3845 Best Route Between Two Links
dtom
We have a 3845 router at one of our remote sites.  We want to connect the router to our central office using the two gigabit ports.  One link would be the primary and the other would be the secondary (backup).  The router is running EIGRP and the two ports would have diffrent ip addresses. How can we set up the router to use gi0/0 as the primary port and gi0/1 as the secondary (backup) port?  The backup port would only be used if there was congestion on the primary port or if the primary port went down.  Is there a way to force the router to make the primary link the best route?
Remote Router Sample Config:
int gi0/0
  desc primary link to Central Office
  ip addr 10.0.1.84 255.255.255.0
  duplex auto
  speed auto
int gi0/1
  desc backup link to Central Office
  ip addr 10.0.2.84 255.255.255.0
  duplex auto
  speed auto
router eigrp 64
  network 10.0.0.0
  network 172.16.0.0
  no auto-summary
Central Office Sample Config
int gi0/0
desc primary link to Remote Offices
ip addr 10.0.1.254 255.255.255.0
duplex auto
speed auto
int gi0/1
desc backup link to Remote Offices
ip addr 10.0.2.254 255.255.255.0
duplex auto
speed auto
router eigrp 64
network 10.0.0.0
network 172.18.0.0
no auto-summary
6 Replies 6
Jose Bogantes
Hello Dtom,
Please check the following link:
Q.    How can I use only one path when a router has two equal cost   paths?
A. Configure the bandwidth value on the interfaces to default, and       increase the delay on the backup interface so that the router does not see two       equal cost paths.
http://www.cisco.com/en/US/tech/tk365/technologies_q_and_a_item09186a008012dac4.shtml
Try something like this and let me know if it works:
R4(config)# interface GigabitEthernet0/1R4(config-if)# delay 10
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c2d96.shtml#delayparaR4
(The default delay is 1 when configured under the interface and it equals 10 microseconds )
3845_2(config-if)#delay ?
  <1-16777215>  Throughput delay (tens of microseconds)
If you use "delay 10", the interface will look this:
3845_2(config-if)#do sho int giga0/1
GigabitEthernet0/0 is up, line protocol is down
  Hardware is BCM1125 Internal MAC, address is 0015.629a.8aa0 (bia 0015.629a.8aa0)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 100 usec,
Regards.
kecorder
Remember to change The delay on The router receiving the update, not the one sending it. On the other hand the route will not change if interface is congested, only PfR can do that...
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Eh?
Believe if you have two equal cost paths, from two ports, on the same router, you'll want to adjust the EIGRP delay on at least one of those ports.
kecorder
Yes if you recieve two routes you can change the delay on one of the interfaces, I just wanted to remind you you need to change the delay on the interface that recieves the route, not on The router that sends The route
Disclaimer
Posting
Ah, I understand what you're saying now.
Thanks.
Rahul Kukreja
One Other option -
Use Summarization. Advertise summary routes over backup link and specific over the primary Link
