4321 Router Initializing Hardware Stuck
Pearce
Everytime i boot the router i get the below
'Initializing Hardware...'
I need to enter ROMMON, however i am unable to type, Breaking in putty or Spamming break doesn't seem to work.
I am unsure on how to progress as i don't seem to be able to get past this.
Does anyone have any idea on how i can proceed?
TIA
12 Replies 12
I took the liberty to move your post from the IP Telephony and Phone board as it didn’t match the topic of that board to the Routing board.
Response Signature
What flow control are you using on your emulator? It could be that the router is expecting RTS/CTS and you are using XON/XOFF or none. Try a different setting for flow control.
Leo Laohoo
If the router is still in ROMMON, post the complete output to the following commands:
  1. dir bootflash:
  2. set
Unfortunately i'm unable to enter ROMMON mode. Thank you.
Are you saying that after "Initializing Hardware" that is all you get?
Yea, so the only thing it states in the CLI is 'Initializing Hardware...", nothing else, then 2 or 3 mins later its says it again.
Contact Cisco TAC and organize RMA.
 - You can do  a 'final power cycle' , if it keeps on Initializing hardware, consider the device broken and have it replaced (RMA).
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 - If it doesn't go past Initializing Hardware, then that could be a fatal hardware problem
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Could this be the console port? I say this because the USB Type B mini port,  is loose and that is how we are connecting to the console?
 - Very much doubt it , when you see 'Initializing hardware' then that can only mean that your console works.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I agree with @Mark Elsen that it’s doubtful that it is a problem with the console port as you get output. Quite likely your hardware is FOBAR’ed and needs replacement.
Response Signature
