Routed Port in Vlan
How can i make a crosslink by 2 routed ports. The switchport in the router has vlan1 and the routed port cannot ping the vlan1 ip. On the other router i had the same interfaces.
How can i add the routed port to the vlan1 ??? So the port should act as a switchport.
14 Replies 14
John Blakley
Can you post your configs?
HTH,
John
HTH, John *** Please rate all useful posts ***
The interface GigabitEthernet1/0 should be in the vlan1 but i cannnot ping the vlan1 interface from GigabitEthernet1/0.
Why?
interface Vlan1
 description ##### Inside-VLAN #####
 ip address 10.0.0.2 255.255.255.0
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1/0
 no ip address
interface GigabitEthernet0/1/1
 no ip address
interface GigabitEthernet0/1/2
 no ip address
interface GigabitEthernet0/1/3
 no ip address
interface GigabitEthernet0/1/4
 no ip address
interface GigabitEthernet0/1/5
 no ip address
interface GigabitEthernet0/1/6
 no ip address
interface GigabitEthernet0/1/7
 no ip address
interface GigabitEthernet0/3/0
 no ip address
interface GigabitEthernet0/3/1
 no ip address
interface GigabitEthernet0/3/2
 no ip address
interface GigabitEthernet0/3/3
 no ip address
interface GigabitEthernet0/3/4
 no ip address
interface GigabitEthernet0/3/5
 no ip address
interface GigabitEthernet0/3/6
 no ip address
interface GigabitEthernet0/3/7
 no ip address
 description VLAN_1_Crosslink
 no ip address
interface GigabitEthernet1/1
 no ip address
 shutdown
 duplex auto
 speed auto
NAME: "CISCO2921/K9", DESCR: "CISCO2921/K9 chassis, Hw Serial#: FCZ1906605G, Hw Revision: 1.0"
PID: CISCO2921/K9      , VID: V08 , SN: FCZ1906605G
NAME: "8 Port GE Non-POE EHWIC Switch on Slot 0 SubSlot 1", DESCR: "8 Port GE Non-POE EHWIC Switch"
PID: EHWIC-D-8ESG      , VID: V01 , SN: FOC19102F4V
NAME: "8 Port GE Non-POE EHWIC Switch on Slot 0 SubSlot 3", DESCR: "8 Port GE Non-POE EHWIC Switch"
PID: EHWIC-D-8ESG      , VID: V01 , SN: FOC19102FHV
NAME: "1000BASE-SX SFP", DESCR: "1000BASE-SX SFP"
  , VID:    , SN: FNS1120M142
NAME: "2 SFP GE SM on Slot 1", DESCR: "2 SFP GE SM"
PID: SM-2GE-SFP-CU     , VID: V01 , SN: FOC182956HE
PID: GLC-SX-MM         , VID: 10.0, SN: SF851540540
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC    , VID: V03 , SN: QCS18510PYS
Interface gi 1/0 is not a switchport it  is routed port, so must have an IP address.
Yes this is my problem. Can i change it to an switchport that is in vlan1????
Try this:
int g1/0
switchport
switchport mode access
switchport access vlan 1
HTH,
John
i have only this commands in my interface
So there is no switchport command
Router(config)#interface GigabitEthernet1/0
Router(config-if)#?
Interface configuration commands:
  aaa                 Authentication, Authorization and Accounting.
