4500X stacks occasionally unreachable
spfister336
Level 2
Level 2
We have several remote site where we have replaced 4506 switches with a stack of two 4500Xs as the site's core switch. They have been working OK for the most part, but we are constantly seeing them unreachable for a few minutes. It happens maybe 2 or 3 times a day and it's happening to different ones each time. When they come up, nothing in the logs seems to indicate there was a problem. I don't see errors on ports, and checking the EIGRP neighbor I don't see any indication that the neighbor relationship was affected at all. All switches, including the AT&T equipment connecting the site to their Opt-E-MAN network show no downtime at all. I don't really have much in the way of clues as to what's going on. I'm thinking it may be some sort of VSS issue (I think this is the first time we've used it in our environment), but I don't see what it might be. Can anyone tell me what I should look at?
5 Replies 5
Philip D'Ath
What software versions are you using on them?  Some of the earlier IOS-XE releases where "flaky".
Looks like most of them are 3.7.1E
Do you think you could try upgrading one of them to the current release in that train, 3.7.3E?
Resolved Caveats in Cisco IOS XE Release 3.7.3E
Bug ID
Headline
CSCum06547
NG3K standalone crashed after removed energywise domain
CSCus17795
Same port name displays in lower and upper case during OpenFlow configuration
CSCus84849
ipdt difference in config and default configuration
CSCus99269
MCMA: dACL should not be synced to MA & should be allowed on MA as well
CSCut14397
Bad parsing when keyword is truncated during OpenFlow LXC configuration
CSCut25533
PnPA: non-vlan CLI should only apply to newly bootup devices
CSCut87285
MAC address being learnt on an individual Port-channel member interface
CSCut88813
WLAN cannot be configured with a space in psk shared key on NGWC 3.7
CSCuu09331
CTS link not passing traffic after SSO
CSCuu15831
Switch reboots when SPAN configured under "cts manual"
CSCuu34717
3850 cts enforcement for multicast traffic
CSCuu36487
Cat3k: OF: Vlan strip action doesnot work for ipv6 packets
CSCuu49195
Access session cache entries not getting updated
CSCuu56466
"Total output drops" counter of a certain ports does not increment
CSCuu56511
OutDiscards counter does not increment
CSCuu66503
HTTPs: IOS HTTPS client not enforcing subject-name verification
CSCuu82607
Evaluation of all for OpenSSL June 2015
CSCuu85807
Switch returns wrong OID when standalone
CSCuu87659
CpmCPUTotal5minRev average value of stack switch 2 on 3850 is incorrect.
CSCuu97048
Traffic is dropped due to static mac entry on foreign interface
CSCuu97550
4500X - SNMP dot1dTpFdbPort retuning incorrect value
CSCuv02964
Memory leak with dot1x on IOS-XE switch
CSCuv07427
TCP connection cannot be established with Openflow agent due to
CSCuv13351
MAC address is learned on RSPAN vlan after stack switchover
CSCuv14890
DHCPv6 solicit frame (IPv6 multicast) frame replication issues
CSCuv19160
Config lock mode during redundancy prevents PnP redirection.
CSCuv19204
NTP Server take 15 - 18 minutes to sync with API-EM clock
CSCuv19773
"nmsp attach suppress" not being added into run-config on WS-C3850-24P
CSCuv20618
3650 - Port goes down when 'no mdix auto' is configured, POE works fine
CSCuv20921
mac address-table learning command should not be allowed for RSPAN vlan
CSCuv22736
After reload, C3850-NM-4-10G/GLC-SX-MM not linkup with speed nonegotiate
CSCuv36348
management port can be added to OpenFlow config
CSCuv42533
Flow addition failing with wildcard match
CSCuv62574
GRE tunnel in up/down state when tunnel source configured via interface
CSCuv78424
Unicast ARP packets are duplicated
CSCuv85232
openflow exclusive config not cleared on standby
CSCuv88334
mismatch in the rf parameters mode between cli/gui
CSCuw06386
Flows are not prgrmd in PD after consecutive clearopenflow switch1 cntrl
CSCuw19798
GRE Tunnel not working on Catalyst 3850
CSCuw21694
Invalid flow count increasing in PD when i remove and add OF ports
CSCuw22050
Switch reports Power device detected when non device is connected
CSCuw28638
3650 Rebooting during EAP-TLS authentication
CSCuw36865
L2 switched traffic matched by L3 SVI VACL in the output direction
CSCuw38233
Mobility tunnel between MA/MC drops when default egress policy is deny
CSCuw39020
access-session vlan-assignment ignore-errors breaks dynamic vlan assign
CSCuw55669
Crash is seen in iosd on switch and auth-mgr
CSCuw67734
CFD CSCun37216 entAliasMappingIdentifier broken on 03.07.02E...
CSCuw73525
3650 DHCPv6 Guard does not block rogue DHCP server to provide IPv6 addr
CSCuw82216
Catalyst3850: Upgrade in install mode corrupts the flash - EXT2-fs error
CSCuw98232
Fixing build breakage for 15.2(3)E/3.7.3E which happened with CSCuv62574
Resolved Caveats in Cisco IOS XE Release 3.7.2E
Bug ID
Headline
CSCup55828
Need error message when using a wrong image to do software install
CSCuq44139
Need to disable Macsec for half-duplex mode on downlink ports
CSCus69196
After overnight ping traffic on active, standby sw#6 crashes at iosd
CSCus89656
Trust, DSCP transparency, COPP not working when a member comes up
CSCut26365
Packet drop on 3850 by an unrelated ACL entry
CSCut49440
3850 class-map "match" doesn't work correctly
Resolved Caveats in Cisco IOS XE Release 3.7.1E
There are no caveats to list here.
Resolved Caveats in Cisco IOS XE Release 3.7.0E
Bug ID
Headline
CSCun29064
Show switch details show false stack linkdown
CSCun54503
No QOS Per Port Per VLAN configuration option 3650 & 3850
CSCuo00561
Switch unusable for 8 minutes after ?default interface? w/ L3 CTS config
CSCup40892
Wireless clients may be stuck in idle state when FQDN feature is enabled
CSCup62150
After Inter-Switch Roam, QoS policy is not applied to Client
CSCuq02810
STP check bypassed for data traffic sent to switch mac address
Yes, I think we should be to schedule that. I'll give it a try.
