05-19-2022
09:26 AM
- last edited on
05-19-2022
11:24 PM
by
Translator
Has anyone seen this before? We have a 3850-24XU with 8x10G Uplink Module that once a SFP is plugged in to 1 of the 8 ports it causes all 8 ports on the network module to go into an errdisable loop. See below. We've tried cisco and 3rd party SFPs and same issue. We have the unsupported transceiver command in. It doesnt matter what port the SFP is plugged into. The only way to break the loop is to issue a reboot.
000037: *May 19 08:09:22: %PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP module with interface name Te1/1/1 is not supported
000038: *May 19 08:09:22: %PM-4-ERR_DISABLE: gbic-invalid error detected on Te1/1/1, putting Te1/1/1 in err-disable state
000039: *May 19 08:09:23: %PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP module with interface name Te1/1/2 is not supported
000040: *May 19 08:09:23: %PM-4-ERR_DISABLE: gbic-invalid error detected on Te1/1/2, putting Te1/1/2 in err-disable state
000041: *May 19 08:09:24: %PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP module with interface name Te1/1/3 is not supported
000042: *May 19 08:09:24: %PM-4-ERR_DISABLE: gbic-invalid error detected on Te1/1/3, putting Te1/1/3 in err-disable state
000043: *May 19 08:09:26: %PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP module with interface name Te1/1/4 is not supported
000044: *May 19 08:09:26: %PM-4-ERR_DISABLE: gbic-invalid error detected on Te1/1/4, putting Te1/1/4 in err-disable state
000045: *May 19 08:09:27: %PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP module with interface name Te1/1/5 is not supported
000046: *May 19 08:09:27: %PM-4-ERR_DISABLE: gbic-invalid error detected on Te1/1/5, putting Te1/1/5 in err-disable state
000047: *May 19 08:09:29: %PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP module with interface name Te1/1/6 is not supported
000048: *May 19 08:09:29: %PM-4-ERR_DISABLE: gbic-invalid error detected on Te1/1/6, putting Te1/1/6 in err-disable state
000049: *May 19 08:09:30: %PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP module with interface name Te1/1/7 is not supported
000050: *May 19 08:09:31: %PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP module with interface name Te1/1/8 is not supported
000051: *May 19 08:09:31: %PM-4-ERR_DISABLE: gbic-invalid error detected on Te1/1/8, putting Te1/1/8 in err-disable state
000052: *May 19 08:09:52: %PM-4-ERR_RECOVER: Attempting to recover from gbic-invalid err-disable state on Te1/1/1
000053: *May 19 08:09:53: %PM-4-ERR_RECOVER: Attempting to recover from gbic-invalid err-disable state on Te1/1/2
000054: *May 19 08:09:53: %PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP module with interface name Te1/1/1 is not supported
000055: *May 19 08:09:53: %PM-4-ERR_DISABLE: gbic-invalid error detected on Te1/1/1, putting Te1/1/1 in err-disable state
Solved! Go to Solution.
05-19-2022 09:45 AM
- FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvc79837
M.
05-19-2022 09:30 AM
what is the version of code code running, what SFP Module 10G or 1G what is the part code ?
check below document may help you :
05-19-2022
09:40 AM
- last edited on
05-20-2022
12:43 AM
by
Translator
Switch Ports Model SW Version SW Image Mode
* 1 38 WS-C3850-24XU 03.07.04.E cat3k_caa-universalk9 BUNDLE
We've tried both 10G and 1G
1G - Cisco GLC-LH-SM
30-1299-01
Class 1 21CFR1040.10
LN#50 7/2001
10G- Cisco SFP-10G-LR
10-2457-01
LN#50 7/2001
05-19-2022
09:44 AM
- last edited on
05-20-2022
12:16 AM
by
Translator
have you tried other option mentioned in the document and bug.
shut / no shut
Workaround: remove sfp module
shutdown/no-shutdown
in the interface mode insert sfp module
or upgrade or downgrade the version it was suggested.
05-19-2022 10:05 AM
I will be upgrading it. Thanks for the help.
05-19-2022 04:08 PM
Please upgrade to 3.7.5 and do not upgrade to 16.X.X.
Also be aware of CSCvq53573.
05-19-2022 09:45 AM
M.
05-19-2022 10:00 AM
Thank you I will take a look.
