3800 Series Router Question
sknorr
We are planning to upgrade from 3600 to 3800 series routers. The one question that we have is, going forward if we wanted to use MPLS for our WAN solution would the 3800 support the physical connections for DS3 or T3 or would we have to upgrade again to the 7200 series?
smif101
Level 4
Level 4
If you go with the advanced ip services IOS, that should provide you with the mpls features you would want. From cisco:
Advanced IP Services
• Advanced IP Services is a comprehensive set of Cisco IOS Software features designed for IP-only networks. It includes all the features of IP Services, plus additional features including ISIS, MPLS, Layer 2 VPNs, Layer 3 VPNs, and IPv6.
• Deployment Guidelines: Service Provider Environments, Enterprise: Campus WAN and Metro Edge
