3G router on MPLS network
happyatuni
Dear all,
I currently have a 150 nodes MPLS network.  My management is anxious to join some sites with 3G routers as their centres move around a lot.
My current MPLS site as 4 x Ps with lots of PEs linking to the 150 x CEs.  Is there a way to easily link up my 3G routers to my MPLS network? I have heard DMVPN may be a solution, but not sure how to implement.
Would be great if anyone can shed some light on this.
Cheers,
Hunt
Emperor2000
Hello.
Have a look at MPLS over mGRE. We use that with 1921 and 2901 and 3G/4G EHWICs as CE with MPLS to the edge.
Alternatively MPLS over mGRE over IPSEC if you are using public 3G networks. Eitherway you would need to lower the MTU on inside interface to allow for the added overhead that IPSEC, GRE and MPLS adds.
Using mGRE allows you to have dynamic ip addresses on enpoints in the CE side.
Empreror2000,
Thanks heaps for your reply.
Just curious would you mind to share some "sample configs" on how to setup MPLS over mGRE for CE routers? As well as config on "one of the core" for accepting MPLS over mGRE connections?
I am completely new to this and would like to learn more and ensure i setup everything correctly on my corporate network.
Cheers
Also, is MPLS over mGRE over IPSEC = DMVPN? And would it work over 3G / 4G EHWICs?
Emperor2000
Yea sure.
Core part. This is from 2951 acting as hub router.
interface Tunnel3
bandwidth 1000000
ip address
no ip redirects
ip pim sparse-dense-mode
ip nhrp authentication
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip ospf network broadcast
ip ospf priority 10
mpls ip
tunnel source GigabitEthernet0/1.425
tunnel mode gre multipoint
  tunnel protection ipsec profile
tunnel key 1
CE part this is a 892F as spoke router.
interface Tunnel2
ip address
ip nhrp map
ip nhrp nhs
ip ospf network point-to-multipoint
mpls ip
tunnel destination
tunnel key 1
I dont have a configuration for mGRE over 3G/4G ehwics ive just tested ordinary MPLS o GRE o IPSEC on thoose interfaces but since that isnt an issue there shouldnt be an issue doing mGRE over inte either.
