3825 Replacement Fan 3
Andrew Bailey
I have a 3825 with fan 3 failing according to syslog messages.
ENVMON-4-FAN_LOW_RPM: Fan 3 service recommended
I have taken the router a part and see that fan 3 is slimmer than fans 1 and 2. I am trying to find a replacement fan, but only can find fans 1 and 2.
(ACS-3825-FAN-1/2) http://www.cablesandkits.com/cisco-3825-router-fan-fan-replacement-p-5046.htm
This fan http://www.cablesandkits.com/cisco-3725-router-replacement-chassis-fan-p-4638.html looks like it could be the same but I do not have a 3725 to verify.
Does anyone know how I can verify if it is the same fan? Or where I can find a replacemenet 3825 fan 3? Thanks.
Eslam Daoud
I had the same problem , We sent a Tech to check the router and he advised that its type same as below.