  access-expression   Build a bridge boolean access expression
  arp                 Set arp type (arpa, probe, snap), timeout, log options or
                      packet priority
  authentication      Auth Manager Interface Configuration Commands
  backup              Modify backup parameters
  bandwidth           Set bandwidth informational parameter
  bfd                 BFD interface configuration commands
  bgp-policy          Apply policy propagated by bgp community string
  bridge-group        Transparent bridging interface parameters
  carrier-delay       Specify delay for interface transitions
  cdp                 CDP interface subcommands
  channel-group       Add this interface to an Etherchannel group
  clns                CLNS interface subcommands
  cmns                OSI CMNS
  crypto              Encryption/Decryption commands
  cts                 Configure Cisco Trusted Security
  cwmp                Configure CPE WAN Management Protocol(CWMP) on this
                      interface
  cws                 Configure Cloud Web Security
  dampening           Enable event dampening
  default             Set a command to its defaults
  delay               Specify interface throughput delay
  description         Interface specific description
  dot1q               dot1q interface configuration commands
  dot1x               Interface Config Commands for IEEE 802.1X
  eou                 EAPoUDP Interface Configuration Commands
  ethernet            Ethernet interface parameters
  exit                Exit from interface configuration mode
  fhrp                Configure FHRP
  flow-sampler        Attach flow sampler to the interface
  glbp                Gateway Load Balancing Protocol interface commands
  help                Description of the interactive help system
  history             Interface history histograms - 60 second, 60 minute and
                      72 hour
  hold-queue          Set hold queue depth
  ip                  Interface Internet Protocol config commands
  iphc-profile        Configure IPHC profile
  ipv6                IPv6 interface subcommands
  isis                IS-IS commands
  iso-igrp            ISO-IGRP interface subcommands
  keepalive           Enable keepalive
  llc2                LLC2 Interface Subcommands
  lldp                LLDP interface subcommands
  load-interval       Specify interval for load calculation for an interface
  location            Interface location information
  logging             Configure logging for interface
  loopback            Configure internal loopback on an interface
  mab                 MAC Authentication Bypass Interface Config Commands
  mac-address         Manually set interface MAC address
  macro               Command macro
  media-type          Configure media type
  metadata            Metadata Application
  mop                 DEC MOP server commands
  mtu                 Set the interface Maximum Transmission Unit (MTU)
  nat64               NAT64 interface commands
  netbios             Use a defined NETBIOS access list or enable name-caching
  no                  Negate a command or set its defaults
  ntp                 Configure NTP
  onep                Configure onep settings
  ospfv3              OSPFv3 interface commands
  pagp                PAgP interface subcommands
  port-tagging        Allow port tagging on an interface
  pppoe               pppoe interface subcommands
  pppoe-client        pppoe client
  rate-limit          Rate Limit
  redundancy          RG redundancy interface config
  routing             Per-interface routing configuration
  service-policy      Configure CPL Service Policy
  service-routing     Service Routing in Interface Mode
  shutdown            Shutdown the selected interface
  snapshot            Configure snapshot support on the interface
  snmp                Modify SNMP interface parameters
  source              Get config from another source
  standby             HSRP interface configuration commands
  tarp                TARP interface subcommands
  timeout             Define timeout values for this interface
  topology            Configure routing topology on the interface
  transmit-interface  Assign a transmit interface to a receive-only interface
  transport-opt       Enable Transport Optimization on an Interface or a
                      Sub-Interface
  tx-ring-limit       Configure PA level transmit ring limit
  user-group          Interface-User-group Association
  vlan-id             Process VLAN-encapsulated packets with a specific VLAN ID
  vlan-range          Process VLAN-encapsulated packets with a range of VLAN
                      IDs
  vnet                Configure VNET interface options
  vrf                 VPN Routing/Forwarding parameters on the interface
  vrrp                VRRP Interface configuration commands
  waas                WAN Optimization
  zone-member         Apply zone name
I can only assume the g1/0 is a L3 port then and you won't be able to change that. You may need to move to one of the other g0/3/? ports and that should resolve the issue...
** Edit **
I looked over your inventory, and this is a 2921. So, I'm also assuming that you have hwics in the router that allow you to configure switching. That being said, your 2 switch modules are 0/1 and 0/3. The g1/0 is going to be the L3 port that would only be able to be configured as a L3 interface and not a member of vlan 1. You will need to move your connection to the switching module...
HTH,
John
So the crosslink by the switchport is working but i want to take the fiber connection for that. So can i change the L3 g1/0 fiber port to a switchport connected to vlan1 or not?
The fiber is much more faster than the switchport.
Is this possible or not? I don´t know how to change a L3 interface to a L2 interface connected to a vlan.
Raimund
to get round this just give int Gi 1/0 an IP address say 10.0.0.3 255.255.255.0 and make that address the default gateway on the switch as I assume the router is connected to the Internet or the rest of your network.
Raimund,
The simple answer is NO
saif musa
Level 4
Level 4
Fine below....
switch(config)# interface fastethernet 0/x      (( example))
switch(config-if)# switchport mode access
switch(config-if)# switchport access vlan1
switch(config-if)# end
switch# write
switch# exit
Sorry but the command is not available in my interface.
Which one is not available inside your switch ??
The switchport command is not avialable in my interface GigabitEthernet1/0.
So it is a Layer 3 port and i would connect it to vlan1. Is this possible? With witch command?
