4321 Nat problem
Triode
Hello everyone.
I've recently got a 4321 router and tried to test it out in the lab with a simple NAT config. Although both the router and the hosts inside the NAT are able to ping the internet (eg. 1.1.1.1 or 8.8.8.8) other network services such as DNS name resolution or HTTP navigation either by domain name or direct IP won't work.
Is there any command I'm missing?
Current configuration : 1654 bytes
! Last configuration change at 07:52:40 UTC Sat Mar 9 2019
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip dhcp excluded-address 192.168.99.1 192.168.99.10
ip dhcp pool DHCPPOOL
network 192.168.99.0 255.255.255.0
default-router 192.168.99.1
dns-server 1.1.1.1
domain-name NAT
subscriber templating
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
ip address 192.168.0.5 255.255.255.0
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
ip address 192.168.99.1 255.255.255.0
ip nat inside
negotiation auto
vrf forwarding Mgmt-intf
no ip address
negotiation auto
interface Vlan1
no ip address
shutdown
ip nat pool NATPOOL 192.168.0.5 192.168.0.5 netmask 255.255.255.0
ip nat inside source list 1 pool NATPOOL overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0/0/0
ip route 0.0.0.0 0.0.0.0 192.168.0.1
access-list 1 permit 192.168.99.0 0.0.0.255
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
ntp server pool.ntp.org
end
Hello
Looks like your already receiving a private addressing meaning upstream from your rtr is a device performing network translation already, which isn't a problem but you need to specify correct dns servers or you can set the rtr to use the upstream dhcp settings if that's applicable
example1:
dns-server 1.1.1.1
domain-name NAT
dns-server 208.67.220.220  208.67.222.222  <-- these are cisco public umbrella dns servers ( highly recommended to use)
example2
ip address dhcp
dns-server 1.1.1.1
domain-name NAT
import-all
ip route 0.0.0.0 0.0.0.0 gig0/0 dhcp
ip nat source list 1 interface gig0/0
Kind Regards
Paul
you seem to be using private space addressing for your external (NAT outside) interface, what else is in between the 4331 and the Internet, a modem ?
Try and change your DHCP pool to:
dns-server 8.8.8.8 8.8.4.4
--> no domain-name NAT
Deepak Kumar
Your DHCP configuration seems not correct as:
dns-server 1.1.1.1 8.8.8.8
no domain-name NAT
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
example1:
dns-server 1.1.1.1
domain-name NAT
example2
ip address dhcp
dns-server 1.1.1.1
domain-name NAT
import-all
Kind Regards
Paul
Thanks, the example 2 worked perfecly.
Although I still find weird the fact that the first config didn't work when the settings the router retrieved from the DHCP server are pretty much the same I was assigning manually.
Best regards.
