3850 MPLS and LDPv6
rasmus.elmholt
Level 7
Level 7
I am trying MPLS on the new Denali 16.3.2 and can't get it to work with LDPv6.
Does anyone know if it is supported or on the roadmap?
Rasmus
according to the Cisco Feature Navigator, XE doesn't support LDPv6 at ll. You need XR 5.3.0.
But 5.3.0 is quite old, and LDPv6 is only supported on the CSR.
Has LDPv6 been abandoned?
I think you could use 6PE or 6VPE to move the traffic IPv6 through a IPv4 MPLS, I remember ldp doesn´t work with IPv6 directly but you could use those alternative solutions.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio
It is the exact opposit i want to do.
I want my core network to only be IPv6, and have IPv6/IPv4 on the edge.
That is why i need LDPv6.
