4331 ISR won't take "zone" command.
Not applicable
So I have a brand new 4331 ISR and literally just putting in basic config. Yes, n00b, but have some basics. I am trying to configure zone based firewall... I get my "conf t" and type in;
NEW4331ISR(config)#zone security PUBLIC
% Invalid input detected at '^' marker.
NEW4331ISR(config)#
I am obviously missing something really easy, like "licensing" or "you can't do that without _____ you n00b"
So.. short of RTFM what does the community have for me.
Sean
Running Config attached
9 Replies 9
that is indeed usually a licensing issue. Can you post the output of 'show version' and 'show license' ?
NEW4331ISR#sh ver
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
NEW4331ISR uptime is 1 day, 6 hours, 36 minutes
Uptime for this control processor is 1 day, 6 hours, 37 minutes
System returned to ROM by reload at 04:18:13 UTC Wed Mar 22 2017
System image file is "bootflash:/isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bi"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None Smart License None
securityk9
appxk9
AdvUCSuiteK9 None Smart License None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None Smart License None
uck9 None Smart License None
securityk9 None Smart License None
ipbase ipbasek9 Smart License ipbasek9
cisco ISR4331/K9 (1RU) processor with 1648789K/6147K bytes of memory.
Processor board ID FDOX0X0X0X0X
5 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3223551K bytes of flash memory at bootflash:.
Not applicable
***EDIT***
possibly you have smart licensing enabled. Try and disable it with the command:
NEW4331ISR#no license smart enable
and then reboot the device.
OK, then here's what I want to do. I want to block all EXTERNAL->INTERNAL traffic, and create 3 VPN connections to small offices around town. What Lic do I need?
Sean
the 'Security' license is what you need.
Ok, so when I try to install the Lic;
NEW4331ISR#license install flash:isr4300-universalk9.lic
No matter what I try and put there it always gives me invalid at the first letter of the switch after "license".
What gives?
what options do you have:
NEW4331ISR#license ?
smart Smart licensing
