3925E - Field Notice FN - 63723 - How to retrieve Fan Tray Serial Number from CLI
Hello Experts,
My customer has installed a bunch of 3925E routers, so far we've replaced 3 of them presumably because of FN - 63723. I've been able to corroborate it from the last replacement, since I had access to the faulty fan tray in order to check its serial number.
Now that we found the FN, we have many routers to verify if they are prone to the same issue with the fan tray, however, I've not been able to find a command to retrieve the SN of the fan tray from the CLI. Otherwise, we would need to shut those production routers down in order to check this. And that would really suck.
The image installed in most of them is c3900e-universalk9-mz.SPA.151-4.M6.bin.
FN - 63723:
http://www.cisco.com/c/en/us/support/docs/field-notices/637/fn63723.html
BTW. I've SNMP walked the router, with no luck =(.
Thanks in advance for the help,
Pam
There is no command that would give you that output.
Leo Laohoo
Try "sh inventory raw".
Nope, already tried that:
show inventory raw
NAME: "CISCO3925-CHASSIS", DESCR: "CISCO3925-CHASSIS"
PID: CISCO3925-CHASSIS , VID: V02, SN: FTXXXXXXXX
NAME: "C3925SPE200 Chassis Slot 0", DESCR: "C3925SPE200 Chassis Slot"
PID:                   , VID:    , SN:
NAME: "Cisco Services Performance Engine 200 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 200 for Cisco 3900 ISR"
PID: C3900-SPE200/K9   , VID: V04 , SN: FOCXXXXXXX
NAME: "DaughterCard Slot 0 on Card 0", DESCR: "C3925SPE200 DaughterCard Slot"
PID:                   , VID:    , SN:
NAME: "XFR-1GE SFP Container", DESCR: "XFR-1GE SFP Container"
PID:                   , VID:    , SN:
PID:                   , VID:    , SN:
NAME: "DaughterCard Slot 1 on Card 0", DESCR: "C3925SPE200 DaughterCard Slot"
PID:                   , VID:    , SN:
NAME: "DaughterCard Slot 2 on Card 0", DESCR: "C3925SPE200 DaughterCard Slot"
PID:                   , VID:    , SN:
NAME: "DaughterCard Slot 3 on Card 0", DESCR: "C3925SPE200 DaughterCard Slot"
PID:                   , VID:    , SN:
NAME: "DaughterCard Slot 4 on Card 0", DESCR: "C3925SPE200 DaughterCard Slot"
PID:                   , VID:    , SN:
NAME: "DaughterCard Slot 5 on Card 0", DESCR: "C3925SPE200 DaughterCard Slot"
PID:                   , VID:    , SN:
NAME: "GigabitEthernet0/0", DESCR: "iGbE"
PID:                   , VID:    , SN:
NAME: "GigabitEthernet0/1", DESCR: "iGbE"
PID:                   , VID:    , SN:
NAME: "GigabitEthernet0/2", DESCR: "iGbE"
PID:                   , VID:    , SN:
NAME: "GigabitEthernet0/3", DESCR: "iGbE"
PID:                   , VID:    , SN:
NAME: "C3925SPE200 Chassis Slot 1", DESCR: "C3925SPE200 Chassis Slot"
PID:                   , VID:    , SN:
NAME: "C3925SPE200 Chassis Slot 2", DESCR: "C3925SPE200 Chassis Slot"
PID:                   , VID:    , SN:
NAME: "Container of powerSupply Containers", DESCR: "Container of powerSupply Containers"
PID:                   , VID:    , SN:
NAME: "Container of Power Supply 1", DESCR: "Container of Power Supply 1"
PID:                   , VID:    , SN:
NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
PID: PWR-3900-AC       , VID: V04 , SN: PSTXXXXXXXX
NAME: "Container of Power Supply 2", DESCR: "Container of Power Supply 2"
PID:                   , VID:    , SN:
NAME: "C3900 Unknown Power Supply 2", DESCR: "C3900 Unknown Power Supply 2"
PID:                   , VID:    , SN:
