3750X Switch Transceiver compatibility Issue
sarifulcisco
Dear All,
I have WS-C3750X-24T-S switch with C3KX-NM-1G and now i want to put a transceiver GLC-EX-SMD= in the switch SFP port, is this GLC-EX-SMD= compatable with that switch ?. i thorughly check the product datasheet and compatible chart but their i don't have seen ?. Please help me.
Palash
InayathUlla Sharieff
Sorry to say this module is not supported on WS-C3750X-24T-S.
http://wiki.nesevo.com/index.php/Gigabit_Ethernet_Transceiver_Modules_Compatibility_Matrix
This is supported on 3750Metro switches.
Catalyst 3750 Metro
ME-C3750-24TE-M
GLC-T (1000BASE-T)
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
CWDM SFP
GLC-BX-D
GLC-BX-U
DWDM SFP
DWDM SFP (add.)
SFP-GE-S
SFP-GE-L
SFP-GE-T (10/100/1000)
GLC-EX-SMD
12.2(46)SE
12.2(44)SE
12.2(44)SE
12.2(44)SE
12.2(50)SE
12.2(46)SE
12.2(52)SE
12.1(14)AX
12.1(14)AX1
12.1(14)AX1
12.2(25)EY2
12.2(40)SE
12.2(50)SE
12.2(46)SE
12.2(46)SE
12.2(5
REgards
Inayath
******Please rate if this info is helpfull and mark the thread as Answered if this has answered your query.
I check the compability list again:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
for the WS-C3750X-48T and found that:
GLC-EX-SMD
(CPN 10-2624-01 or later only)
Please tell me what is "CPN 10-2624-01 or later", how can I get that for GLC-EX-SMD can work on 3750X, thank you.
It will work on the 3750X.
10-2624-01 is the Cisco Part number.  The last two digits, i.  e.  "01", is the version number.
