the switch receives traffic from the router destined for an address, the switch is going to forward it to it's next best hop - which in your case is the default route. If that's the case, and you don't want bgp configured on your switch, you can point your more specific routes with static routes on the switch, or use an igp (ospf/eigrp) on the switch between the router and switch. You'd then redistribute your bgp learned routes on your router into whatever igp you chose.
HTH,
John
09-29-2015 05:02 PM
When a Router learns the multihop BGP router and tries to forward the traffic then the devices on the way to the destination does not required to know all the bgp route details?
Below is the diagram and configuration
R1: Configuration
hostname R1
interface GigabitEthernet0/1.102
encapsulation dot1Q 102
ip address 10.177.56.18 255.255.255.248
standby 102 ip 10.177.56.17
standby 102 priority 120
standby 102 preempt
interface GigabitEthernet0/1.108
encapsulation dot1Q 108
vrf forwarding mgmt
ip address 10.157.64.130 255.255.255.128
standby 108 ip 10.157.64.129
standby 108 priority 120
standby 108 preempt
router ospf 2 vrf mgmt
router-id 10.157.64.1
capability vrf-lite
network 10.157.64.0 0.0.3.255 area 100
network 10.157.252.74 0.0.0.0 area 0
default-information originate
router ospf 1
router-id 10.177.56.1
redistribute connected
network 10.177.56.0 0.0.3.255 area 0
router bgp 38456
bgp router-id 10.177.56.1
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 10.177.56.2 remote-as 38456
neighbor 10.177.56.2 update-source Loopback0
neighbor 10.177.57.13 remote-as 132462
neighbor 10.177.57.13 ebgp-multihop 255
neighbor 10.177.57.13 update-source Loopback0
address-family ipv4
neighbor 10.177.56.2 activate
neighbor 10.177.56.2 next-hop-self
neighbor 10.177.56.2 soft-reconfiguration inbound
neighbor 10.177.57.13 activate
neighbor 10.177.57.13 send-community both
neighbor 10.177.57.13 next-hop-self
neighbor 10.177.57.13 soft-reconfiguration inbound
exit-address-family
hostname SW1
boot-start-marker
boot-end-marker
vrf definition mgmt
description VRF for Management
rd 1000:1000
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
system mtu routing 1500
vtp mode transparent
ip routing
vlan 2-5,10
vlan 30
vlan 100-105
vlan 107
name MgmtLAN
vlan 108-109
interface Loopback0
ip address 10.177.56.5 255.255.255.255
interface FastEthernet1/0/5
description Link to BMobile_wireless_P2P
switchport access vlan 30
switchport mode access
interface Vlan1
no ip address
interface Vlan30
ip address 10.177.57.1 255.255.255.240
interface Vlan102
ip address 10.177.56.22 255.255.255.248
interface Vlan108
vrf forwarding mgmt
ip address 10.157.64.133 255.255.255.128
router ospf 1
router-id 10.177.56.3
log-adjacency-changes
ip route 0.0.0.0 0.0.0.0 10.177.56.17
