Few BGP questions
ashah5053
Please help on answers for below mentioned questions
1.Can we redistribute BGP into IGP?
2.Does it require that BGP router-id should reachable in cloud?
3.If a static route is advertised in BGP without using update source what will be the next hop address in update
4.In Multihoming scenario if primary link gets fail, after how long traffic will be shifted to secondary link
5.I am receiving updates from eBGP peer, will the next hop change or not
6.I am receiving updates from iBGP peer, will the next hop change or not
Nagendra Kumar Nainar
You can. It basically depends on the number of prefixes to be redistributed. Normally, it is not recommended to redistribute full internet table into IGP.
No. It is not required to be reachable.
If I remember it right, it depends on who you are advertising to. If it is advertised to iBGP neighbor, it uses the nexthop as it is in RIB table. If it is without nexthop in RIB, it will set the BGP source address.
If it is advertised to eBGP neighbor, it will set it as BGP source address.
By default, fast external failover is enabled for eBGP neighbor. So when the egress interface fails, it immediately bring down the BGP session and next best path will be selected. if you have it disabled, it wil lrely on the BGP holdtimer.
If you dont have any inbound policy to change the nexthop, irrespective of receiving an update from eBGP or iBGP, NH will be the one received in update. But when you advertise to eBGP neighbor, NH will be set to self by default.
If  you dont have any inbound policy to change the nexthop, irrespective of  receiving an update from eBGP or iBGP, NH will be the one received in  update. But when you advertise to iBGP neighbor, NH will not be changed by default.
HTH,
Nagendra
