3825 Router PAT configuration problem.
sayedahmads
I have cisco 3825 router with two interface one with public ip 182.50.190.140 and the other with private ip 192.168.1.1 and the DNS is 66.28.0.45, I configured NAT overload on it to access internet I can ping public ip nad default gateway but cannot ping dns and neither internet can be accesed.
following are the configurations.
Current configuration : 3045 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
--More--
ip dhcp pool noc
   import all
   network 192.168.1.0 255.255.255.0
   dns-server 66.28.0.45
   default-router 192.168.1.1
ip domain name noc
ip name-server 66.28.0.45
ip name-server 4.2.2.5
crypto pki trustpoint TP-self-signed-1732394243
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1732394243
revocation-check none
rsakeypair TP-self-signed-1732394243
crypto pki certificate chain TP-self-signed-1732394243
certificate self-signed 01
  3082023E 308201A7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31373332 33393432 3433301E 170D3132 30363238 30373137
  35365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 37333233
  39343234 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100952B 9734D85D 1C566AC4 0648A999 F0CDD1B8 4FE87878 80F92DF3 F48CFE88
  0D0D7CC2 DEC55623 4091FE03 288994E1 8EA99592 9E69DB02 B961A748 7534C3A0
  B4C781DC 8390FECA 576C23AC E0384AD3 A88DC767 0ECF95EB 01749B8A 272F70FB
  579BAD74 74A1F6E6 5887E5D6 B57F160B D2D4BA13 0DFE0F37 EA6E41AC 2B267491
  95970203 010001A3 66306430 0F060355 1D130101 FF040530 030101FF 30110603
  551D1104 0A300882 0652312E 6E6F6330 1F060355 1D230418 30168014 E0B5F2C8
  BC1BC49D A917EBA0 59751280 FB78BC84 301D0603 551D0E04 160414E0 B5F2C8BC
  1BC49DA9 17EBA059 751280FB 78BC8430 0D06092A 864886F7 0D010104 05000381
  810014F5 E5E26052 59CBDFB0 5E593ED5 93006065 C654B96A FB3666CB 23297D0C
  66683A79 40DEC588 C8E1CE8B 73CE2D8A B7D6574A A97C0583 7EF2DB28 4D1694E2
  06D79FC3 A306C3D8 19C08E23 56BF02A7 6CDF7664 B13EE6E3 58A4D873 5037764F
  71EB7B2F 6B903071 B3C36A50 5A9024CA 9FD1C86E D2203E6C 4AE0FE4E B0A28898 6CE9
        quit
username noc privilege 15 password 0 noc
archive
log config
  hidekeys
interface GigabitEthernet0/0
ip address 182.50.190.140 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip nat inside
duplex auto
speed auto
media-type rj45
ip default-gateway 182.50.190.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 66.28.0.0 0.0.0.255
access-list 2 permit 66.28.0.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
cadet alain
no ip route 0.0.0.0  0.0.0.0 Gig0/0
ip route 0.0.0.0 0.0.0.0 182.50.190.254
no access-list 1
clear ip nat tra *
Regards.
Alain
handoko wiyanto
Level 3
Level 3
hi sayed,
i believe Alain have the answer.
i just saying that if you post your router config, i think its better if you mask some value on the router config such as username/password/some ip public. even with the service password endcrption enable, nowadays there are tools to reveal the password.
regards,
