04-13-2021 07:29 AM
Can a Cisco 4331 ISR Chassis equipped with an AC PSU, accommodate a DC PSU, or are they different chassis types?
04-13-2021 07:50 AM
Hi PhilS
4000 series routers support a variety of power supply configurations. The power supplies are field-replaceable
and externally accessible. The Cisco 4331 ISR power supply is not externally accessible, it is inside the
chassis.
The Cisco 4451-X ISR and Cisco 4431ISRs support dual, hot-swappable power supplies.
Below Table summarizes the power options
04-13-2021 04:05 PM
Same chassis. Different PS models. Hot swappable.
