3G configuration Cisco 881G
millencol1n
quick question regarding a 3G access via a cisco 881G
i have a partner sim card (with the same number as the one in my mobile) iserted into the router.
now i have the problem that my mobile is unreachable (line busy), is there a way to use both sims at the same time?
what do i have to change in the router configuration?
thx,
Martin
paolo bevilacqua
The router doesn't know nothing and cannot do nothing about how many sims and numbers you have.
If it can establish a connection only depends by telco, so in case of problem you wil will have to talk with them
