4431 Port Channel configuration changes affer upgrade
mumbles202
Level 5
Level 5
I had a 4431 running 16.12.4 with a working port-channel to a stack of switches. The channel-froup was set to active on the router. Upgraded the code to 16.12.5 and the configuration under the interface went from channel-group 2 mode active to channel-group 2. If I do a show startup the configuration is correct. I removed the channel-group from the interfaces and added it back correctly and saved the configuration.  Just tested another reboot and seeing the same behavior. I fixed it again but now considering reverting back to 16.12.4. Is this a known issue?
Leo Laohoo
Raise a TAC Case.  This is a known issue:  CSCvw74609
NOTE:  Since the release of 16.12.5 for ASR 4000, this is the FOURTH time I have seen this (two here at CSC and another two from "other" forums) issue being reported.
