4431 T1 Card
IP_Cartel
Is there documentation at what point the configuration disappears when a PRI T1 card has loss of connectivity to the PSTN service provider?
I had the PRI-Group go missing from the controller t1 config and the interface serial.
I am wondering if someone hot removed and reinsert the card in the same slot causing the configs to vanish.  I know if the card is moved to a new slot the config will need to be rebuilt.
I rebuilt the config.  It's working now.  I just want to know if in the future someone randomly removes the T1 cable or card if that will drop the config from the setup.
0 Replies 0
